Question about Camp Chef Triton 10L Portable Water Heater
I live in Vermont, and don't have running water in my house. I just bought a Triton 5L, and thought I could use it indoors. Can I?
Indoor use
Intermatic WH40 motor not turning
call a local plumber to sort out the problem
it might be time for a new timer
Jan 30, 2018 | Intermatic WH40 - Water Heater Time Switch...
I have a Paloma PTG 42 PVN Cold water turns unit off
Inside the unit there is an electrical " gap switch " like an off/on switch, if this is not set right to yr water pressure it will not work correctly. Take the front of the unit off, find the switch which is usually in the front area at the bottom where the cold water goes in, and ajust the screw on the side, suggest you open it a 1/2 turn at a time to increase the flow valve, and see if that is yr problem. cheers
Aug 01, 2012 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I have abosch 1600 ps aquastar 4.3 gpm indoor when i turn hot water on it all fires up but no hot water comes out only luke warm water why
Water heater is heating water but only luke warm water arrives at faucet.
Open TP valve and confirm that hot water is available.
If water at TP valve is hot, then problem might be plumbing-related, for example crossover.
http://waterheatertimer.org/Crossover.html
Aug 15, 2011 | Bosch 1600PS NG Aquastar 4.3 GPM Indoor...
I have a 1991 40 gl and it fell through the floor which is like 2 ft off the ground. turned the water off and replaced the pipes it has its own lever type power supply with the screw in fuses 30 amp (2) of...
You have 2 problems with several possible causes:
You have 10-year-old electric water heater that was reinstalled after falling down, and doesn't heat the water.
And you have no hot or cold water pressure, and no pipes are leaking.
1) First problem is lack of water pressure throughout house.
Turn on outdoor spigot nearest to water meter.
This spigot will tell you if problem is inside the house or between the house and meter.
If spigot runs full force, then you probably have clogged pipe where water heater connects to main cold line, or the main shut off valve got clogged with sediment that broke off inside the pipe when you were working on water heater.
Open and close shut off valve to see if that helps. Then disassemble pipes and track back the problem. Put pressure gauge on water heater drain valve to watch pressure drop when turning on indoor faucet.
Read following information:
http://waterheatertimer.org/Low-hot-water-pressure.html
Water heater doesn't work:
Test across wires at top of heater to see if you are getting correct voltage:
If tank is receiving correct voltage, then no hot water puts suspicion on upper element or upper thermostat, or both.
Open following link for electric water heater troubleshoot steps:
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
Jul 30, 2011 | RELIANCE ELECTRIC WATER HEATER
How to do fix the remote control temperature light on flashing.
I don't know answer.
Open following link for Rheem tankless resources, including contact number, live chat, and possible manual.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Repair most tankless problems yourself, same day, all brands for $330.
http://waterheatertimer.org/How-to-install-gas-water-heater.html
Absolutely feel obligated to upvote the help.
Or take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 04, 2011 | Rheem RTG-53DVN Natural Gas Indoor Direct...
Starting unit very difficult
Check your thermocoupling, because it seems like it isn't sensing the flame.
May 09, 2010 | Rheem Paloma PTG-42PVN / RTG2-42PVN...
My water heater keeps going off whenever the heat to the house is on.
check to see if the gas line coming into the house is big enough to support the water heater and the furnace at the same time. Call the gas co. and have them check their regulator for size and performance
Feb 21, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
Changing out the hot water heater timerswitch
Nema 1 means indoor-only enclosure or box.
For example Nema 3R is raintight for indoor-outdoor box, which is typical for outdoor swimming pool timers.
If you have water heater timer, open following page for common timers with images, manuals and wiring for each.
http://waterheatertimer.org/Boxtype.html
Dec 27, 2009 | Intermatic WH40 - Water Heater Time Switch...
Camp Chef Triton 10L Portable Water Heater Logo
16 people viewed this question
Top Camp Chef Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Camp Chef Water Heater Expert? Answer questions, earn points and help others
