Question about Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor
My air compressor wont work - Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor
Testors Blue Mini Modelers Airbrush Compressor
Air compressors are rated for a maximum pressure and maximum output flow. Your description implies more air is going out of the compressor than it's designed flow rate. Check for a major leak at hose fittings or around the compressor. If this is an old unit, a compressor gasket could be cracked or broken.
May 31, 2014 | Ingersoll Rand - Rand Type - 30...
Motor Wont Work on Air Compressor
What do you mean that it wont work?
Jul 16, 2013 | Coleman Air Tools & Compressors
Air compressor wont produce more than 60psi
clean the one way cheak valve on the head of the air compresser motor whier the big line comes out and goes to the tank.
Sep 09, 2012 | Coleman Powermate 27 Gallon Air Compressor
Ac compressor wont engage on its own
there is a low pressure shut off switch to prevent compressor damage charge the system before testing anything else
Jul 10, 2012 | 1997 Chrysler Concorde
Air compressor wont start
For air compressor not working,click the link below :---http://repairhelpcenter.blogspot.com/2012/01/air-compressor-wont-start.html
-----------Thanks.
Jan 20, 2012 | Air Tools & Compressors
MY COMPRESSOR JUST KEEPS RUNNING AND WONT REACH MAXIMUM PRESSURE AND SHUT OFF. I CAN SHOOT NAILS BUT IT WONT SHUT OFF DOWN.
The compressor itself sound like it is bad. You might see what it cost to repair it. It might be cheaper to get another one...keep in mind if you do a lot of work with it that a 2 stage compressor will cool better and you won't have this type of problem again.
Oct 19, 2009 | Craftsman 1 Hp, 4 Gal. Air Compressor
I have a 33g craftsmans air compressor oilless
have a 26 gallon air compressor , changed regulator switch but it still wont shut off
Feb 22, 2009 | Craftsman Air Tools & Compressors
Compressor keep running in off position
you could have a relay or contactor inside the unit welded closed, therefore compressor will keep operating when unit is off. replace compressor contactor.
Feb 09, 2009 | GE Zoneline AZ55H07D Air Conditioner
Air conditioner wont cool
the compressor has a capacitor that helps to start the compressor if the compressor does not reach the speed required to jump from the start coil to te continum work in about 10 sec the termic protector disconect the compressor for about 5 minutes but the blower or fan does work just blowing the air and that is not cold
Dec 31, 2007 | Heating & Cooling
WINDOW AIR CONDITIONER_WHIRLPOOL
Did you recharge the refrigerant gas? If it is not pressurised the the compressor wont work.
Oct 06, 2007 | Heating & Cooling
Cobra CJIC 350 900 Amp Jumpstarter Powerpack with Air Compressor Logo
121 people viewed this question
Top Cobra Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Cobra Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
