Question about Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008 Brand Booster Car Seat
Cannot adjust position
Recline
  • Maxi-Cosi Master
  • 1,629 Answers
Hi
Grip the carseat on the underside of the front lip, push the button in and lift the front to recline / push down to put in a more upright position.
Posted on Sep 14, 2014
The six way power seat on my 2005 suburban has an issue. When I turn the motor off and remove the key the motor goes to it's down and back position but continues to run. And it doesn't respond to the...
The first place to start would be to have the dealer or someother qualified repair shop , that has a professional scan tool read DTC'S - diagnostic trouble codes in the driver seat module ! The seat adjuster motors are controlled by the driver seat module through the adjuster motor control circuits. In an inactive state both of the motor control circuits are grounded within the driver seat module. In an active state the driver seat module switches the appropriate motor control circuit to battery positive voltage. The direction of the adjuster motor rotation is determined by which of the motor control circuits is switched to battery positive voltage while the other remains grounded. During adjuster motor operation the driver seat module also monitors the current flow through the motor control circuits.
DTC B1770, B1775, B1780, B1785, B1790, B1805, or B2415
B1825 , B1850, B1860, B1960, B2355, B2365, or B2375
B3962
Memory Seat System Components
The memory seat system consists of the following components:
• Power seat switch assembly
• Memory recall switch assembly
• Horizontal adjuster motor
• Front vertical adjuster motor
• Rear vertical adjuster motor
• Recline adjuster motor
• Driver seat module
• Driver door module
• SEAT 30A circuit breaker
Memory Seat System Description
Battery voltage is supplied to the driver seat module through the power seat circuit breaker. The driver seat module supplies the seat adjuster switch assembly with a battery positive reference voltage. While the seat adjuster switches are in an inactive state the switch contacts are closed to the adjuster switch ground circuit. When a seat adjuster switch is pressed to an active state the switch contact is closed to the reference voltage circuit. Battery voltage on a switch signal circuit indicates to the driver seat module the switch status is active. Each seat adjuster motor is controlled by the driver seat module through 2 motor control circuits. While the seat adjuster motors are in an inactive state the motor control circuits are closed to ground circuit contacts within the driver seat module. The driver seat module operates the seat adjuster motors by switching one of a motor's control circuits to battery voltage. The seat adjuster motors are bidirectional and the direction of adjuster motor rotation is determined by which of the adjuster motor control circuits is switched to battery voltage while the other remains grounded.
Memory Set/Recall Operation
The seat adjuster motors are equipped with internal position sensors. The adjuster motor position sensors are monitored by the driver seat module and are used to determine the seat position when storing or recalling memory settings. The horizontal, front vertical, and rear vertical adjuster motors use hall effect type position sensors. The hall effect position sensors are supplied with battery positive reference and ground circuits from the driver seat module. The position sensor signal circuits are supplied battery positive voltage through a resistor them monitored within the driver seat module. During adjuster motor operation the hall effect position sensor provides a single pulse for every revolution of the adjuster motor shaft. The driver seat module counts the pulses from the position sensor signal circuits to determine the adjuster motor positions when storing or recalling memory seat position settings. The recline adjuster motor is equipped with a potentiometer type position sensor. The recline motor position sensor is supplied with it's own 5-volt reference ground circuits from the driver seat module. The recline position sensor signal circuit is referenced from ground within the driver seat module. The signal voltage monitored by the driver seat module ranges from 0.39 - 4.58 volts and is determined by the wiper location on the resistor within the recline motor position sensor. The recline motor position sensor signal circuit voltage level is used by the driver seat module to determine the seat recline position when storing or recalling memory seat position settings.
The memory recall switch assembly on the driver's door provides inputs to the driver door module. Battery voltage is supplied to the memory
Feb 06, 2018 | Chevrolet Suburban Cars & Trucks
I have a cosco alpha omega elite car seat that i bought yesterday and i figured out how to put in in my car but i can't figure out how to take the base off for front facing.
Specs Released 3 years ago Restraint System 5-Point Safety Harness
Adjustable Harness Height Adjustable Harness Height
Car Seat Type Convertible
Additional Features Latch System
Adjustable Recline Positions Adjustable Recline Positions
Carry handle No Carry Handle
Head Protection With Headrest
MPN 22155HMR
Seating Direction Rear / Forward Facing
Stay-in Car Base No Detachable Base
UPC 044681223853
Weight Limit 5 - 100 lbs
Sep 08, 2010 | Cosco Alpha Omega Elite 5-Point 22-155
The invacare tilt wheel chair will not stay in the upright position . It gradually lays back
The release cable for the back is preventing the cylinder from locking. Adjust the cable just like you would adjust a bicycle hand brake. Adjust the cable so there is a quarter inch of play in the release lever. Look along the cable for a adjustment section.
Aug 24, 2010 | Invacare HTR5500 Tilt & Recline Wheelchair
Power seat won't recline
My 2006 honda accord drivers seat makes a clicking and grinding noise when i try to put it in the recline position.It will go back about halfway and stop and make this noise, does anyone have a suggestion?
May 05, 2009 | 2006 Honda Accord
How to fold a beby trend expedition single
TO FOLD STROLLER
• Close the canopy as described in the canopy section. Recline seat by releasing buckle as described in seatback positioning section.
• The stroller is folded by simultaneously pulling each trigger fold. . When the fold latches are released, the handle will begin to fall toward the floor. Release the fold buttons and press downward on the stroller handle until the stroller is completely folded. Secure the stroller in the folded position by hooking the fold latch, located on the right side of the stroller, over the rivet that protrudes from the frame.
CANOPY
* The canopy features a ratchet system that allows the canopy to be moved forward to block the sun or wind. To adjust the canopy’s position, push forward or backward on the canopy until the canopy is in the desired position. See figure 23.
SEATBACK POSITIONING
* The seat has a multiple position recline that is controlled by a strap and buckle assembly behind the seat. . To recline the seat, loosen the strap through the buckle and adjust to the required recline position. To place the seat back in the upright position, press upward on the seat back with one hand while pulling the strap through the buckle with the other. The strap will lock automatically.
http://www.babytrend.com/download/2007061021349109CT_instructions.pdf
Apr 28, 2009 | Baby Trend Expedition LE Jogger
How to change reclining position
Viewed from behind, there are two cords with pull tbs that are gathered together in the center of the seatback with a black plastic gather. These two cords are loosen or tightened to raise or lower the seat back recline position.
Mar 01, 2009 | Graco MetroLite Air 6116 Stroller
Reclining the stroller
you should be able to find the manual here
http://www.quinny.com/quinny/productdetail.aspx?id=3
Robert
Please rate the solution
Aug 21, 2008 | Quinny Buzz Jogger
Need to recline seat
On the back of the the seat back is a plastic tab connecting two lanyards/cords. These cords are used to adjust the seatback angle from the recline to full up-right position.
Nov 01, 2007 | Eddie Bauer C01078EBL Light Weight...
Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008 Brand Booster Car Seat Logo
158 people viewed this question
Top Maxi-Cosi Baby Gear Experts
ray gallant
Douglas Dinnebeil
Douglas Dinnebeil
Marc Cohen CPSTI
Are you a Maxi-Cosi Baby Gear Expert? Answer questions, earn points and help others
