I can not acccess my 192.168.0.234 to reset my sitecom 300n range extender
Not showing in my laptop 192.168.0.234 to set sitecom 300n range extender
2 Suggested Answers
LaptopNomad
  • 12 Answers
SOURCE: Sitecom WL-130 Wireless Network Range Extender
For extending / repeating WIFI signals there's quite a bit of details to know about.
Read about repeating a WIFI signal with a sitecome WL-130 WIFI repeater here.
Posted on Oct 01, 2009
I got a problem in connecting my samsung galaxy GT-7500 to sitecom extender 300N .. I have tried to change the IP address but it doesn't work with me . Any help plz?
Which modes are you trying to use this Sitecom? If you have the Sitecom as your Access Point (AP Mode), then you would need a LAN connection to your internet gateway (DSL, Cable Modem, etc). I didn't see any LAN hook up so I assume you are trying to use it as a wireless repeater. So you need to configure the unit differently. The 3rd mode is called Bridge mode. Again, you need to have a LAN hook up to your local network with a router or network switch.
Because your Tablet is connecting to the Sitecom okay, which mean that you either have the Sitecom setting for AP mode or Bridge mode. And the reason it didn't give you access to internet because there is no internet gateway connection to the Sitecom (LAN). I hope this answer your question (or confuse you totally).
Feb 15, 2013 | Computers & Internet
I cannot switch off the DHCP in the WL330 sitecom
You can find the user manual here: http://www.sitecom.com/wireless-range-extender-300n/p/714. I don't know your specific software, but on mine you have to click on every page to save changes. If you make all changes then save it will not save all changes.
Nov 28, 2012 | Belkin Computers & Internet
Hi, I'm having problems connecting to the router (Virgin) to my bedroom from lost of signal strength, so i brought Sitecom Wireless Range Extender 300N to boast the signal. I've installed the Range...
1. did you first try to connect to the router via wire directly with it in the same room? then set up the wireless to work in the same room too.
2. once you've done that and it worked then move it to your bedroom. If it doesn't work there it could be that there is something inbetween the two rooms that is blocking the signal...ie a furnace can do that
3. if it won't work try relocating the router to another location. Try a different location in the same room first
but as i said , first get it set up and running in the same room so you know for sure it works.
Mar 21, 2011 | Computers & Internet
I have a Sitecom wireless range extender 300N nd am trying to set it up following the manual. I reach the point where I have to enter the IP address into my web browser to be able to put my user name and...
I have had 2 of these extenders, first one worked until I got a virus and had to reset the settings. After that it only worked for a minute at a time, lost my temper and smashed it with a hammer. Got another one, determined not to smash it I went through the instructions following them step by step. I did this twice and STILL nothing. Works when connected to my router via an Ethernet cable, does not work wirelessly. I am resisting the urge to throw it out of the window and will be returning it to maplins later on today. Load of ****!
Jan 06, 2011 | Computers & Internet
Can not access sitecom 300n with factory preset 192.168.0.234 or find trouble shoot in manual
open Network Connectdisable the wlan adapter first. open Network Connections from Control Panel and disable the wlan adapter first.Then Open Properties of the (wired) LocalArea Connection. Scroll down to TCP/IP and Change the Properties: IP=192.168.0.2 and Subnet Mask=255.255.255.0. Then connect the Sitecom using the wire (UTP). You should be able to browse with an internet browser to 192.168.0.234 now. After setting up the Sitecom disconnect the wire and enable the wlan adapter again.
May 15, 2010 | Computers & Internet
My Sitecom 300N repeater resularly loses its connection to my BT homehub. I think this is when the H homehub goes down sometimes. Resetting the Sitecom from scratch is a pain but resolves the problem. 3...
I also had this problem when the BTHomeHub goes down, power loss etc. I seem to have fixed the problem by changing the wireless config in the homehub to use a fixed channel, (the default is automatic which means it changes each time it restarts). This has been running trouble free for a couple of weeks through a number of power outages.
Can't help with Qs 2&3, get the same problems but less of an issue now that the thing works all the time.
May 16, 2010 | Computers & Internet
Problem with sitecom wl-130 connection
I think I have the solution: you have to click on the basic settings tab, then n "site survey" button, then (optional) on "refresh" button.
Now you will get the information about your network, and you just have to check the channel number of the signal from your main router. then you have to set that channel in the "channel" button of the basic settings tab. You also have to choose Universal repeater as working mode of the sitecom device, instead of Access Point.
Hope it helps.
By the way, all these settings should be automatic in such a device.... But this sitecom range extender is ****.
I suggest everybody is reading: DON,T BUY THIS ITEM!!!! Spend 10 bucks more and get a working one!!!
Jun 01, 2008 | Computers & Internet
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
