Question about Autodesk AutoCAD Computers & Internet
PRETOOL HAS NOT BEEN RUN SINCE BUILD
UNABLE TO INITIALIZE ADLM. ERROR CODE 6
2 Suggested Answers
  • 99 Answers
SOURCE: unable to initialize adlm at windows vista
use Autocad in windows 7 is great. vista is **** and doesnot support most of problems. i use autocad 2010 in windows 7 with no problem.......
Posted on Nov 05, 2009
Unable to clean 46. this error display in lcd of brother dcp585cw printer. how to solve me this problem.
Machine Error 46 - Purged Ink Box Full MFC620CN/420CN/410CN/210C and FAX2440C
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An "initial purge", for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an "Unable to Clean" external message and will be unable to use the printer. The "Unable to Clean" external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Resetting purge counter MFC620CN/420CN/410CN/210C and FAX2440C
1) Enter machine maintenance mode (on MFC210C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
FAX models with numerical keypads: Press the Menu/Set, *, 2, 8, 6 and 4 keys within two seconds. (if you fail to complete the correct key sequence within two seconds, press the Stop key to try again).
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the "up arrow" key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine's log information list (function code 80).
3) Press the Black Start key several times to scroll through the log information list to reach the purge counter. The purge counter is the 25th item in the list.
4) Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
5) Press the Stop/Exit key to return to the initial stage of the maintenance mode.
6) Press the 9 key twice to return to the standby state.
Jun 26, 2011 | Brother DCP585cw AllInOne InkJet Printer
Unable to initialize adlm
Unable to initialize adlm error after uninstalling Service Pack for 2014...
Solution:
There are 2 solutions available, either of them can help you to resolve the license issue.
Option #1:
Uninstall and reinstall the Service Pack (any of the Service Pack if you have more than one) that you want to keep. This will restore the mismatched file versions to the correct one.
Option #2:
Copy and replace files manually
1. Download the LicenseCrash.zip attachment below, unzip to your local drive, and then unzip the 32-bit or 64-bit package according to your platform.
2. Unzip the package
3. Close all running Autodesk products
4. Stop the FlexNet Licensing Service from the Task Manager:
  • Click Start ? Run
  • Type taskmgr and the Windows Task Manager will open.
  • In the Windows Task Manager, on the Services Tab, right-click FlexNet Licensing Service ? Stop Service.
5. Replace the following 5 files from the unzipped folder into the following locations:
a. Replace adlmact_libFNP.dll and adlmact.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
b. Replace adlmint_libFNP.dll and adlmint.dll with the ones (version 11.11.0.3 and 7.0.51.100) in the unzipped folder.
Note: Most products put this file under the root folder of "\Program Files\Autodesk\#Product name#\" i.e. AutoCAD2014, but some other products put this file under subfolder, i.e. Inventor /Alias in \Program Files\Autodesk\#Product name#\Bin folder.
c. Confirm and if necessary replace FNPLicensingService.exe with the one in the unzipped folder to avoid file version incompatible issue.
6. Launch your products.
Mar 20, 2011 | Autodesk AutoCAD 2010
It says "unable to clean"
Dec 20, 2010 | Brother MFC-5840CN All-In-One InkJet...
AutoCAD 2010 won't start after reinstall.
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD-2010-does-not-start.html
Issue:
When you try to start AutoCAD, you briefly see the splash screen and the program does not start.
Solution:
This behaviour can be caused by corrupted license information.
Please check if there are any errors listed in the ACD2010ENGAdlm.log file in the folder:
C:\Documents and Settings\All Users\Application Data\Autodesk\Adlm (Windows XP)
or
C:\ProgramData\Autodesk\ADLM (Windows Vista) (Please note the file name may be slightly different for localized product versions, for example for the German version the file name is ACD2010-DEUAdlm.log)
If the log file shows errors regarding the product information table file, for example "Unable to locate the Product Information Table File" or "Product Information Table file is not found", you will need to:
  1. Uninstall all installed 2010 products
  2. Delete the ADLM folder mentioned above, and
  3. Reinstall the products
Oct 14, 2010 | Autodesk AutoCAD 2010
Unable to clean code error 46
All you need to do is to reset the purge counter
To reset purge counter
1) Enter machine maintenance mode (on MFC240C all four photo/copy/fax/scan lights flash in maintenance mode). Care is needed in maintenance mode, otherwise critical settings may be inadvertently corrupted.
Other (non-FAX) models: Press the Menu/Set and Black Start keys. Next press the “up arrow” key four times to enter the maintenance mode).
2) Press the 8 then 0 keys in the initial stage of the maintenance mode to call up the machine’s log information list (function code 80).
Feb 03, 2010 | Brother Office Equipment & Supplies
Unable to initialize adlm at windows vista
Nov 05, 2009 | Autodesk AutoCAD 2010
Computers & Internet Logo
125 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
