Question about Cozy Heating & Cooling
Cdv251 Does this heater need to be cleaned
    Top Expert:
  • Cozy Master
  • 43,020 Answers
Most any heater needs cleaning of some sort .
Posted on Jan 08, 2015
Why is my flow low through my heater
pump basket may need to be cleaned out...sand filter may need to be backwashed....cartridge filter may need to be cleaned out
May 06, 2014 | Hayward H-series Electronic Gas Pool...
How to clean amish heaters
I was told my Amish heater only needed taken apart and cleaned to make it work nicely again, So is there any instructions that I can look at while I do this so that I don't mess anything up inside the unit ?
Oct 30, 2012 | Heating & Cooling
I have a model 640 Reliance water heater. SN # A07A150454 M,F, 01/30/2007. About 3 months ago the water started getting cooler, then won't start. I turn the control up, then it starts, but the...
I believe 640 is typical tank-type atmospheric-vented gas water heater.
Gas water heater problems can get complicated. New heater sells for $350 at local box store.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
If thermostat is not controlling temperature accurately, then (1) gas control needs replacement (2) water heater has sediment build-up (3) combustion and burner parts need cleaning. (4) All three things above, plus additional causes such as bad venting or not enough combustion air.
Usually recommended that plumber replace gas control valve thermostat:
See typical tank-type thermostats:
http://waterheatertimer.org/images/Typical-gas-valve-500.jpg
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html
Clean sediment out of tank:
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Clean combustion chamber and burner parts and troublehoot venting and air supply:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/images/Clean-burner-300.jpg
http://waterheatertimer.org/pdf/Bosch_Ventilating_tight_houses.pdf
Aug 07, 2011 | Reliance Water Heaters
Reem power vent 2 will not stay lite electric starter starts but will not lite
First suspect is dirty combustion parts and air in gas line.
Gas water heater combustion chamber and parts need to be cleaned once a year.
Following link has images and 2 pdfs about cleaning gas water heater.
http://waterheatertimer.org/How-to-install-gas-water-heater.html#clean
Jun 17, 2011 | Water Heaters
Flame wont go high so its not heating up the house the heater is about 25 years old its a round heater with a flue sticks out of the corner
the heater needs servicing,= what is it gas fed,so jets need cleaning,oil feed,filter cleaned or changed depending on type
Jul 07, 2010 | Heating & Cooling
Fumes
WITH PROPANE THEY NEED CLEAN AIR, I HAVE THIS PROBLEM WHEN I USE THEM IN A CRAWL SPACE, TRY TO PUT IT SOME PLACE WHERE IT CAN GET CLEAN AIR, GOOD LUCK PLEASE LEAVE FEED BACK IF THIS WORKS
Jan 14, 2010 | Desa International Reddy Heater R40 40,000...
Raypack gas pool heater displays"clean filter/strainer" when I turn it on
There is not enough system pressure to close the heaters pressure switch so the heater will not fire. Assuming your pump is on and any valves in your pipes are set correctly it means something is restricing water flow too much and needs to be cleaned to fix your flow rate and allow the heater to fire.
Start at the skimmer(s) baskets and then the pump strainer basket and finally clean your filter. If sand, backwash it. If cartridge or DE clean according to your manufacturers direction. In some cases cleaning a cartridge filter will no longer satisfy heater pressure requirements meaning you will need to replace the element.
Nov 11, 2009 | Raypak Free Hydraulic Lift Gate Delivery -...
Heater makes my smoke detector go off.....
Gary, it sounds like the heater needs to be cleaned. Sounds like the heat exchanger is full of dirt bunny's.If you have a manual it will tell you how and what all needs cleaned. If you do not have manual i would call a heating/cooling repair company and have them come out and clean and inspect it. Then you can watch how the tech. does it then you will know how it is done if you want to do it next time. The heater should be cleaned every year they say but you might be able to go every other year
Jan 17, 2009 | Vanguard International Blue Flame - Large...
Heating & Cooling Logo
48 people viewed this question
Top Cozy Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
jdthefixer
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
