Question about Panasonic Vacuums
Vacuum shut off vacuuming
Have to unplug to turn off
SOURCE: Westinghouse Unplugged Vacuum Turns off after 5 Seconds.
If both batteries are behaving the same way then this is probably a charger problem. When you insert the battery pack into the charger does the 'charging' light blink for 30 minutes (fast charge) then go steady? I noticed that one of my batteries was causing the light to come on steady immediately I inserted it into the charger. When I tried to use the battery pack I got the same problem everyone else is seeing, i.e. vacuum cleaner shuts off in less than a minute, so I conclude that when the charging light is on steady then the battery is not being charged.
If the charging light does not blink when you insert the battery (i.e. comes on steady or not at all), try removing the battery and re-inserting it into the charger.
Try a conditioning cycle on your battery packs. To do this:
* Insert the battery pack into the charger
* Before the charging light lights press the 'condition' button located just above the charging light.
* The 'conditioning' light should blink. This is a light which does not normally illuminate, and it is located below the condition button and above the charging light. The charger fan will run quieter in this mode.
* Leave the battery pack in the charger for 24 hours while this cycle is taking place.
I'm not a service technician so perhaps someone else might like to post other solutions or corrections to this one.
Posted on Dec 27, 2008
ginko
  • 19396 Answers
SOURCE: vacuum will not shut off
Either the switch has a contact inside, or the wiring in the harness to motor are making contact.
This can be verified using a multimeter , preferably reading continuity (Ohms) on switch contacts, with power disconnected, that is safer than reading voltages.
This will tell if responsible is the switch or the wiring harness.
Posted on May 09, 2009
  • 3 Answers
SOURCE: Power cut off after handle was dropped on floor while vacuuming
connections inside the handle came loose. happens to me all the time. take the handle apart and connect the wires back.
Posted on May 29, 2009
  • 70 Answers
SOURCE: My vacuum is constantly shutting itself off. When
It sounds like you have a blockage somewhere and the air is not passing over the motor to keep it cool. There is usually a thermostat mounted either on or near the motor. The blockage can be anywhere from the elbow ( the swivel part of your carpet sweeper if you have a canister vac) up thru the hose.If you have a canister vac, use a broom handle to push through the hose to clear the blockage. DO NOT ! use a coat hanger or anything that will cut or tare the hose. There are electrical wires in it that have 120 volts and causes quite a shock !
If you have an upright vac, start with the duct hose that comes from the part with the brush up to the hose and on to the main canister of the vac
If this does not work, take your vac to a reputable vac shop for repair. Hope this helps,
Joe
Posted on Nov 16, 2009
SOURCE: U5180-910 vacuum shuts off on own
WARNING, DO NOT BUY THE HOOVER PLATINUM SERIES:
Piece of junk, out of the box it shuts down after 20 seconds of operation. Also when you raise or lower it it will shut down,
What happened to Hoover???
My moms is Hoover 35 years old and still working even though I tell her to buy a new one year after year.
Maybe shes right.
Mike in WI
Posted on Nov 26, 2009
Turned off can not restart
it has an auto shut off feature if the motor gets to hot try unplugging it wait 30 mins then try again
Jun 02, 2013 | Eureka AirSpeed Pet Bag Upright Vacuum
Vacum shuts off
If you have BISSELL vacuum, some of our models have a brush reset. Here are the instructions to turn it back on:
If something becomes lodged in the foot and the
brush shuts off, turn the cleaner off and unplug
from the outlet. Remove the obstruction. The
brush will automatically reset when the cleaner
is plugged in and turned back on.
Additionally, you could have dirty filters that are activating a thermal protector switch that shuts the vacuum off if the motor becomes too hot. If this is the case unplug the vacuum, clean any filters, clogs, or obstructions and wait 30 minutes for the unit to cool. Then plug the unit in and it should work. I hope this helps.
May 03, 2012 | Vacuums
My vacuums power shut off while vacuuming
Its a good chance that your vacuum motor has either shorted out or become burnt out, this can happen after a few years of use. My only real suggestion, being what i would do in your situation, either contact dyson and try and get another motor, alternatively, contact a 2nd hand motor place, maybe a white goods store, and they may have a vacuum motor to suit as Dyson spare parts can be expensive. I hope this offers some assistance.
Nov 26, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Turns itself off
Your problem sounds electrical in nature. possibly the on/off switch. Take it to a reputable repair shop to determine the exact issue.
Oct 28, 2009 | Hoover Windtunnel Supreme U5280-900...
May 16, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Hi, vacuum clogged and motor shut down, how do I restart. thx
I'm assumeing you have remove the clog so unplug the machine an let it set of about an hour then plug it in and before you turn it on get it ready to vaccum then turn it on the overload switch should reset and it should run
Jan 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
The vacuum won't turn on
it could possibly be a short in the power cord. try replacing the power cord. if that doesn't fix it, it would probably be cheaper to buy a new vacuum cleaner.
Oct 12, 2008 | Bissell 6594 PowerForce Bagless Upright...
Dyson dc07 animal
This is from the Dyson web page:
Get expert help Thermal cut out Most Dyson vacuums have a built in safety system that stops the machine if it begins to overheat. This usually happens because the filter needs washing or your machine is blocked. If your machine turns off on its own, unplug it and leave it for at least an hour to cool down. Remember to check the filter and look for blockages before re-starting.
Any non- domestic use may adversely affect the filter performance such as vacuuming up plaster dust.
Sounds like your vacuum is overheating. Check the above.
Lou
Aug 30, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Vacuums Logo
Top Panasonic Vacuums Experts
Jim Parker
Jim Parker
Joseph Hoffmann
Are you a Panasonic Vacuum Expert? Answer questions, earn points and help others
