Question about True T-35
T-35 reaches 32 degrees temperture then few minutes goes down to 45 degrees and stays there for about 10 minutes
  • True Master
  • 5,323 Answers
My guess the thermistors
Posted on Mar 17, 2015
How do I input Degrees-Minutes-Seconds to convert to Degrees? Vice-Versa.
On any calculator, let's convert degrees-minutes-second to degrees and then we will do the reverse.
Let's start with the number of seconds in a minute - 60, so we must take the seconds and divide by 60 to get the number of minutes. Next, add the number of minutes. The number of minutes in a degree is 60, so we take this total and divide by 60. Now we add the number of degrees to get out final answer.
Example: 35 degrees 50 minutes 32 seconds
(32/60 + 50)/60 + 35 = 35.842222 degrees
Just out of interest, let's start with 35.842222 degrees and convert it to degrees-minutes-seconds. We know it is 35 degrees, the whole number. Now we have to determine the minutes and seconds. Start by subtracting 35 to get the decimal 0.842222. Now multiply by 60 to get the number of minutes. I get 50.5332. Subtract 50 from this and multiply again by 60. I get 31.9992, which rounds to 32 seconds.
Good luck.
Paul
Jul 06, 2015 | Texas Instruments TI-36 X Solar Calculator
IPhone 5 temperature limit?
The iPhone is a very durable piece of equipment; it is built to have an operating ambient temperature of 32 to 95 degrees F (0 to 35 degrees C) however it is not built to withstand temperatures of -4 to 113 degrees F (-20 to 45 degrees C)- which means you should probably think about getting a different phone.
Sep 16, 2012 | Apple iPhone 5
My GE Refrigerator model GSL25JTFBBS stay in
Good day,
35 minutes would be considered nominal. That is the amount of time needed to heat up the cooling coils behind the rear panel in the freezer compartment, and then allow it to drain the condensate water out the drain.
The defrost cycle is made up of 2 parts.
The first part involves shutting all fans and compressor off, and turning on the heater/heaters mounted on the bottom of the cooling coil to above freezing. About 10 to 15 minutes.
The second half occures when a defrost thermostat mounted on the top of that coil senses the coil is above freezing. It cuts the power to the heaters, and lets the system just idle, while the water is allowed to drain out of the drain.
If that tstat is working properly, the food temperature is affected slightly but never to an above freezing condition.
The thermostat is a small 1" round disk clipped to the top of the coil.
Only one possibility, but that tstat could be hanging allowing the freezer coil compartment to reach a very high temperature. If so, it needs replaced.
You should also check to see if both fans and compressor start running as soon as the cycle is done.
Mar 12, 2010 | GE CleanSteel GSL25JFTBS
The humidifier only stays on for a few minutes even if it is on the highest setting
Not sure where you are located (Northern US?) but it really isn't cold enough for the air to hold much water. It is shutting off because the air in your home is already at 40-45%.
Nov 17, 2009 | Aprilaire 600 Humidifier
Find cos 32° 45'
Look at the column of keys under the ALPHA key. You have the integral, the square root, and then the key that has a degree sign, an apostrophe and a double closing quotation mark. That is the one you use to enter the angle in sexagesimal notation. To simplify my task I will symbolize the key with [DMS], degree, minute , second.
To calculate cos (32° 45')
you press
[COS] 32[DMS]45 [DMS] ) and press [=] The result si 0.841039013
Hope it helps.
Nov 08, 2009 | Casio FX-115ES Scientific Calculator
Hotpoint 14.2 cu ft top freezer refrigerator -- at least once a day, according to repair company, the "heater" comes on in the freezer to defrost unit. At that point the temperature in the freezer slowly...
well for one thing i have never of a home frige unit have a heater unit on it all stores have a heater unit around the doors so the door opens easily current fridges work on a simple fan cycle the movement of the air from the freezer goes down the fridge to keep things cold and the food in the frezer frozen all this is controlled buy venting of the air from the freezer you open and close the vent to direct the cold air flow from on top to the bottem for coldness and that s all it does. i would call the better business bearu and check there standing s or a second opinion and you gathere the information good luck
Aug 10, 2009 | Hotpoint HTR16ABSR Top Freezer...
Siemens RDE20.1 upper temperture setting
Hold the return and + button at the same time for at least three seconds, then adjust the indicated temperature down which tricks the thermostat in heating to a higher temperature before the set point is reached.
Dec 09, 2008 | Siemens Efficient Networks SpeedStream...
My Kitchen Aid Supuerba top covection oven will heat to set temp 350-400 then drop over 100 degree's but still read on digital display 350 or 400
how do you know it is dropping 100 degrees ?
If the set temperature is 350-400 the heaters will work untill the thermostat will read that the temperature is reached - after that the heaters will shut down and the temperature will drop...and after few minutes when the temperature goes below thw set point (in this case 350-400) the heaters will turn on again - this will happen for the duration of the timing you have selected (example 45 minutes)
Oct 04, 2008 | KitchenAid Kitchen Ranges
Sony SLV-SE820 VHS VCR
Uh oh. If you have already unplugged this unit and allowed to reset after 5 minutes, it will be time for a service visit...accordianman
Feb 11, 2008 | Sony SLV-SE820 VHS VCR
Kenmore electric oven
Sears Kenmore Electric Wall OVen, Mod.#9114012192 purchased in 1993. Set oven for 425 degrees, reaches set temperature, stays on about 10 minutes and temp. display goes out and oven starts cooling down. Will not stay on desired temp.to cook. Can you tell me what my problem is? Thanks. Doug.
Dec 02, 2007 | Ovens
True T-35 Logo
80 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
