Lg washer .upside down f3 error code - Washing Machines
  • 489 Answers
SOURCE: LG wm1814cw washer
No, there is no access to the drain pump other than by removing the front panel to get to it.  It is a job that can be done but you will need to spend some time to disassemble the machine to get to it.
Posted on Sep 29, 2008
omaharox
  • 166 Answers
SOURCE: My LG WM-2277HW front load washer has an error
This is a water overfill condition and many things can be causing the issue.
Leaking water valve.
Plugged water lvl. switch hose.
Problem with the main computer.
A service call may be needed.
Posted on Jan 20, 2010
SOURCE: My washer is blinking upside down F and E. Manual
It is actually a TE and should be the thermistor Part#
1268202
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: repeated error code for LG 2277. upside down F and then E.
LE indicates a fault with the motor on the appliance.
LG suggest you switch off, wait for a minute, unplug the appliance.
Wait 15 minutes then plug it back in again.
Try the machine again.
If it's still faulty, you can try changing the Hall Sensor in the motor, this can sometimes cure the problem.
Unplug the machine and remove the rear cover. There are 4 Philips head screws. Take them out and remove the rear cover.
You should now see the rear of the motor, which is mounted to the back of the drum.
In the middle is a large bolt which holds the stator cover.
You'll need a 17mm socket and a ratchet to remove this bolt.
Remove the stator cover and place aside.
Toward the bottom-left, you will see a couple of wire bunches held to the motor by three screws. One holds a metal bracket, one actually holds a ground wire, and the last is through a plastic bracket toward the bottom. Remove these three screws and don't lose them.
Through the motor there are 6 bolts holding it onto the back of the drum assembly.
You'll need a 10mm socket and ratchet to remove them.
You will now have the motor off the back of the drum.
Disconnect the two wire harnesses from the motor.
Looking at the surface of this motor that was facing the DRUM (not the outside), you'll see two small pieces clipped onto it, toward the bottom.
The sensor you are looking to replace is the one that looks like a kitchen magnet.
It is attached by small clips. You'll see how it goes on. It's easy to remove.
Go to google and search for part number 6501KW2002A.
This will bring up an LG sensor assembly.
Double check with the supplier that this is the sensor for your appliance.
When you receive the sensor, simply reverse steps 1 through 5.
Once re assembled, try the machine again.
If still the same after this you'll need to replace the motor and/or control board.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
richroth
  • 9472 Answers
SOURCE: LG front load washer is gettign an error code of
FE means overflow condition. That means sand or trash has gotten into the tube going from tub to water level switch. So find that hose and blow it out. Remove the standing water and retry.
Posted on Dec 28, 2010
LG WT1701CW error code LE. Fault code 513,7. What is wrong?
The LE error or fault code indicates that the washer motor is either overheating or has lost connection to the motor control circuit board. Turn off the machine for 30 minutes to let the motor cool down. Then, restart the washer. If the code comes back immediately the motor is not likely to be at fault and so you should check the wiring from the motor to the motor control board. Also, check the wiring and condition of the rotor position sensor, also called a HALL sensor. If the code doesn't come back on immediately, but returns after the washer has run for a while, the motor stator may be defective.
Jun 23, 2015 | LG Washing Machines
LG Tromm wm1815cs front loader washer error message 1e. Have cleaned filters, checked hoses,and supply source, I still get message,
R u sure it is not an (LE) error code. Kinda looks like an upside down (F)? Very common on older LG washers. Indicates a hall sensor/ motor position sensor error.
Mar 22, 2015 | LG Washing Machines
How do I trouble shoot the error code on my LG Tromm WM0642HW, it is an upside down F and E.
could the upside down F be a lower case t. If so the error code is tE and you have a heating problem.
Jan 25, 2015 | LG Washing Machines
LG WM2277H error code upside down f E
You will readily find this out by booking a Service Call to have the manufacturers authorised agent take a look at your machine.
You see, this may not be the only problem with your machine. Get the benefit of knowing eyes and minds to give you real peace of mind with a full check up for the cost of a call out.
Poppa
http://www.cdbaby.com/cd/poppamadison
Mar 07, 2012 | LG WM2277H Front Load Washer
I have a code that is not list in the manual. Upside down F and E
That is a thermister error. Replace the thermister, located at the bottom front of the tub. (It is difficult to do without taking the washer's front off)
Jan 17, 2011 | LG WM-2077C Front Load Washer
1268202
May 08, 2010 | LG WM227HW Front Load Stackable Washing...
My LG WM-2277HW front load washer has an error code of upside down "F" and E. Will not run at all. Manual says to call service.
Jan 18, 2010 | LG WM-2277HW Front Load Washer
Error code upside fe
But U still haven't told us specifically what the issue is with the device. So how can anyone help you?!?!?!?!?!
Sep 12, 2017 | LG Washing Machines
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
