Question about Napoleon Fireplaces Napoleon F45 GDS50 Gas Stove On/Off Hand Held Battery Operated Remote
How do you get a blower out of a gds50 - Napoleon Fireplaces Napoleon F45 GDS50 Gas Stove On/Off Hand Held Battery Operated Remote
Blower fan not working at all 2004 Buick rendezvous
Which system ?
HVAC Systems - Manual HVAC Systems - Automatic
If automatic it's probably the blower motor control processor .
Blower Motor Control Processor The blower motor control processor is an interface between the HVAC control module and the blower motor. The blower motor speed control, Blower motor speed signal, battery positive voltage and ground circuits enable the control processor to operate. The HVAC control module sends the commanded blower motor speed to the control processor through a 0 to 12-volt linear ramped blower motor speed control circuit. As the blower motor speed control voltage increases, the blower motor speed increases. The control processor sends the actual blower speed to the control module through a 0 to 12-volt blower motor speed signal circuit. The processor supplies 12volts to the blower motor through the blower motor voltage supply circuit. The control processor uses the blower motor ground as a low side control to adjust the blower motor speed.
Nov 19, 2016 | Buick Cars & Trucks
How to change ac blower on a 2001 chevy silverado with the 5.3 liter v8
With Delphi Blower Motor
  1. If equipped, remove the sound insulator panel.
  2. Remove the blower motor insulating cover screws.
  3. Disconnect the electrical connector from the blower motor.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor from the heater/ventilation module.
  6. Remove the blower motor.
With Visteon Blower Motor
  1. Remove the sound insulator panel.
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the screws from the blower motor.
  4. Remove the blower motor from the HVAC module.
  5. Remove the retainer from the blower motor wheel. Discard the retainer.
  6. Remove the blower motor wheel from the blower motor.
Jul 27, 2014 | 2001 Chevrolet Silverado
The heater blower stopped working and the fuse is not blown?
Blower Motor Removal & Installation W/O Air Conditioning Blower Motor (W/O Air Conditioning) gm-10-00-634.gif
To Remove:
  1. Remove the PCM.
  2. Remove the coolant reservoir.
  3. Remove the rear coolant recovery reservoir mounting stud.
  4. Disconnect the cooling tube from the blower motor.
  5. Disconnect the electrical connector from the blower motor.
  6. Remove the blower motor mounting bolts.
  7. Remove the blower motor insulating cover.
  8. Remove the blower motor.
To Install:
  1. Install the blower motor.
  2. Install the blower motor mounting bolts.
  3. Connect the electrical connector to the blower motor.
  4. Connect the cooling tube to the blower motor.
  5. Install the rear coolant recovery reservoir mounting stud.
  6. Install the coolant reservoir.
  7. Install the PCM.
W/ Air Conditioning Blower Motor (W/ Air Conditioning) gm-10-00-633.gif
To Remove:
  1. Remove the PCM.
  4. Disconnect the electrical connector from the blower motor.
  5. Move the PCM connectors out of the way.
  6. Remove the blower motor access cover screws. CAUTION
    Do not cut any deeper than necessary in order to remove the access cover.
  7. Cut through the access cover on the cut line using a sharp utility knife.
  8. Disconnect the cooling tube from the blower motor.
  9. Remove the blower motor mounting bolts.
  10. Remove the blower motor.
To Install:
  3. Connect the cooling tube to the blower motor.
  4. Install the blower motor access cover.
  5. Install the blower motor access cover retaining screws.
  6. Using black weather-strip adhesive, seal the cut line.
  7. Connect the blower motor electrical connector.
  8. Reposition the PCM connectors.
  9. Install the rear coolant recovery reservoir mounting stud.
  10. Install the coolant reservoir.
  11. Install the PCM.
Feb 08, 2011 | 1996 Chevrolet Blazer
How to change blowermotor on 2001 gmc jimmy
To Remove:
  1. Remove the PCM.
To Install:
  7. Install the PCM.
To Remove:
  1. Remove the PCM.
To Install:
Dec 08, 2010 | 2001 GMC Jimmy
How to replace a blower motor in a 1996 ford thunderbird lx
Removal
  1. Remove the glove compartment liner to gain access to the heater blower motor and blower motor wheel assembly mounting screws.
  1. Use a small screwdriver to remove clip retaining hydraulic damper strut.
  1. Remove four screws and remove the heater blower motor assembly and blower motor wheel assembly from the heater blower motor housing.
Installation
  1. Using a new seal, position the heater blower motor and blower motor wheel assembly to the heater blower motor housing with the flat side of the flange near the heater blower motor switch resistor (18591). Install the four retaining screws.
  1. Tape the heater blower motor power lead to the air inlet duct to keep the wire away from the blower outlet during installation.
  1. Install the heater blower motor and blower motor wheel assembly in the vehicle.
  1. Install the glove compartment liner.
Oct 07, 2010 | 1996 Ford Thunderbird LX
How to install a front blower motor in a 96 ford explorer
Blower Motor - REMOVAL & INSTALLATION
(see Figures 1 and 2)
Fig. 1: Exploded view of the blower motor mounting
Fig. 2: Exploded view of the blower motor and wheel (fan) assembly
Without Air Conditioning
  1. Disconnect the negative battery cable.
  2. Remove the air cleaner or air inlet duct, as necessary.
  3. If necessary, Remove the speed control module and the washer fluid reservoir.
Fig. 3: To remove the blower motor, first disconnect the electrical wire harness plug...
Fig. 4: ...then remove the blower motor cooling tube from the motor
  1. Disconnect the wire harness connector from the blower motor by pushing down on the connector tabs and pulling the connector off of the motor.
  2. Disconnect the blower motor cooling tube at the blower motor.
Fig. 5: Remove the blower motor attaching screws and the washer fluid reservoir...
Fig. 6: ...then slide the blower motor from the housing. Take care to not damage the blower wheel (arrow)
  1. Remove the 2 screws attaching the blower motor and wheel to the heater blower assembly.
  2. Holding the cooling tube aside, pull the blower motor and wheel from the heater blower assembly and remove it from the vehicle.
  3. Remove the blower wheel push-nut and/or clamp from the motor shaft and pull the blower wheel from the motor shaft.
To install:
  1. Install the blower wheel on the blower motor shaft.
  2. Install the hub clamp and/or push-nut.
  3. Holding the cooling tube aside, position the blower motor and wheel on the heater blower assembly and install the 2 attaching screws.
  4. Connect the blower motor cooling tube and the wire harness connector.
  5. Install the vacuum reservoir on the hoses with the 1 screws.
  6. If removed, install the speed control module and the washer fluid reservoir.
  7. Install the air cleaner or air inlet duct, as necessary.
  8. Connect the negative battery cable and check the system for proper operation.
With Air Conditioning
  2. In the engine compartment, disconnect the wire harness from the motor by pushing down on the tab while pulling the connection off at the motor.
  3. Remove the air cleaner or air inlet duct, as necessary.
  4. If necessary, remove the solenoid box cover retaining bolts and the solenoid box cover.
  5. Disconnect the blower motor cooling tube from the blower motor.
  6. Remove the blower motor mounting plate attaching screws and remove the motor and wheel assembly from the evaporator assembly blower motor housing.
  7. Remove the blower motor hub clamp from the motor shaft and pull the blower wheel from the shaft.
To install:
  1. Install the blower motor wheel on the blower motor shaft and install a new hub clamp.
  2. Install a new motor mounting seal on the blower housing before installing the blower motor.
  3. Position the blower motor and wheel assembly in the blower housing and install the attaching screws.
  4. Connect the blower motor cooling tube.
  5. Connect the electrical wire harness hard shell connector to the blower motor by pushing into place.
  6. If removed, position the solenoid box cover into place and install the 2 retaining screws.
  8. Connect the negative battery cable and check the blower motor in all speeds for proper operation.
Hope this help (remember comment and rated this).
Apr 23, 2010 | 1996 Ford Explorer
How to replace the blower motor fan assembly in a 2000 GMC Yukon XL K1500 4X4
Blower Motor Removal & Installation Delphi
Blower Motor Replacement (Delphi)
To Remove:
  1. Remove the instrument panel sound insulator panel (if equipped).
  3. Remove the blower motor insulating cover screws.
  5. Pull the retaining tab down and rotate blower motor counterclockwise to remove.
To Install:
  1. Position the blower motor and turn assembly clockwise until tab locks in place.
  2. Install the blower motor insulating cover.
  4. Install the instrument panel sound insulator panel (if equipped).
Visteon
Blower Motor Replacement (Visteon)
To Remove:
  3. Remove the blower motor screws.
To Install:
  1. Position the blower motor and install mounting screws.
  2. Connect the electrical connector to the blower motor.
  3. Install the instrument panel sound insulator panel (if equipped).
Oct 02, 2009 | 2000 GMC Yukon XL
Blower motor
PART 1
If all blower speeds are not working I would check the blower, but if only one speed is not working I would check the resistor block for the blower it controls the speeds. they use 2 different blowers in this truck I have to sent a second message with the rest it will not hold it all inthis message.
2001–05 Models With Delphi Blower Motor
c93043c.jpgPull the retaining tab down while turning the blower motor counterclockwise in order to disengage the blower motor
To install:
  2. Install the blower motor to the heater/ventilation module. Turn the blower assembly clockwise until the retaining tab locks into place.
  3. Install the blower motor insulating cover.
  4. Connect the electrical connector to the blower motor.
  5. Install the blower motor insulating cover screws.
    1. Tighten the screws to 14 inch lbs. (1.6 Nm).
  6. If equipped, install the sound insulator panel
Nov 27, 2008 | 2004 Chevrolet Silverado
Napoleon Fireplaces Napoleon F45 GDS50 Gas Stove On/Off Hand Held Battery Operated Remote Logo
Top Napoleon Fireplaces Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Napoleon Fireplaces Kitchen Range Expert? Answer questions, earn points and help others
