Question about Wolfgang Puck Salt & Pepper Mill Set
How do you load the salt and pepper in it ? - Wolfgang Puck Salt & Pepper Mill Set
Salt and pepper grinders how to clean
warm soapy water, you can put some soapy water in the grinder, shaker and shake it vigorously to remove any pepper or salt that is stubborn, but hot water will dissolve the salt and loosen the pepper.
Sep 29, 2014 | Cuisinart Salt and Pepper Grinder,...
I am doing an experiment. i am using water. I am trying desolve salt,grits and pepper in water. would water be my independent variable and the salt, grits and pepper be my dependent variables?
Hey there,
Dependent variables are the output of certain actions or variations in the independent variables. In this case, the dependent variable would be the sludge you create. The water would be a constant medium to the independent variables grits,salt, and pepper
Oct 04, 2013 | Finance
How to load peppercorns into trudeau 0716840
I found the following webpage on your grinder: www.shoptrudeau.com/v/vspfiles/images/instructions/0716840.pdf
Just in case the link doesn't work, it looks like the top (salt) part just pulls off the bottom, pepper grinder part. With the top off, there's a hole to pour the peppercorns into.
Jan 20, 2013 | Trudeau 0716840 Click Combo Pepper Mill...
Stupid question but how do you refill the pepper grinder of the Octo Combo? I don't consider this an appliance since it doesn't use electricity or batteries but couldn't figure out another category for...
Hi, from the photos I see on the web, it looks like you hold the salt chamber and then unscrew the nut on the top of the unit. I would say that you need to then pour out the salt into a small container, and then grasp the bottom (pepper chamber) and pull up on the salt chamber to separate it from the bottom chamber. Fill the pepper chamber and then replace the salt chamber and fill with salt, replace salt cover and then replace nut. I hope this helps.
Jan 02, 2011 | Vacuums
Have a used cooker-no instructions. What pressure/for how long to cook stuffed peppers?
Hi. 15 psi for 20 minutes. Here is the recipe STUFFED PEPPERS Printed from COOKS.COM
1 lb. hamburger
1/2 c. uncooked rice
Onion
Onion salt
Garlic salt
Celery salt
Tomato sauce
Green peppers
Combine hamburger, rice, onion, seasonings, and a half can of tomato sauce. Stuff mixture into peppers loosely. Dot with butter. Pour remaining tomato sauce over pepper. Place in a pressure cooker. Pour water in to almost cover peppers. Pressure cook for 20 minutes.
Jun 24, 2010 | Microwave Ovens
Wolfgang Puck Salt & Pepper Mill Set Logo
403 people viewed this question
Top Wolfgang Puck Home Experts
john h
Tom Chichester
Are you a Wolfgang Puck Home Expert? Answer questions, earn points and help others
