Question about SATO Office Equipment & Supplies
How do you make adjustment to the print on lable
How do I align my Citizen CLP 7202e Lable printer print head to align with the lables? Currently it starts printing low on the lable and thus the last 1-2 lines print over onto the next lable
Adjust vertical offset in printer properties. If that doesn't fix it, adjust it under "advanced". Or... you can set the offset in the printer itself. Hold down the left two buttons at the same time. Cycle through the settings until you get to vertical offset.
Apr 19, 2015 | Citizen CLP-7202e Thermal Printer
My ricoh printer refuses to print the lables.
you had to adjust setting between the computer & the printer
then always run the test page......if test page normal then the labels will be normally print......dear heather darling
Sep 13, 2013 | Ricoh Aficio BP20N Laser Printer
Epson R380 CD Printing is almost 3/8" off! How do I align it to center image or print on a CD? There is a setting to adjust up to 2mm...not near enough. It used to line up perfect but I don't know...
If you're using a direct printable disc. Settings should be 24mm inner and 117mm outer. Also change the "Adjust print position" to 0.1mm up and 0.1mm left... this should center you. If you're using the stickers label outer should be 117mm but the inner you will have to adjust depending on the lable inner diameter.
Nov 18, 2009 | Epson Stylus R380 InkJet Photo Printer
Printer does not print
hold down the feed button until both light flash off and let go. This will reset the printer. This should stop it from feeding multiple labels.
Apr 27, 2009 | Argox OS-203 Thermal Label Printer
Dell 922 printer will not print on the lines of lables
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Dec 08, 2008 | Dell 922 All-In-One InkJet Printer
Printing CD labels , can not get it to line up stright.
I have the exact problem with my HP Deskjet D2360...Done all adjustments, doesn't print in the outline of the label...help
Nov 09, 2008 | HP PSC 1510 All-In-One InkJet Printer
Printing Labels
The MPF is simply the "Manual Paper Feed".
Your printer is set by default that the MPF paper type is "plain paper". Since you are telling the printer that you are trying to print lables, the printer is simply telling you that you need to load the MPF with lables.
If you say "ok", the printer sould continue and print the lables.
If you only print lables, the you can change the default paper for the MPF tray to "lables", and then you will no longer be prompted to load the tray.
Sep 25, 2008 | Dell 5100cn Laser Printer
Z4m small labels
try the pause test if print ok in some and have problems with other lables, is possible the belt.
Apr 08, 2008 | Zebra Z4Mplus Label Printer
Set up
May be your problems can be solved doing a calibration. To do this, turn off the printer, press the feed key and turn on the printer. When the led flashes in red quickly release the feed key, the printer will start to calibrate and after the calibration will feed one label.
It is explained in the user manual.
Mar 17, 2008 | Toshiba B-SV4D Label Printer
Printing to memorex cd lable paper
the paper feeder cant grip the back side of the paper. It slip through the feeder and the positioning led control cant adjust the correct positioning for printing!
Try another brand of paper!
Jan 18, 2008 | Brother MultiFunction Center MFC-440CN...
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
mukhtar21 shaikh
mukhtar21 shaikh
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
