Question about Copystar Office Equipment & Supplies
Mita Copystar CS2013 error code C63 - Copystar Office Equipment & Supplies
2 Suggested Answers
SOURCE: mita copier error code c63
Fuser error - blown fuse, lamp, or thermistor.
Posted on Mar 22, 2009
C6940 error code on 5500i
Try compressed air or a new fan motor as suggested here:
http://www.copytechnet.com/forums/kyocera-mita-copystar/125813-code-6940-ih-fan-motor-taskalfa-5500i.html
Jan 10, 2018 | GPS
How to remove C6400 error in kyocera km 6030
http://www.copytechnet.com/forums/kyocera-mita-copystar/11146-kyocera-km-4050-c6400-error-codes.html
Dec 02, 2016 | Kyocera Office Equipment & Supplies
What does 'no cartridge' error mean??
Most likely there is no cartridge installed or the cartridge is not locked in correctly. Take out the cartridge and reseat it..
Mar 29, 2016 | Kyocera Mita Fs-1016 Mfp Multifunction;...
I have a print mode error on my Kyocera Mita CS-2050 KX How do I reset the copier?
what the error code ?
if c6xxx you need to rest by program 163 just tell me the error code and i'll help you
thanks
Aug 10, 2010 | Copystar CS-2050 All-In-One Printer
Mita DC1435 Copier shows a C63 error message
you have a fuser code. you will need to test the fuser lamp, thermo fuse and thermistor with a vom with machine umplugged. open the front door and the clamshell. remove the orange fuser cover. t. remove the back cover. remove the bottom black cover. unplug the lamp, and thermistor. go to the fron of the machine. just to the right of the fuser on the frame is a black screw. remove it. now tip up the fuser 97 degrees and slide it to the left it will come out. now test the lamp with ohms, continuity, do the samae for the fuse. you will need ti remove the thermistor with one screw. put your finger onit. put he meter at 200 ohms and it should change vlaue. good luck
Dec 26, 2009 | Office Equipment & Supplies
Mita copier error code c63
Mar 22, 2009 | Kyocera Mita Office Equipment & Supplies
Error C63
That is the same as a Kyocera Mita DC 1470.
Error C63 is a fuser related error:
Broken fixing unit thermistor wire
• The fixing unit thermistor output voltage does not exceed 0.039 V DC within 7 s after fixing control has started with the fixing temperature remaining below 100°C/212°F (fixing unit thermistor output voltage: 1.71 V DC).
I can provide for you a full service and parts manual from Mita in PDF form for a nominal fee. Contact me for more info here.
Jan 07, 2008 | Copystar CS-2114 Copier
21 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
Tammie Duggan
Tammie Duggan
Timothy Van Der...
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
