Interesting problem... I picked this TV up from a neighbor's house...he said a repair guy wanted to charge him $100 to repair it. He decided to chunk it, so I decided to take it & see if I could fix it myself. So here's the problem: When I turn it on, it clicks & powers on...however, no picture or sound. After about 10 seconds or so, it shuts off & the power light blinks twice, then a long blink afterwards. On a google search, I got this solution for a similar problem: http://www.freelists.org/archives/techassist/12-2004/msg00318.html However, I realize that, like beep codes on a computer POST, different light codes mean different things. So what's my solution?
hmmm...I don't know where to find it...a link to an online supplier would be great...I'm in san antonio, so that california number does me no good. I appreciate all you help. :)hmmm...I don't know where to find it...a link to an online supplier would be great...I'm in san antonio, so that california number does me no good. I appreciate all you help. :)
nevermind...I found a site for the kit. Thanks a lot!
AnonymousDec 18, 2007
I have the same problem and can't find the kit to fix it. Where did you find horiz driver kit # 483513057673??I have the same problem and can't find the kit to fix it. Where did you find horiz driver kit # 483513057673??
AnonymousJun 19, 2008
My Philips 32PT5441/37 32" TV just broke.
The sound comes on for 2 secunds and then it just blinking green.
Thanks JohanMy Philips 32PT5441/37 32" TV just broke.
Thanks Johan
You can't post conmments that contain an email address.
Andrews Electronics (661) 257-7700 or on-line or any supplier
of Philips ( NAP ) parts...............................T.Andrews Electronics (661) 257-7700 or on-line or any supplier
I assume you're asking about a cordless phone? Cordless handsets need to be "registered" to a particular base station. You wouldn't want your handset responding to your neighbor's calls, would you? Would you want your neighbor picking up your calls?
The manual will give you instructions on registering your handset to the base. If you still have trouble, please repost your question, specifying the make and model of your phone.
You would need to figure out if it is a problem inside the cylinder or with something like the crank-cam sensor firing the coil. I would change the plug again to see if it works for a few days. Could be a problem with the fuel injector or a vac leak if the plug is firing but no power from that cylinder.
The Antenna may be in a weak signal area heres a quick cheap fix Get a Freeview Box and connect it via SCART LEAD to your tv, if the Box picks up a good signal then your tuner may be very weak.. You may want to try a BOOSTER to the TV first, and if that fails go with an external freeview. My neighbor has a 42 and the freeview box WITHOUT an antenna attached resolves all the channels..so give that a try. I have a goodmans too with a slow tuner and I have to retune it sometimes even though it gets a good signal from the antenna. I will be getting an external tuner freeveiw box.
You should be able to find a local repair shop or person to fix it. Try craigslist.
I usually charge $75-100 to fix that problem, but you can go the diy approach for about $10 if you've got a decent soldering iron and 1-2 hours to kill.
It's not hard but it does take time and a steady hand. You could end up damaging the motherboard further...so be careful.
Check youtube and google for guides, I've never used a guide before myself because I'm cool like that but it might be a good idea to see it so you know what you're getting yourself into.
If its a 100.00 to clean it your ok, Be up front with him if the 100.00 includes an estimate your ok again. Find out what his max labor is tv servicer's don't get paid by the hour they get paid by the job.
If by separating you mean the colors are not lining up, this means that the convergence amplifiers are failing. If this is the case you will need to have the amplifiers replaced, this is not at all expensive. The Technician will most likely charge about $100-$250 for the house call and $250 for the actual job itself. This will total $350-$500 at the most. I would suggest getting this fix, unless you are looking for an excuse to upgrade your TV. If you decide to buy a new TV you can give your TV to a local vocational high school, for use in helping teach TV repair. In any event it is worth fixing.
i have this tv it has screen broging
i want fix screen but what i do ?
my mail is [email protected] VIZIO TV MODEL # AND ALL DATA
MODEL NO VIZIOVX32L
HDTV 10A 100-240V-1.5A 60/50HZ
SERIAL NO LSSABBH 1919067
MFG. DATE MY 2007
poless send me enformation
where can I get this kit?
Thanks Johan
