Question about Disney DT1350-C 13" TV
How fix protected program by tv y7 - Disney DT1350-C 13" TV
MESSAGE THAT PROTECTED PROGRAM TV-PG HOW DO I FIX THIS
You can't. There's a chip inside that prevents a copyrighted program form being recorded.
Oct 30, 2013 | RCA (DTA800B1) Video Converter
Software webcam Y7
try here may solve your problem
www.alibaba.com/showroom/free-driver-usb-webcam-y7.html
Aug 15, 2012 | Computers & Internet
Tv as protected program tv-y7 message when turned on, cna change channels but goes right back to that message how do i correct this
In the Menu of the TV, there should be a parental ratings feature. You should be able to adjust it there! Good luck!
Oct 09, 2010 | Durabrand DWT1304 13" TV
I used the fn then f4 button to mute my panasonic cf-y7
When booted into windows just hit fn and f4 again. That should unmute it. You can also look at the toolbar at the bottowm right corner. You should see an icon that looks like a speaker. Right-click and check to see if mute is checked. If so just uncheck it.
Jan 29, 2010 | Panasonic Toughbook CF-Y7 PC Notebook
Hi, I bought a laptop from a lost and found auction which was for a charitable organization. The operating system is password protected. It doesn't even allow me to format and re-install when I use a...
Does it have floppy disk drive? If so, try creating a boot disk. Boot from the floppy, then format or re-partition. Then boot from XP CD to install XP.
Regards, dC
Dec 15, 2008 | Computers & Internet
Tv/VCR Combo Sylvania #SRC 21134 is from the darkside!
You will have to get the original remote. Go to remotes.com, we order from them all the time. Take the replacement because the original is NLA.
Jun 13, 2008 | Sylvania SRC22134 13 in. TV/VCR Combo
DWT1304 13''
Hi - Below is a link for your manual. You can download it and it will show you how to change it. If this solves your problem PLEASE rate this as fixed.
http://www.funai-corp.com/6pdf/om/DWT1304.pdf
Jeff
May 16, 2008 | Durabrand DWT1304 13" TV
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
Tv vcr
Since you haven't gotten a response shown here, I have comcast cable and a Daewoo. I am having the same issue and confirmed that all locks are turned off through the digital cable. If you didn't set the parental code, try defaults such as 2211 (which worked on my tv to turn off the parental control) and 3308.
May 27, 2007 | Daewoo DVQ19H1FC 19 in. Combo
Disney DT1350-C 13" TV Logo
16 people viewed this question
Top Disney Televison & Video Experts
Jaime Hernandez
Chris Goulet
Are you a Disney Televison and Video Expert? Answer questions, earn points and help others
