Question about HP J4680 Office Jet All-In-One Printer
Error on hp j4680 image on fax send report is set to on
  • HP Master
  • 783 Answers
Sir/Madam
Solution one: Print a fax test
1.Make sure the product is turned on and correctly connected to the telephone jack.
2.Make sure that there is plain white paper in the input tray.
3.On the product control panel, press the Setup button ( ).
4.Press the right arrow ( ) to select Tools , and then press OK .
5.From the Tools menu, press the right arrow ( ) to select Run Fax Test , and then press OK . The fax diagnostic test prints.
6.Review the results of the test.
·If the test lists faxing issues and solutions, the fax test failed. Follow the solutions on the printed report to troubleshoot the issue. This report is specific to your product and faxing environment, so use the solutions on the report to resolve the listed faxing issues. Repeat the Fax Test after fixing the listed faxing issues to make sure the test passes.
·If the test does not list faxing issues and solutions, the fax test passed. Continue to the next solution.
7.Try to send a fax again. If the HP fax still cannot send a fax, continue to the next solution.
In case You Still facing Problem The Visit official HP Printer website Below URL Link On:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01555948&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3692888
OR
If you Still having Problem then follow Us On:
HP Printer Support
Posted on Feb 12, 2014
Riztech
  • 731 Answers
SOURCE: Fax Error codes
I have mentioned the Description for the error codes.388 and 421 error codes means the same and suggestion to resolve the problem.
282 - Retry the transmission.
388 - Reattempt the fax reception at a different time when telephone line conditions have improved.
421 - Reattempt the fax reception at a different time when telephone line conditions have improved.
233 - A communication failure has occurred between the two machines (OR) The user at the remote machine might have pressed the Stop button. (OR) Sometime Call waiting service might cause this error code.
  • Turn OFF the Error Correction mode(ECM).Steps to do. Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to Error Correction mode(ECM) and highlight -> press ok/Enter->Select turn OFF-> press ok/Enter.At Last Press Cancel to quit the menu.
  • Decrease the Fax speed.Steps to do.Push the menu/setup button ->Select Advanced fax setup-> press ok/Enter->Scroll Down to" Fax speed"-> press ok/Enter-> Choose "Medium speed or slow speed ->press ok/Enter. At Last Press Cancel to quit the menu.
Thank You
Posted on Feb 09, 2008
  • 5 Answers
SOURCE: Error 232 receiving fax
fax error 232 indicates a communication failure between the sending and receiving units. I'd check for line noise on the phone (you can hear it as cracks and pops) If your fax line is not dedicated, any noise from another phone pickup or an answwering machine can cause the failure.
Posted on Sep 08, 2008
amusedgeek
  • 787 Answers
SOURCE: Hp Officejet J5780 All-in-One
On the Officejet`s control panel, Press Setup, then press 2, now press 3.
The panel will display the choice of Off, Print confirmation on Send, Print confirmation on recieve or Print on Send and Recieve. Select your choice.
Posted on Oct 19, 2008
  • 50 Answers
SOURCE: Image on fax send report is set to off
1> Press the wrench/tool mark (SETUP) button on the printer.
2> Go to 'Print Report'
3> Go to 'Image On Fax Send Report' and use the arrow key on the front panel to change it to ON and select/press OK tio save.
Posted on Jul 17, 2010
nonontech
  • 4737 Answers
SOURCE: hp officejet pro 8500 a909a
Press the settings button i.e the button with the wrench icon on the machine. Now select "Print Report" and then "Image on Fax Send" and set it to "ON". Save the settings and try again. It should work.
Let me know if you need further help. Good Luck.
Thanks for using FixYa.
Posted on Mar 24, 2011
Hi could you tell me how to print the report for sending please to keep as proof to a number it was sent
Customizing the Transmission Verification Report You can use the Transmission Report as proof that you sent a fax. This report lists the time and date of transmission and whether the transmission was successful (OK). If you select On or On+Image, the report will print for every fax you send. If you send a lot of faxes to the same place, you may need more than the job numbers to know which faxes you must send again. Selecting On+Image or Off+Image will print a section of the fax's first page on the report to help you remember. NOTE:When the Verification Report is turned Off or Off+Image, the Report will only print if there is a transmission error, with NG in the RESULT column. 1 Press Menu/Set, 2, 4, 1. 2 Press ? or ? to select Off+Image, On, On+Image or Off. Press Menu/Set. 3 Press Stop/Exit.
Jul 21, 2011 | Brother MFC-620CN All-In-One InkJet...
I keep getting "image on fax send report is set to
Hi!!
Press the Setup button on the front panel of your All in One
Go to Print report
Check for Fax report it may be off turn it On
Apr 16, 2011 | HP Photosmart C7280 Printer
you did not mention your HP Printer model, however if you are getting the message " Image on fax send report is off " you can try this setting on your Printer.
Press the Setup button on the printer front panel ( Ranch like symbol )
Scroll using the down arrow ( or arrow keys ) till you find Print Report option - Press OK
Scroll till you find Image of Fax Send Report - Press OK
Turn if off/on using the arrow key - Press OK
The Issue is resolved.
Regards,
Ron
Feb 24, 2011 | Office Equipment & Supplies
I would like to have the device print a Fax Confirmation for all fax sent and received. HP Officejet J4680 All-In-One
Follow the steps below to enable the Fax confirmation on Sent and recieved.
On the printer :
  1. Press Setup (c01461502.gif ).
  2. Press the right arrow button (c01185072.jpg ) to select Print Report , and then press OK .
  3. Press the right arrow button (c01185072.jpg ) to select one of the following options:
    • On Fax Send: Print a confirmation page every time you send a fax.
    • On Fax Receive: Print a confirmation page every time you receive a fax.
    • Send & Receive: Print a confirmation page every time you send or receive a fax.
  4. Press OK .
Thank you for contacting FixYa
*Please rate this solution with Thumbs Up
Nov 24, 2010 | HP J4680 Office Jet All-In-One Printer
Brother IntelliFax-2820 Plain Paper Laser Fax does not automatically print a transmission report each time we send a fax. Is there a way to automatically have that happen. We can't find it.
You need to set up the Transmission Verification Report and Journal Period in the menu table.
-OR-
Press Menu/Set, 2, 4, 2.
Note
is a transmission error, with ERROR in the
RESULT column.
2 Press ? or ? to select On, On+Image,
Off or Off+Image.
Press Menu/Set.
3 Press Stop/Exit.
Printing reports
1.XMIT Report
2.Journal Period
Nov 15, 2010 | Brother IntelliFax-2820 Laser Fax
Image on fax send report is set to off. Will not send fax
Jul 15, 2010 | HP J4680 Office Jet All-In-One Printer
How do I get a fax conformation?
This is an excerpt of the User's Guide for your machine. You can download from here:
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&product=1138342&
Print fax confirmation reports
If you need printed confirmation that your faxes were successfully sent, follow these instructions to enable fax confirmation before sending any faxes. Select either On Fax Send or Send & Receive.
The default fax confirmation setting is Off. This means that the HP All-in-One will not print a confirmation report for each fax sent or received. A confirmation message indicating whether a fax was successfully sent appears briefly on the display after
each transaction.
To enable fax confirmation from the control panel
1. Press Setup.
2. Press 2, and then press 1.
This selects Print Report and then selects Fax Confirmation.
3. Press to select one of the following, and then press OK.
Off Does not print a fax confirmation report when you send and
receive faxes successfully. This is the default setting.
On Fax Send Prints a fax confirmation report for every fax you send.
On Fax Receive Prints a fax confirmation report for every fax you receive.
Send & Receive Prints a fax confirmation report for every fax you send and receive.
User Guide 65
Fax
Tip
If you choose On Fax Send or Send & Receive, and scan your fax to send from memory, you can include an image of the first page of the fax on the Fax Sent Confirmation report. Press Setup, press 2, and then press 2 again. Select On from the Image on Fax Send Report menu.
Aug 14, 2009 | HP OfficeJet 4315 All-In-One InkJet...
Confirmation page
You can configure your HP all-in-one so that it automatically prints error and confirmation reports. If you need printed confirmation each time a fax is sent, follow these instructions before sending any faxes and select Send Only. To set automated report options from the control panel Press Setup. Press 2, and then press 1. This selects Print Report and then selects Fax Report Setup. clip_image001.gif Press to scroll through the following report types: Every Error: prints whenever there is any kind of fax error (default). Send Error: prints whenever there is a transmission error. Receive Error: prints whenever there is a receiving error. Every Fax: confirms every time a fax is sent or received. Send Only: prints every time a fax is sent indicating whether the fax was successfully sent or not. Off: does not print any error or confirmation reports. Press OK to select the report.
Jul 29, 2008 | HP OfficeJet 6210 All-In-One InkJet...
HP J4680 Office Jet All-In-One Printer Logo
95 people viewed this question
Seeker5211
Seeker5211
