Question about Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor
My air compressor dosent turn on my cobra cjic 350
The air compressor will not turn on when you turn the power on
We relocated our Sullair 3700 about 30m from air receiver, due to excess dust. Now the compressor never stops running, trips on high pressure yet the receiver is not achieving the pressure required
would say dust has done something to do with it
before you had time to move it
will need the compressor serviced
first ..in simple words
to replace the compressor pressure shut off /turn on valve
that should fix the pressure trip build up limit problem
and maybe a partial strip down to clean out the casing
if dust build up is noted
Oct 14, 2016 | Sullair 350 Air Compressor; Sullair...
My air compressor will not turn on
Your problem in the power supply.
so the power not connected to the drive motor, so that the motor cannot run. and cannot drive the compressor
Feb 11, 2014 | Cobra CJIC 350 900 Amp Jumpstarter...
Sullair compressor
check condition of air filters and dryer filters.
May 16, 2013 | Sullair 350 Air Compressor; Sullair...
1992 Dodge Dakota 2wd 3.9L V6 Air conditioning/Heater dosent blow? when i turn the air or the heat on i can hear the compressor kick on but it dosen't blow cold or hot? any help would be appreciated
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
Nov 29, 2011 | 1992 Dodge Dakota
When I plug the unit into the AC charger I hear a
w+pnt0gwwvrvgaaaabjru5erkjggga=
I would check battery, it may not be good, If you need battery look online it will be less expensive than buying from mfg.
Oct 27, 2017 | Cobra Electronics Cobra Jumpstarter Air...
Just got replica ac cobra 5.7L 350 big block
5.7l 350 isn't a big block (i believe) this is a small block - still nice motor though.
As for oil, Cobra guys on www.cobraclub.com would say Valvoline Vr1 20w/50 mineral oil
rgds
Gary
May 09, 2010 | Chevrolet Classic Cars & Trucks
Cobra 29 chrome
you could have a bad soilder but probably your voltage regulator went out.
Dec 15, 2009 | Cobra 29 LTD CB Radio
Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor Logo
142 people viewed this question
Top Cobra Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cobra Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
