Question about Samsung RF266AEPN
What is the rubber door seal product number
Door seals are cracking.
fridgetech
  • 473 Answers
SOURCE: Warm to Hot molding that seals the doors
Either the fan motor has gone bad or the coils under the fridge are too dirty. Both will cause a no cool situation and cause this area to become too hot. Part of the coil runs thru the cabinet in this area to prevent sweating. This is a good indication of dirty coils or a bad/weak fan motor. If your fan was noisy I would replace it before it goes out completely. This excessive heat will lead to premature compressor failure.
Posted on Nov 11, 2007
SOURCE: Door open signal flashing -
First check to see that the door switch is closed fully when the door is closed. Tape it fully shut to make sure
Posted on Jul 17, 2008
cosatto
  • 29 Answers
SOURCE: my refrigerator door won't stay closed!
Don’t mess with this or you could invoke the manufactures warrantee. Contact Customer Services
http://www.samsung.com/uk/support/onlineservice/onlineService.do
Posted on Dec 10, 2008
  • 291 Answers
SOURCE: door seal hot
The manufacturer runs a freon line through the cabinent so there will be no condensation on the case where the doors seal. This is only supposed to be lukewarm, so if it is hot then you have one of several problems. If your condensor under the refer is dirty it can cause this. If your condensor fan motor is burned out or running slowly it can do this. If you have a bad compressor it can do this. Check these and see if this takes care of your problem
Posted on Dec 16, 2009
  • 34186 Answers
SOURCE: Refrigerator door seal has gap, and the alarm keeps going off
My refrigerator as delivered had noticeable gaps in the sealing gasket. The solution is to adjust the doors to eliminate the gap. The door hinges allow for adjustment by loosening hardware, adjusting, and tightening hardware again.
Posted on Sep 09, 2012
GE washer Went finish washing why is their water on rubber on door
I asume the water is on the door ( rubber seal)
is the seal cracked or ripped anywhere
Feb 11, 2015 | GE Washing Machines
Leaking from motor
Water Inlet Valve
If the dishwasher is leaking water the water inlet valve might be defective. If the water inlet valve sticks open, it will allow water to fill the dishwasher continuously. Some customers report that they see clean water filling the bottom of the dishwasher after it's been sitting all night or for a couple of days. If this happens, turn off the water that is supplying the dishwasher. This is normally a valve under the kitchen sink. Then, replace the water inlet valve, it cannot be repaired. The water valve needs at least 20 lbs pressure to shut off properly. If your water pressure is to low replacing the valve may not solve the problem.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Center Wash Arm Assembly
If the dishwasher is leaking water, the center wash arm assembly might be cracked or split. This can allow a jet of water to spray toward the door seal, causing a leak. If a crack or split in the center wash arm assembly is found, replace it. There isn't any glue that will hold the part together inside the dishwasher.
Lower Wash Arm Assembly
If the dishwasher is leaking water the lower wash arm assembly might be defective. If the lower wash arm has a crack or split on the end, it can force water to spray directly toward the lower part of the dishwasher door. Then, the water can be forced under the door and onto the floor. Check the lower wash arm for any cracks or splits and replace it if necessary. Also make sure the screws are tight in the wash arm support. If the screws are loose, water can spray out the side of the pump and cause a leak.
Upper Wash Arm Assembly
If the upper wash arm assembly is broken or cracked it can cause water to spray very forcefully toward the seams of the door, causing a leak.
Door Seal
Every dishwasher door has a door seal. If the dishwasher is leaking water, it might be that the door seal is defective or worn out. Try closing the dishwasher door on a dollar bill and see if the door seal is making good contact all the way around the door. If not, replace the door seal. If the door seal is good or has been replaced and there is still a leak check the door hinges. If the hinges are bent the door will not close properly and the hinges will need to be replaced.
Dishwasher Door Gasket
God bless youc9c8c0e9-8a93-431d-b16a-9b8d97f35d28.gif14b36f01-1d58-4f2a-8f54-fc14feec17e3.jpg
May 23, 2013 | KitchenAid Dishwashers
Leaking from top
follow the next step, for test. God bless you
Water Inlet Valve
Door Seal
Apr 05, 2013 | Whirlpool Dishwashers
Front load washer door seal is detached
The seal appears to be spring reinforced. you may need to remove the door partially and rewrap the spring around seal. or if broken or cracked try to replace or fix with a sheet rubber and rubber cement. May be an old bike tube!? hehe
Mar 02, 2013 | Washing Machines
Rubber door seal problem
In my 13.5 years experience I have never experienced a door seal coming away from the drum!!!
If this was the case then you would have a major water leak!!!
Does the door seal look twisted at all?
Have a good look at the seal. Is there any black mold on the seal?
If the seal has come off then I would need to guide you through the refit process.
Please email me on: aardvark.repairs@btinternet.com and I will email you back my phone number
Regards
Aardvark Repairs
Nov 17, 2009 | Washing Machines
Slimy mold in rubber seal
Hi, Just dry the seal after a wash and leave the door open just a little. Leaving the door cracked will also help with the smell allowing air to circulate through the machine. ALL front loads have this problem with mold and that strange smell.
Sep 05, 2009 | Washing Machines
Water leaking from door
This video will show you how to change a door seal on this Bosch front loader washing machine to stop leak
we have all bosch repairs in our channel
You can get seals on eBay
Aug 29, 2009 | Bosch Washing Machines
Water inside the refrigerator.
check the door seals and make sure when the door closes,it's sealed completely around both doors.Also make sure the door seals are not cracked or hard and brittle.A good preventive maintence is to rub a little mineral oil on the door seals/gaskets once a month. DO NOT USE VASELINE as it contains petroleum and will harden the rubber. If you have a switch that says"ON" to reduce exterior moisture" please turn it on.Remember, as long as no outside air enteres the fridge,you won't have water inside. Also shorter door open times will reduce interior moisture.
Aug 26, 2009 | Refrigerators
Front load washer leak
This could be the rubber seal or the door lock. If the door lock is not pulling it tightly closed then it needs to be replaced. Check the seal really closely and make sure there are not cracks and it does not look deformed
Feb 16, 2009 | LG WM2277H Stainless Steel Front Load...
Small crack in rubber seal
This video will show you how to replace the Bosch washing machine door seal with step by step guide on the process
Aug 06, 2007 | Bosch WFR 145 Front Load Washer
Samsung RF266AEPN Logo
16 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
