Question about Eureka Vacuums
Change power switch eureka as1000
Change power switch
Best place to get a eureka vacuum techical manual. my eureka lost power am unable to turn on.
ofen it is the power switch is stuffed you may need to replace it... some vacums with foot switches to turn on and off get broken due to people standing on them to hard etc.... it bends the contacts in the switch... hope this helps
Feb 26, 2011 | Eureka Altima Upright Vacuum Model 2996AVS...
Changing belt for a eureka power plus 4703D
I have listed below a link to the owners manual which has instructions on how to change the belt and a link to the belts you need. Hope it helps!
Eureka 4703D Owner's Guide
Eureka 4703D Replacement Belts
Nov 03, 2009 | Vacuums
Handle gets very hot on my 5892BVZ vac
i have a 1998 chrysler sebring convertible stop starting by the ignition switch,we changed starter,ignition switch been changed,changed starter relay,trace the wire haven't found a broke are burned place in it,checked igniton fuse its good,didn't see a linkable fuse
Sep 23, 2009 | Eureka 5892AVZ Bagless Upright Cyclonic...
Eureka 6993 power switch will not stay on
Did you eer figure out the solution? Mine is doing the same thing...
Jun 23, 2009 | Eureka 6993 Canister Vacuum
My vacuum (Eureka Bagless Model 2961 AVZ) will not START!
Had exactly the same problem with my upright Eureka Model 5893 bagless. Eventually, the handle would get hot, and finally it just quit. When handle was disassembled, the wires were melted and it was toast. Ordered a switch after talking to several repair men. Talked to Eureka, too, and they were absolutely no help. Cheap wiring and switch made in China. Good luck trying to find a switch. vacuum-depot.com has switches, so you might try there, but make sure you get the 3-prong switch (same switch used on Eureka's Genesis). It is Part #27871.
Jun 11, 2009 | Eureka 2961AVZ Bagless Upright Vacuum
My Eureka Whirlwind vacuum on-off switch won't turn off
the power switch is bad. go to your local hardware store and buy a new power switch and replace it.
Mar 23, 2009 | Eureka Whirlwind Litespeed 5740 Bagless...
Change vacuum belt
This unit is not designed for the consumer to change the belt. Eureka recommends you to take it to a service station to have this done
Dec 19, 2008 | Eureka 402A Bagless Upright Vacuum
Eureka Boss Smart Vac 4870 evidentally overheated. Allowed unit to cool and observed a spark/smoke at outlet when it was replugged into the power outlet. Unit will not power up now. Circuit breakers in...
The wires leading to the switch inside my Eureka 4870 are fried...black and melted. Don't know why that happened, but it may be what is happening to the others listed on this site as well.
Dec 18, 2008 | Vacuums
Eureka 2961AVZ
http://geeksquad.fixya.com/ThreadView.aspx?prdid=538511&thid=720558
Eureka 2961AVZ
Posted by Joanschmuck on Jun 29, 2008
Will not start ...I get a momentary flicker of power about every 3rd or 4th time that I flick on the power switch. Outlet is fine / Plug looks good / cord looks good / I see no obstructions ........Would appreciate any helpful thoughts ....Trying to get Mom's Eureka 2961AVZ back up and running. Thanks
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It sounds to me that you may have a bad switch or the worst scenario would be a bad motor and or armature, and the armature is almost the cost of the new motor, so I would replace the motor, but check the switch and the cord because sometimes the cord looks good but there might be broken wires inside the cord that you can’t see. If the vacuum is less than one year old the motor would be covered under the factory warranty if one year and maybe the switch as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.eureka.com Customer Service
Customer Service Dept 1-800-282-2886
Electrolux Home Care Products
P.O. Box 3900
Peoria. IL 61612
Hours of Operation
Monday thru Friday 8:00am to 7:30pm CST
Saturday and Sunday 10:00am to 6:30pm CST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 29, 2008 | Eureka 2961AVZ Bagless Upright Vacuum
Vacuums Logo
123 people viewed this question
Top Eureka Vacuums Experts
Jim Parker
Jim Parker
charlesjo336
Level 1 Expert
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
