Question about Kyocera Mita Office Equipment & Supplies
Copystar copier cs-2013 error code c63
Copystar copier CS-2013 flashes C 63 on screen.
  • 18 Answers
SOURCE: resetting code on a copystar cs-1620
what code? many codes to be reset such as 1087 1087 then enter163 to reset fuser. you need to know what your resetting first, some machines used 096. let me know what you resetting. rrralf
Posted on Feb 03, 2008
  • 990 Answers
SOURCE: COPYSTAR CS-1810
Hello sir; "AP" isn't a problem, just let it run for a little while, it will disappear.
Posted on Feb 19, 2009
  • 26 Answers
SOURCE: I have a Copystar CS-2020 and it is showing error
Document Processor communication problem. This is due to a faulty ground connection.
Open the doc feeder lid, check the left hinge. There are two versions of grounding tab: a small one and a bigger and better one. Both attached by a screw.
Twist the small metallic tab that grounds the hinge with doc feeder metal frame in order to create better contact. Worst scenario, the doc feeder cable has a broken ground wire at the holding strap (inside the back rear cover of the feeder, which is hold in place by plastic clasps. If you are handy you can solder the wire ..
Posted on Feb 21, 2009
  • 5 Answers
SOURCE: kyocera cs 1820 or copystar = error message = 3200
3200 is a problem with the exposure lamp. If you are in a dirty enviroment, the problem could be dirty mirrors under the scanner glass.
Posted on Apr 09, 2009
goodgold
  • 389 Answers
SOURCE: Copystar CS-C2525E. Paper Jam error 91. No paper
Under included device open and close the lid. Unless throw, see the condition a sensor entry and leaving the paper - can be the sensors conk. Good luck
Posted on Oct 08, 2009
Error code c410 on cs-2218
If a C410 Error occurs, replace the DP-410 Main PCB Assembly, Ground Wire and Screw.
The PCBs part number is 303HL01018.
Apr 01, 2013 | Copystar Cs-2218/cs-2221/cs-2225 Developer...
I HAVE A CODE C-6 ON COPIER AFTER POWER WENT OUT
have a copystar#GS-1500 and after power went out, have flashing error code C-6 and 400. Worked perfect just prior. please help!
Oct 13, 2010 | Copystar CS-1500 Copier
I have a brand new Copystar CS-3060 turn it on and a ERROR CODE 3100 appears on the screen what does this code mean please??????
The scanner is locked...look for some large yellow screws on the side of the machine or on the rear of the machine inside of a detent. Turn it left until it pops out to release the scanner.
Mar 11, 2010 | Kyocera CopyStar CS-3060 Black and White...
Oct 06, 2009 | Copystar CS-4035 Copier
Error Code A-O 210 is flashing. What do I do?
press 10871087 uoo will flash on screen then press print, D-L will appear, then press darker key find the letter c then print then email me the data that will appear low_toner@yahoo.com from then i will teach you on what to do
Apr 16, 2009 | Copystar CS-1620 Copier
Kyocera cs 1820 or copystar = error message = 3200
Apr 02, 2009 | Kyocera Copystar CS-1820 Black and White...
What does C710 stand for?
GO ON LINE AND TYPE
KYOCERA COPYSTAR CS-1820 ERROR FLASHES C710
ENTER
GO ONLINE AND TYPE THE FOLLOWING INFORMATION
MANUFACTURE NAME,MAKE,MODEL SERVICE GUIDE AND DRIVERS
ROD
Feb 09, 2009 | Kyocera Copystar CS-1820 Black and White...
Unrecognizable error code
press 10871087 menu will appear then go to c codes list
Apr 09, 2008 | Copystar CS-2050 All-In-One Printer
Copystar CS-1810 Error Code
I'm sorry, Copystar is not a brand I am familiar with.
Be blessed.
Mar 19, 2008 | Copystar CS-1810 Copier
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Jan 07, 2008 | Copystar CS-2114 Copier
18 people viewed this question
Top Kyocera Mita Office Equipment & Supplies Experts
Kyocera HP Expert
Adorjani Laszlo
AAAA262430
Are you a Kyocera Mita Office Equipment and Supply Expert? Answer questions, earn points and help others
