Question about Refrigerators
Works fine until i leave for two weeks at some point it shuts down and food spoils
4 Suggested Answers
  • 13 Answers
SOURCE: Amana Refirgerator stops working for hours then starts again
check the defrost timer if necessary replace it
Posted on Aug 10, 2009
  • 308 Answers
SOURCE: Refrig. won't keep food cold but the freezer works
If the thermostat has been replaced, then I would take a look at the dampers between the refrigerator and the freezer. Here is why....
All the cooling takes place in the freezer section of the unit, there are passageways with dampers that connect the freezer section to the refrigerator section. If these dampers get stuck in a certain position you will either have not enough cooling or to much cooling. This sounds like it is your issue. Hope this helps.
Posted on May 07, 2010
espressonist
  • 1711 Answers
SOURCE: Hi, I have a Hotpoint refrigerator
The most posible fault is a dirty condenser.
The condenser in your model is located behind the base grille on the bottom of the fridge. Remove the base grille by grasping it at the bottom andpulling it out. Now either sweep away or vacuum dust that is readily accesible.
This easy cleaning should be done at least once a year for most efficient operation.
Their is also a smaler posibility that the automatic defrost system which can be either the defrost thermostat or the defrost heater.
So if the condenser cleaning will not make a change after a couple of days then switch of the refigerator for tow hours and try to keep door closed so good not spoiled. then switch it on again and notice if you have desired temperature. You should find a thermometer so this will help you realise the deference in temperature more acurate.
Good luck and thanks for using FixYa.
Posted on Aug 31, 2010
Tip
Refrigerators cleaning tips
<span> <p>The first thing that you need to do is keep the weekly and the daily cleaning of the refrigerator up to date.<br /> <ul> <li>Clean up any spills as soon as they happen. That means that you need to remove the drawers and clean under them. This is the location with the most potential for trouble as the stains are likely to stay.</li> <li>Always store food in covered containers. Open things can easily spill or be pushed to the back and forgotten about until they spill.</li> <li>Keep an eye on the leftovers. Throw out food when it expires or goes bad. Food that is stored too long will develop mold which could contaminate other foods.</li> <li>Monitor the temperature. You need to keep the gauge set accurately so that food does not spoil and bacteria does not grow.</li> <li>To stop odors, store an open box of baking soda in the refrigerator.</li> <li>Use a sanitized towel to wipe down the shelves, handles and door each day or week as needed.</li></ul> <p>If you take the time to keep up the fridge, you will have less trouble in deep cleaning it later. Of course, this means less scrubbing if you keep up on it from the beginning.<br /></span>
on Apr 02, 2011 | Refrigerators
The refrig has stinky smell after not opening it for two weeks without any spoiled food.
Is it a moldy odor or rotten food odor?
I suggest cleaning interior and then spraying with odor remover like: Nok Out Odor Eliminator and Sanitizer
Mar 20, 2016 | Refrigerators
Used wrong water filter. Now that we replaced with correct filter, there is a horrible odor in the refrigerator.
Hello Mary;
My name is Peter. I am a retired field service refrigeration technician.
Putting in the wrong water filter will not effect the smell in your refrigerator. At times the granules in a water filter will break down and get into your water dispenser and ice cube tray. This should not create a bad smell, just cloudy water.
Your plastic liner in your refrigerator has pores and holds odor. You have something in your fresh food section or freezer that is spoiled. Your fresh food section receives cooling air from your freezer. If you have a spoiled product in your freezer you will not smell it because it is frozen. But, as the cooling air goes into your fresh food section and cools down you will smell it.
Find the bad product in your freezer and discard.
With a 50% solution of white vinegar and water wash the plastic liner.
Now you can put a tray of baking soda in your unit, until you purchase deodorizers based on temperature requirements, one especially designed for the freezer section and one for fresh food section. These deodorizer are about $12.00 each.
Try Lowe's and Home depot.
May 11, 2015 | Samsung RF31FMEDBSR Stainless Steel 31 cu....
Left ge stainless steel fridge and freezer door open acciently
youll need to unplug and defrost all the ice from hte back panel, leave unplugged for a min of 24, hours, then plug back in you should be fine. way too much ice has built up behind hte inner panel ,cutting of all air flow to both compartments.you did no real harm( other then losing your food
Nov 28, 2008 | GE Refrigerators
Fridge Problems
what model and make is it
Oct 30, 2007 | Refrigerators
Refrigerators Logo
12 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
