Question about Black & Decker Tools & Hardware - Others
120xl031 timing belt sander - Black & Decker Tools & Hardware - Others
I am looking for a drive belt for a mastercraft 3x21 beltsander. the belt says 120xL031. cant seem to find one anywhere.
The belt you can replace with a is simply any generic 3x21 belt. You can find them at your local hardware store or order them from a website like Home Depot, etc and have them shipped to your home. Here is a link to take you to Home Depot specifically for an 80 grit, but you can look for other grits as well. 3" is your width and 21" is the diameter of the belt you need.
Gyros 3 in 21 in 80 Grit Aluminum Oxide Sanding Belt 5 Pack 12 32180 5 The...
Feb 14, 2015 | Tools & Hardware - Others
I have a power devil belt sander, but every time i turn it on for use the belt works its way off... i bought this sander second hand at a boot sale so im thinking is there supposed to be an outside guide...
no there is not anything missing, you need to adjust the belt by turning the black plastic adjuster knob which guides the belt to the left. I have found that whilst using the sander you sometime need to adjust it further. If you adjust it too much the belt will hit and grind the plastic casing of the sander.
Also make sure you are using the correct size belt as it should be size 75X533 which you can buy from Toolstation for £2.78 a pack of 5.
Sep 03, 2011 | Electric Power Belt Sander, 3" X 21" 700...
HOW DO I REPLACE A TIMING BELT ON A 3" X 18" BELT SANDER
On the side of the sander there is a black triangle shaped cover with 3 screws holding it in place. Remove the screws and you will see the drive belt and 2 pullies or gears. The belt will be attached to the gears. Remove and replace the belt. Typically the belt is broken so the only thing you will need is to locate a new belt and slip in over the gears with the side with the teeth facing the gears. This keeps the belt from slipping. Reinstall the cover and you are ready to go back to work. The hardest part may be finding a supplier for the belt.
Aug 06, 2011 | Black & Decker BR300 3''x18'' Belt Sander
I need a new belt for my porter cable 4X24 inch belt sander - model 362 - type 6 whisper series
I have had the hardest time trying to find a belt for mine.
I've made do with a 3 x 24 without any turmoil
I take it you are having similar problems
Mike
Aug 21, 2010 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
How to adjust belt on skil belt sander
There should be a tracking adjustment knob on the side of the sander behind the front roller. Run the saw and adjust this knob to center the belt. You will probably have to do this every time you change belts. Hope this helps you...
Sep 11, 2009 | Sander Tools & Hardware - Others
Broken drive belt on belt sander
My answer comes almost a year after the original question, but I'll post it anyway for those who end up here after a search.
Black & Decker no longer supplies drive belts for the BR400 sander, but you can get a replacement elsewhere if you know what to ask for.
The belt is a synchronous, single-sided "XL" series belt, and mine had 120XL031 printed on it. The belt width is 0.31in or 5/16in or 7.9mm. Its pitch (distance from tooth to tooth) is 0.20in or 1/5in or 5mm. Its total height is 0.09in, and tooth height is 0.045in. It has 60 teeth, making the total length 12in.
I found a replacement at sdp-si.com, part number A 6R 3-060031.
Look here for timing belts (inch), then narrow the search for single-sided, .200 (XL) pitch, 60 grooves, 5/16 width.
Jul 15, 2009 | Black & Decker Tools & Hardware - Others
Describe your Black & Decker BR318
This is a good sander but no portable belt sander is really a floor sander.
Jun 13, 2009 | Black & Decker BR318 3" x 18" Belt Sander
Belt won't stay on belt sander
Check first that you have retensioned the belt... i.e. when you removed the other belt, you would have had to pull on a spring-loaded lever to remove the belt tension before you added the new one... make sure the tension lever is flipped back in to ensure the new belt is tensioned...
Next, and the likely problem you are having, is belt tracking... There should be an adjustment knob up near the front of the sander near the front roller, either on top of the front part of the sander, or to the side near the front roller... When you turn this knob, it makes the belt track either left or right over the sander's base. This knob will allow your belt to run square and true and not spin off to one side...You need to adjust the tracking using this knob while the belt sander is running and with the new belt tensioned and in place, so turn the sander upside down, and power it on with one hand, then turn the knob with the other hand whichever way is needed to have the belt track square and in the middle of the rollers. Make small adjustments on the tracking knob to begin with. They can be sensitive at times.
That should stop your belt spinning off to one side.
Mar 18, 2009 | Black & Decker Tools & Hardware - Others
Belt sander adjustment
There should be a knob on the front of the sander which adjusts the front roller on the sander. If the belt runs off in the same direction each time try turning the knob as the sander is running and while watching the belt. If turning the knob one direction does not work try turning the other direction. If turning the knob does not have any affect on the way the belt tracks on the sander then you probably have a broken or missing part on the front of the sander. This may require taking the sander to a service center.
Sep 15, 2008 | Tools & Hardware - Others
How many Types of Sanders?
Belt sanders: Belt sanders are useful for removing large quantities of wood stock quickly. They are generally used for rough sanding before fine finishing with a smaller sander. Palm sanders: Palm sanders are ultra-portable and useful for finishing small projects. Orbit sanders: Orbit sanders are usually more heavy-duty than palm sanders and appropriate for larger projects.
Aug 27, 2008 | Bosch 3X18 Belt Sander
Tools & Hardware - Others Logo
Top Black & Decker Tools & Hardware - Others Experts
Gil Shultz
Are you a Black & Decker Tool and Hardware - Other Expert? Answer questions, earn points and help others
