Question about Exercise & Fitness
Track needs alignment on Bremshey Treadline Ambition treadmill
How to adjust the track alignment
2 Suggested Answers
Robert Braun
  • 77 Answers
SOURCE: how do I adjust the tracking epic t 40 treadmills
If you mean side to side tracking, there are Allen bolts at the bottom rear of both sides of the treadmill. Turn one slightly one way and the other the slightly other way until it's right.
Posted on Mar 15, 2010
Bremshey treadmill maintenance treadmill belt slipping
Fit new belt ,check for slide adjuster slots.
Aug 13, 2014 | Exercise & Fitness
Bremshey treadmill maintenance,treadmill wont run until i have safety button pressed in
Your treadmill should not run without the safety button pushed in, or safety key in. this is to shut the unit down if you were to fall.
Sep 21, 2013 | Exercise & Fitness
Bremshey lift motor
see the diagram attached and fix it. God bless you
However you can RUN the software calibration for easy diagnose, troubleshooting, and fix it.
God bless you
Dec 14, 2012 | Bremshey Exercise & Fitness
Nordic track treadmill stuck on highest speed
Adjusting the speed sensor:If the calibration does not pass you may need to check the speed sensoralignment.1) Remove the motor cover hood by loosening the 4 screws that hold it inplace (you do not need toremove them completely).2) The speed sensor is located on the left side of the frame, right nextto the front roller pulley (thepulley will have a belt around it that also goes to the motor). Thespeed sensor is small and blackwith a wire connected to it.3) Make sure the sensor is as close as possible to the pulley withouttouching it. You will see a magneton the face of the pulley; make sure the sensor is aligned with themagnet. There is a screw thatholds the sensor in place that needs to be loosened to adjust thesensor. Re-tighten the screw whenfinished.
sincerely.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Oct 09, 2011 | Nordic Track NordicTrack Commercial 1500...
Nordic track treadmill stuck onfull speed
GOOD LUCK.SINCERELY
I currently replaced the walking belt on my C954i/C956i treadmill. When I plugged it back in and turned on the power, the treadmill has no power. What could have happened?
Dear Sir:
I can read you trouble, and follow the next steps:
ALIGNING AND ADJUSTING THE RUNNING BELT
The correct alignment of the running belt is critical to the smooth operation of the treadmill. The belt is properly aligned at the factory. However, during shipping and handling or by use on an uneven surface, the belt may move off center and require a few simple adjustments. Before aligning the running belt, check its operation by following the procedure in Checking the Alignment of the Running Belt. If you determine that the belt needs alignment, follow the instructions here. CAUTION: Special care must be taken when aligning the running belt. Turn OFF the treadmill while adjusting or working near the rear roller. Remove any loose clothing and tie back your hair. Be very careful to keep your finger or any other object clear of the belt and rollers, especially in front of the roller and behind the deck. The treadmill will not stop immediately if an object becomes caught in the belt or rollers. Realigning the belt takes a few simple adjustments. If you are unsure about this procedure, call Precor Customer Support (see Obtaining Service.) Take the following steps to align the running belt on the treadmill. To ensure your safety, make all adjustments while the treadmill is OFF. 1. Make sure the treadmill is OFF and the running belt has completely stopped. 2. Locate the right belt adjustment bolt in the rear end cap of the treadmill. (To determine left and right, stand at the rear of the treadmill and face the display.) See Diagram 24. The direction you turn the bolt depends on how the belt is tracking. Make all belt adjustments on the right rear corner bolt using the hex key provided. • If the belt is off center to the RIGHT, turn the adjusting bolt ¼ turn clockwise, which moves the running belt to the left. • If the belt tracks off center to the LEFT, turn the bolt ¼ turn counterclockwise; this moves the belt to the right. Important: Do not turn the adjusting bolt more than ¼ turn at a time. Overtightening the bolt can damage the treadmill. 3. Turn the unit ON. 4. Stand beside the treadmill and press QUICKSTART. 5. If you are prompted for a password, press INCLINE ??¼, SPEED ??¼, SPEED ??². The running belt starts automatically after the 3-second countdown appears on the display. 6. Press the SPEED ??² key until the display shows a speed of 3 mph (5 kph). 7. Walk around to the rear of the unit and observe the running belt for a few minutes. The belt should run centered along the running bed. If the belt drifts off center, you will need to make adjustments. CAUTION: If you hear any chafing or the running belt appears to be getting damaged, stop the running belt immediately by pressing the red STOP button. Contact Precor Customer Support. 8. If the belt needs additional alignment, repeat steps 1 through 7 until the belt is properly aligned. 9. After aligning the belt, press the STOP button and RESET. Turn OFF the treadmill. Tighten any loose fasteners or other components on the equipment. If you hear unusual noises or you feel that the treadmill is in need of repair or service, contact Precor Customer Support. Refer to Obtaining Service.
Finally, check if the power cord is loose, connect it again. a) See if the breaker of Home is tripped? b) See if the breaker of the Treadmill is tripped. If do the Belt is very Tighted! loose a little. Try again.
Thank you in advance, if you need assistance, you can contact me, Blessing. sincerely.
E. CUADRA Managua, Nicaragua. C.A.
Sep 26, 2011 | Precor C954i Commercial Treadmill
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
23 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
