Question about Carrier Heating & Cooling
Carrier 24ANB760A300 will not run when it is 18 degrees out.
What termperature should the refrigeration and freezer be at when running right? In degreees, please
Fridge 4 - 8 degrees C, 5 degrees preferred, though some say 1 - 5 degrees.
Freezer minus 18 to minus 30 degrees C with minus 25 being preferred.
Sep 10, 2017 | Refrigerators
What is the Torque for cylinder head jeep wrangler crd 2.8
169 dohC Turbo diesel (2.8l)
16 Valve Vm motori
1st Bolts 1-18, 22 ft lbs,
2nd Bolts 1-10 turn 75 degrees,
3rd Bolts 11-18 turn 50 degrees,
4th Bolts 1-18 turn 75 degrees
Aug 16, 2015 | Jeep Cars & Trucks
Need bolt torqe specs , rods, mains, oil pump & oil pan for 6.0 vortec engine thanks
Connecting Rods: First pass 15 lb ft. If you have an early first design final pass 60 degrees. Second design 75 degrees.
Main Crank Bolts: Inner bolts first pass 15 lb ft. A final pass additional 80 degrees. Tighten the outer bolts/studs 15 lb ft. Final pass 53 degrees.
Tighten the side cap bolts to 18 lb ft. Tighten the bolt on ones side of the bearing and then tighten the bolt on the opposite side of the same bearing cap.
Oil Pump Bolts: 18 lb ft.
Oil Pump Screen Nut: 18 lb ft
Oil Pump Screen Bolt: 106 lb in
Oil Level Indicator Tube Bolt: 18 lb ft
Oil Level Sensor: 115 lb in
Oil Pan Drain Plug: 18 lb ft
Oil Pan Bolt: 18 lb ft
Oil Pan (to front cover): 18 lb ft
Oil Pan (to rear cover): 106 lb in
Oil Pan Skid Plate Bolt: 15 lb ft
If you need more specs contact: melissapowers75@gmail.com
Feb 02, 2010 | Chevrolet C2500 Cars & Trucks
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Rod and main bolt torque specs
rods bearings for the 4.2 engine is.18 ft lbs +110 degrees. main bearings 18 ft lbs +180 degrees. the 5.3 engine rod bearings torque is.15 ft lbs +85 degrees.main bearings is inner bolts 1st pass 15 ft lbs .final pass is 80 degrees.outer bolts 1st pass is15 ft lbs .final pass is additional 51 degrees.the m8 bolts 18 ft lbs..the 6.0 engine rod bearings torque is 15 ft lbs plus 85 degrees.the main bearings torque is inner bolt 1st pass 15 ft lbs .final pass plus 80 degrees. outer bolts .1st pass 15 ft lbs final pass plus 51 degrees.m8 bolts 18 ft lbs.
Jun 19, 2009 | Saab 9 7X Cars & Trucks
Carrier Comfort 13 Puron model 24ACA3 / FV4NB006 installed 3/18/08 no longer cooling. Carrier AC1-100 Thermostat checked per manual - all default settings intact. Test override did not turn unit on though....
Verify 24 volts at the low voltage transformer inside the air handler. If it is OK, jump out the red/green and yellow thermostat wires. If everything comes on, replace the thermostat.
Jun 07, 2009 | Carrier 38CKC036 Air Conditioner
Carrier PTAC Condenser ices over.
You are describing normal operation for a heat pump unit.
Feb 20, 2009 | Carrier 52CQ315 Air Conditioner
Heating & Cooling Logo
23 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
