Question about Candy Ovens
How to remove glass from model fpp609x door
I just want to remove glass if possible for cleaning
  • 50 Answers
The doors are made from high quality heat resistant and insulating materials, they are not made to come apart sorry.
Posted on Nov 24, 2015
SOURCE: Removal of door
get a special key and open
Posted on Nov 13, 2007
  • 17 Answers
SOURCE: Whirlpool double oven - model RBD305PD82
Please take a look at the diagram if you think you want to do that.
if you still want to do it and need more details to disassemble feel free to email me. nguyen@ite.net
Posted on Jun 09, 2009
  • 49 Answers
SOURCE: I own a Kenmore stove model #639539J2. The glass
yes. open the oven door to the first "click". it kind of stops about a quarter of the way open. most ovens you grab both sides of the oven door and pull up. some models have a couple of screws you have to take out before you can remove the oven door. then lay it down with the insie of the door facing up and take out all the screws holding the oven door together. some may be on the sides or the top and bottom of the door. when apart, clean first with easy off, then clean several times with windex till streaks are gone. assemble door in reverse and put back on stove.
Posted on Oct 10, 2009
  • 43 Answers
SOURCE: How to clean inside glass on oven door
If you can, usually it is possible, remove the door from the oven. open door to the first open position..(broiling) about 6" open then (make sure any screws are removed from hinges holding door in place) lift up and out at the angle the door sits.place on counter and start removeing screws. can be a whole bunch of em..
Posted on Oct 25, 2009
  • 4 Answers
SOURCE: cleaning glass in oven door
Extend your door hinges and remove entirely over to a table or other flat surface where you can do a step-by-step dis-assembly. Begin by removing the bolts at the bottom of the door, then the main panel and side flanges can be removed. The glass slides out from the tabs and you can give it a good cleaning at this point. Reverse your order to re-assemble, and put your door back on the oven. It's not as bad an exercise as it would appear. Just take your time and watch what you're doing. I used the hinges as a shim, and had it laid out on a pool table for easy, elevated examination.
Posted on Jan 02, 2011
Testimonial: "Thanks for the advice and it worked like a charm, like you said make sure that you take your time and it works TX "
How do i remove the glass from the door
The oven door glass panel is a sealed unit that is not intended to be removed for "cleaning". The unsightly residue between panes accumulates because the metal seal expands while the oven is heating.
Jul 30, 2016 | Ovens
Can you please tell me how to remove the oven door?
If you are trying to clean between the inner (heat shield) glass and the outer glass (safety glass for looks), you may not have to remove the whole door. On most models, the outer glass is either integral to the handle and frame or at least is trapped by the handle and frame. Open the door and look inside. There should be either two or four screws right at the top that hold the handle and frame assembly in place. You may find that when you take these off, the handle slides off, and the glass can either slide up or the whole frame will rock outward. Be VERY careful, this is safety glass and shatters into 2mmx4mm pieces easily if you bump it.
If the whole door has to come off, most new models don't even need screws taken out... you just pry up the two metal tabs next to the hinges, and it unlocks and you slide the door up off the hinges. See the link for instructions if you need to remove the door and take it apart. This covers most oven doors.
Cleaning between the glass of an oven door Frigidaire Jim Carson
Jan 02, 2016 | Ovens
How do I take the glass out my oven door model AP578X-8
Hi, I have pasted the instructions for your Smeg oven you below:
9.4 Removing the internal glass panels
The glass in the door should always be kept thoroughly clean. To facilitate
cleaning, it is possible to remove the door (see 9.2 Removing the door) and
place it on a canvas, or open it and lock the hinges in order to extract the glass
panels.
The glass panels of the door can be completely removed by following the
instructions provided below.
Warning: before removing the glass panels, make sure that at least one of the
door's hinges has been locked in the open position as described in "9.2
Removing the door". This operation may have to be repeated during the glass
removal process if the door is accidentally freed.
Removing the internal glass panel:
• Remove the internal glass panel by
pulling it upwards, following the
movement indicated by the arrows. Doing
this detaches the 4 pins attached to the
glass from their slots in the oven door.
Removing the intermediate glass panels
(on some models only):
• Some multifunction models have an
intermediate glass panel. Remove the
intermediate panel by lifting it upwards.
Cleaning:
• It is now possible to clean the external
glass panel and the panels removed
previously. Use absorbent kitchen roll. In
the case of stubborn dirt, wash with a
damp sponge and neutral detergent.
Replacing the glass panels:
• Replace the panels in the reverse of the
order in which they were removed.
• Reposition the internal glass panel, taking
care to centre and insert the 4 pins
attached to the glass into their slots in the
oven door by applying slight pressure.
You can go to the website for further information: http://www.u-manual.com/download-manual-now-for-free-10/210209/oven-smeg-ap578x-8.html#.UumokD2Sxvg
Jan 29, 2014 | Smeg Ovens
Frigidaire oven door glass clean inside
Good Morning Suzi - Generally, qualified technicians often perform complicated part replacement such as this, however this may or may not be specifically for your model. Below are generic instructions that I found on how to take your oven door apart to remove any stains that may be caught down in the door vents.
Tools needed: Phillips head screwdriver or small quad bit driver.
A. Open Door remove 2 screws and washers on door lining at door hinge area.
B. Refer to owners guide with door in broil stop position lift door assembly off hinges.
C. Lay door on table, position so that handle hangs freely over edge of table
D. Remove 2 screws and washers that secure handle to lining assembly.
E. Remove 8 screws that attach textured steel door wrapper trim to lining assembly 3 at top, 3 at bottom, 1 on each side
F. Lift door lining up and out of wrapper trim assembly.
G. Lay lining assembly on table with wool shield/inner part of lining facing up.
H. Remove 2 glass clamps via 2 screws per clamp. These clamps attach innermost clear glass to wool shield.
I. Lift out center clear glass from wool shield, this glass just lays onto the wool shield and is held in place by the glass/ clamps in item H.
J. Clean each glass with appropriate cleaner, Windex, bon ami, fantastic, etc
K. One glass that remains in door lining assembly can at this time be cleaned without further disassembly the lining assembly.
L. Reassemble in reverse order.
I hope this information helps to some degree.
May 24, 2013 | Frigidaire 27 in. Electric Double...
Hello Is it possible to remove the glass door panels for cleaning? I can remove the door but I want to clean the glass panels separately. Many thanks Jill
With the door removed, I would suggest to lay it on a flat surface, look at the door around the edges. Normally you can see 2-3 screws around the bottom and 2-3 screws around the top edge. By removing them you can disassemble the door. Be-careful as you disassemble the door, pay close attention to how it can apart to reassemble when your done. This job should not require any special tool other then a screwdriver. Do not force anything back together. This should be about a 30-min job or less depending on the cleaning part on the glass. Go luck.. P.S. - it is glass your dealing with, some of the edges can cut you if handle in the wrong unsafe manner.
Jul 08, 2011 | Whirlpool Ovens
Cleaning glass in oven door
Jul 02, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Oct 24, 2009 | Ovens
Oct 10, 2009 | Kenmore Ovens
Broken inner glass on Model # NGSG3PZAQA
To replace the door glass do the following:
0 Check if there is a hinge stop bracket located at the hinge point of entry on the oven, in that case remove it.
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Removethe inner screws. Keep all set of screws ordered, and take note of theorder you remove them. You will follow reverse order in reassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
I also report testimonials for your model:
removed the door from the oven by releasing clips attached to the door hinge -- very nicely engineered. Removed about 6 philips head screws to allow the door assembly to be taken apart for access to the glass. Lifted out the broken glass, cleaned the inside of the door, installed the new glass, reassembled the door (a two minute project), and reattached the door to the oven. Cleaning the inside of the door"
I removed the oven door by lifting it off with the hinges. Disassembled the door parts one at time making sure I remember where I removed the screws until I am able to get to the broken glass. The most difficult part is making sure that the insulation strip & the gasket stayed in place after I replaced the broken glass & doing the reverse process of installing the parts together. Relatively easy process as long as you remember where the parts go. When in doubt, I had to refer to the pictorial of the disassembled door shown on your website. "
See diagram below , click on picture to enlarge:
Part here: Inner Door Glass
Mar 17, 2009 | Frigidaire FGB24S5A Gas Single Oven
Cleaning Inside Glass Oven Door of KitchenAid KEMC308KSSO
To dismantle the kitchenaid pro line oven door: there is a lever over the hinges that attach a door to the oven. The lever is right on top of the hinge. Pull the lever up. When that lever is in the up position, you can pull the door out.
Jan 10, 2008 | KitchenAid Architect Series KEMC308KSS...
Ovens Logo
57 people viewed this question
Top Candy Ovens Experts
ashburton
ray gallant
Dado
Are you a Candy Oven Expert? Answer questions, earn points and help others
