Question about Sharp Televison & Video
Sharp LC-26QF3M HARD RESET
HARD RESET
How to factory reset my sharp aqous LC 55LE653U
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts.
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 02, 2017 | Sharp Televison & Video
How to factury reset lc-60le810uh sharp
There are two methods to reset. Hard reset and factory reset. To make it a hard reset unplug the set from the AC mains wall socket and reinsert after an hour or so. To make it a factory reset you have to enter it's service mode option. If you wish to get more details visit the site linked here. Service mode entry procedure of many popular brand sets are given. http://electronicshelopnline.blogspot.com/
Feb 25, 2017 | Sharp Televison & Video
How do I get into the service mode hard reset for sharp aquos LC-48LE551U
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Dec 31, 2016 | Sharp Televison & Video
My tv, sharp, does not power on. it only shows the word SHARP for a few seconds and turns off. what may be the problem?
Do a hard reset to this set, and then check. If it do not help, check and replace its main digital board.
Sep 26, 2016 | Sharp Aquos Televison & Video
Sharp LC-26AD5E-BK Upon switching TV on screen displays: "Software Update through PC/UART" & "Connecting to host". TV is non responsive to remote control and am unable to exit screen. Please help.
Try a hard reset to this set, and then check. If it do not help you; contact the authorized service center for sharp. Firmware update might be necessary.
Jun 15, 2016 | Sharp Televison & Video
Sharp displays frozen on start up logo. Just shows SHARP and wont change sources or anything. Model # LC-65LE645U
Sounds like corrupted firmware. A firmware update might be necessary. If you wish to get some details; check the site linked here. Pull up older posts.
Firmware (Software) update procedure of many popular brand TVs and other devices are given in detail.
Bfore doing anything; try a hard reset to this set, and check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
May 24, 2016 | Sharp Televison & Video
How to reset my sharp aquos led tv LC-24LE155M
Apr 26, 2016 | Sharp Televison & Video
My sharp aquos lc-60le660u its only displaying the sharp logo.wont.turn.of or anything else.like if it is frozen
Try a hard reset to this set; and check. If it do not help you, contact the authorized service center. The main board will be faulty. There are two types of reset to TVs. The first is simple to do; a Hard Reset; and the other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Jan 17, 2015 | Sharp LC 60LE660 60 Inch Aquos 1080p
SHARP AQUOS LC-70LE632U will not accept a signal through any of the HDMI ports. Whats the problem
Do a reset to this set and check. If it do not help you; contact any service technician.
To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Sep 07, 2014 | Sharp Aquos LC-70LE632U 70 Inch 1080p...
Sharp Lc-42d62u lcd 42 in. tv has sound with solid blue screen no picture
Try to unplug the set to allow it the chance to reset the micro it uses--for a while or even overnight---Also with the model call Sharp to see if this is a known issue with this model or if there is a way to do a manual hard reset of the TV.
Apr 21, 2012 | Sharp Televison & Video
Televison & Video Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
