Question about Reliance Water Heaters
Reliance propane water heater filter
Clogged
  • Reliance Master
  • 5,245 Answers
  • 11 Answers
SOURCE: Need Instruction Manual for 1992 Reliance LP 40-gal. water heater
Gas water heaters have not changed much over the last few decades. The manual that they sent you should suffice. What sort of a problem are you having?
Posted on May 25, 2009
  • 582 Answers
SOURCE: Describe your Reliance & 30 Gal LP
TURN OFF THE GAS VALVE AND WATER TO THE TANK REMOVE THE PIPES FOR THE DRAFT USE A SHOP VAC AND CLEAN THE DIRT AND DUST FROM THE INSIDE OF THE DUCT WORK ALSO WHERE THE BURNER IS LOCATED YOU CAN VACUME THERE ALSO AND REINSTALL THE DUCT TO THE FLUE
Posted on Aug 23, 2009
co7196
  • 3433 Answers
SOURCE: reliance water heater has a loud pop and somthing
YOU ARE PROBABLY HEARING THE WATER PERK DUE TO CALCIUM AND LINE BUILD UP.. YOU CAN DESCALE WITH ACID BUT IT TAKES A CIRCULATION PUMP AND A LITTLE PLUMBING SKILL.
Posted on Sep 25, 2009
  • 82 Answers
SOURCE: need to empty reliance 501 hot water heater how?
1) Shut the breaker off to it at the panel. 2) Hook a hose up to it (the bottom has a drain). 3) Close the valve to the water heater (on the cold water supply). 4) Open drain on the bottom of water heater. 5) Open the relief valve to allow air into the tank (it won't drain otherwise - think if you put your finger on one end of a straw - the liquid stays in until you let go). Why are you draining it by the way?
Posted on Jan 31, 2010
heatman101
  • 43501 Answers
SOURCE: i have a reliance 501
To change a gas hot water heater thermostat you will need to first buy a new gas valve for your hot water heater. The gas vaive and the thermostat are integrated into one unit.
To replace the thermostat on a gas hot water heater you must follow these procedures....
1. Turn off the incoming water and drain the water heater.
2. remove the pilot tube, the burner gas tube and the thermocouple from the gas valve. Turn off the gas line and remove from the gas valve.
3. get a pump pliers or a wrench in behind the gas valve and turn the whole assembly CCW to remove it from the tank.
4. After appliying pipe dope or tape to the new gas valve threads, turn the new gas valve into the tank by turning in a CW direction. Be careful not to damage the small wires to the ECO. They are the little red wires on the back. If you break them the assembly is irreparably damaged.
5. reinstall the gas line, thermocouple, burner tube, and the pilot tube to the gas valve.
6. Fill tank with water. Make sure to open a hot water faucet and purge all air from the tank.
7. Check for leaks where the gas line hooks up with soapy water.
8. Relight pilot light and check operation.
9. Set the new temperature setting to a medium setting and then adjust the temperature to your likeing from there and adequate time for heating completely.
heatman101
Posted on Feb 25, 2011
Where do I get a Propane to natural gas conversion kit for a Reliance 640LORT water heater
You should be able to get this at any home improvement store or a Tractor Supply Store. Another source would be somewhere like Praxair or whoever your local propane gas refill place is.
Feb 14, 2015 | Reliance Water Heaters
Air filter on bottom of hot water heater is clogged
Copy following link with general cleaning instructions for each brand:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Reliance/ AO Smith can be cleaned with feather duster and compressed air.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Mar 23, 2013 | Reliance & 30 Gal LP Gas Water Heater
Reliance 606 propane pilot won't stay on when i begin to turn on.its like ite not getting the message or signal,HELP PLEASE
1) Reliance is AO Smith-American, and air intake screen located on bottom of water heater. Clean air intake. Replace thermocouple. First two digits of serial number are year of manufacture.
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
http://waterheatertimer.org/How-to-replace-thermocouple.html
2) Add comment and say what you tried so far.
Include age of water heater.
Jan 05, 2013 | Reliance & LP Gas Water Heater Control
Need gas control unit& burner for water heater 40 gallon
Reliance is AO Smith.
Each gas control has identifying information on side of gas control valve. Make sure you order for NG natural gas or LP propane gas, since these are two different gas control valves.
Google search the gas control number and results will show.
Copy following links for more help:
http://waterheatertimer.org/pdf/How-to-replace-water-heater-gas-valve.pdf
Sep 03, 2012 | Reliance Water Heaters
We have a reliance 501 propane water heater model # 5 40 porto manufactured in 1991 We have had build up of rust in the pipes from the tank to our dishwasher and sink. Our dishwasher is not cleaning...
After 18 years there will be a build up . you could flush the tank and see what comes out, replace the line to the sink and dishwasher , then you can decide if you want to replace the tank .Which sounds like it will need to be done .
May 13, 2017 | Water Heaters
How do you change a propane control valve on a reliance hot water heater?
You will have to drain the water from the tank until it is below the level of the control. Hook up a hose to the drain valve near the tank bottom and run it to a floor drain, a large bucket or to the outside, Open it and also open the T & P valve on the side of the tank so it will flow faster. Then turn off the gas at the shut off valve and disconnect the 3 tubes coming from the burner. To untwist the control from the tank, you will need to thread a 1/2" nipple that is 6"-12" long for leverage into the inlet of the control and spin it off the tank in a counter clockwise direction. Use pipe dope or Teflon tape to seal the threads on the new control before you thread it on and rehook everything back up. Check for leaks on all gas connections with a soap solution before relighting the water heater.
Why are you replacing the control? If you are having pilot outages, this will not solve the problem. This brand of water heater has other issues. If you still have your owner's manual, you will need to call the manufacturer. They will need the model # & serial #. This particular brand has a fine mesh filter screen on the bottom (below the burner) that gets clogged and causes irregular pilot outages. They have a recall in which they will send you a new burner assembly with a reset switch built-in to it. They will send it to you for free, but you will need to hire your local propane co (at your expense) to install it and also clean the filter while they have the burner assembly out. Good luck. Douglas
Dec 21, 2010 | Reliance & LP Gas Water Heater Control
My pilot light goes out irregularly it's a reliance 606 propane water heater
Oct 01, 2010 | Reliance Water Heater #6-50-DJRT 50GAL...
Model 640HORT Reliance 606 40 gal LPgas came to cabin, water cold, lit; ran for 4 hours, flame went out, burner won't come on.
It does sound like a weak pilot thermocouple. Change the thermocouple first. Make sure you have an adequate supply of propane serving the water heater. If it still works for a while then completely shuts down, you will need to replace the control valve. Call Reliance and see if the unit is still under warranty, you may be able to get free parts.
Sep 11, 2010 | Reliance & LP Gas Water Heater Control
Not very hot
don't use it. now see it to any exspert
Mar 04, 2010 | RELIANCE ELECTRIC WATER HEATER
Apr 20, 2009 | Water Heaters
Water Heaters Logo
50 people viewed this question
Top Reliance Water Heaters Experts
Mack Baxter
Gil Shultz
rickb63
Are you a Reliance Water Heater Expert? Answer questions, earn points and help others
