Question about Janome MyLock 634D Mechanical Sewing Machine
Do I change the plate
Rolled hem for empisal overlocker
5 Suggested Answers
bargainbox
  • 1388 Answers
SOURCE: Ezy_Lock 304D
This may be too small to read, if so, email via
www.bargainbox.com.au and I shall send it on........remember to only ever use the R needle, so you only have 3 threads.
To move the Rolled hem arm, you will need to release the upper knife (knob on left inside cover....push to the right and blade moves approx 6mm) so you can slide the small metal tongue to correct position for:
N = Normal
R = Rolled
Posted on Feb 17, 2008
  • 4 Answers
SOURCE: rolled hem or rolled edge
You need to disengage the cutting blade by openingfirstly opening the front and left hand side covers. pull on the larger of the two silver knobs and slide the red lever towards you. I'm not sure what the tension settings are, but I'm certain you need to reduce them a fair bit to aid in the rolling effect. I only use 3 threads when doing a rolled hem.
My description isn't too detailed but I hope it helps!
Posted on Jun 11, 2008
  • 1116 Answers
SOURCE: Rolled hem
Here is a tutorial - http://www.wonderhowto.com/how-to-rolled-hem-foot-sewing-machine-240603/view/
I have to practice with scraps first.
Posted on May 08, 2010
RichSew
  • 184 Answers
SOURCE: light is on but won't sew
Sounds like either the foot control or the motor has failed. The foot control is the easiest to replace, you should be buy a replacement control for about 30.00.
Posted on May 27, 2010
How to set Bernette serger 203 for rolled hem
Be sure you have the proper foot for your machine to make a rolled hem.
Bernette 203 How to use rolled hem foot have the one page manual but it...
Sew Inspired Serger Rolled Hem Tips
In case you don't have a manual, you may be able to glean some information here:
Sergers Overlockers
need manual for the Bernina Bernette 203 overlocker
Aug 31, 2016 | Bernina Sewing Machines
I need help in good tension for rolled hem in empisal 606D overlocker
Your owner's manual should have instructions for rolled hem settings. My Bernina manual has a the following settings:
Medium weight fabric
80/12 Universal needle
3 cones serger thread
Upper looper 3-5
Lower looper 7-9
Left needle (no thread)
Right needle 3-5
Stitch length 1-1.5
Cutting width 2-3
Differential feed N
Can use woolly thread in the upper looper, but the tension may need to be loosened since the woolly nylon thread will stretch.
Make It Handmade Threading Your Serger or Overlocker
Dec 19, 2015 | Sewing Machines
Can a Empisal Electronic Overlocker 760DE do topstitching?
Thats a 4 thread serger, you cant do a top stitch unless its a 5 thread
Sep 19, 2014 | Sewing Machines
I want to know how to hem with my empisal s4d overlocker
check with
sewvacdoctor.com
a1sewingmachine.com
you may need to contact these websites by email
also try youtube & ehow for video's
Apr 16, 2012 | Sewing Machines
Juki MO-634DE Stiching
I tried to find this on the Juki website but its obviously a previous model so not much info on there. But did find it listed elsewhere as a 3/4 thread overlocker.
So I'd guess at the following, it probably seams a four thread marrow (overlock seam) made with two needles and two loopers. And a three thread overlock seam where you use either the left or right needle, this would give you either a narrow or wider 3 thread seam. Image below of 3 and 4 thread overlock seams.
Lastly, I would suggest that the D denotes Differential feed, this is a feature that controls the two feed dogs in the machine and gives you the ability to set them to move at different speeds - very handy to control the fabric feeding but also used decoratively for lettuce edging.
Rolled hem - most overlockers of 3/4 variety will also do a rolled hem; however, I can't actually confirm if this model does or not. But look around for a retractable stitch ****** in the foot or needle plate or a second needle plate in the accessory case. Rolled hemming is also very useful and most models will do it now; just variation in how you actually set it up to do so. Bernettes you flick a lever in front of the needle/foot area, earlier Elnas like the L3 and L4 you needed to change the needle plate and a little ****** in the presser foot.
Of course, you could email the local distributor for Juki in your country and ask them and this may be the best way to check. Just copy this into your browser
http://www.juki.co.jp/juki_form/home_e/toiawase_form.html to go to their contact us page.
Jan 10, 2012 | Juki Sewing Machines
What setting are the three threads set on for a rolled hem on a singer ultralock l4sh654 and what is the lever by the plate for?
Rolled hemming on any overlocker is usually achived the following way. Right hand needle only.
Blade over to the right usually to cut wider than normal but you can vary this to suit the fabric and stitch width you want.
Thread in this needle and the upper and lower loopers. If you can source any, use woolly overlock thread in the upper looper, this fluffs out when not tensioned and covers the fabric to give the look of solid stitching. Change upper looper tension to about 2 and lower looper tension to about 6 or 7.
The lever by the plate is usually to control the little stitch finger where the stitches are formed, move it backwards and it should move back towards you?? If this happens, then you want it in the retracted (towards you) position for rolled hemming so the stitching is much smaller and the fabric can roll. Normally this stitch finger holds the fabric firm for the loopers to form the stitch over for your normal 3 or 4 thread overlock.
Now test stitch and see how it looks. Tighten the lower looper thread so it lays right beside the needle on the underside. You may need to then tighten or loosen more the upper looper, you want the upper thread to wrap all the way around to the underneath against the lower looper thread and needle.
The cut edge of fabric should roll to underneath inside your seam. Once you've got this happening, turn the stitch length down to 0.5 or so to close it right up tight. This uses heaps of thread so I usually test everything else, then close it up at the end to minimise waste.
Hope this makes sense, good luck.
Sep 22, 2011 | Singer 14SH654
I am not getting an even rolled hem on a heavier fabric. I am only using 3 cones of Maxi Lock.
You can not do a rolled hem on heavier material. It is only for thin cloth. You have to do a 3 thread narrow edge on heavier cloth.
Aug 02, 2011 | Baby Lock Imagine
Bernette 134D
Stitch length should be set between 1 to 2.
May 26, 2017 | Sewing Machines
Brother Serger 634d
where can i buy a new thread tree for my 1034d brother overlocker from betty c
Oct 30, 2008 | Brother Lay-In Thread Serger Mechanical...
Janome MyLock 634D Mechanical Sewing Machine Logo
64 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
