Question about Nordic Track NordicTrack COMMERCIAL 1750 Treadmill
Belt won't move
The tread belt will not start/move
I have it all set up..programmed a work out...it starts to work..but the tread itself that you walk on wont run..what do I do?
From the User manual....here
http://servicedocuments.com/pdfs/_0005_SOLE/_0005_SOLE_01_Treadmills/003_OwnersManuals/2010_2011_SOLE/F63_F65_OM_810.pdf
'1.If the belt moves, but stops after a short time and
thedisplay shows "LS", run calibration. (on next page)
2.If you press start and the belt never moves, then
the display shows LS, contact service.
Sep 14, 2014 | Sole Fitness F63 Treadmill
Tread ajustment
under the shroud cover there is a bolt that loosens the tension on the belt...be sure the belt sensor "sees" the belt as that is why you have an E-1 error code
Dec 03, 2013 | Exercise & Fitness
Proform_xp_800_vp My treadmill just starting
13c5a4bc-2f6e-452d-8456-f22742c60fa8.gifsee the video and lube, please do the same with rollers bearing front+back. Test the drive belt motor, and replace the belt if necessary
If after you lube the problem remain, is TIME to replace the DECK belt.
God bless you
Aug 02, 2013 | Exercise & Fitness
Tread belts won't move.
send message to company then check out there site was there a recall on them.
Aug 12, 2012 | Bowflex Treadclimber TC5300
Hi my hotpoint dryer wont turn please help
You have the belt on wrong. There is a side with numbers or writing on it and ribbed side like treads. The tread side should be facing down, making contact with the drum. If the other side is touching the drum then whenever clothes are put in the belt will slip causing the drum not to turn.
Apr 25, 2012 | Washing Machines
When starting, the motor starts sluggishly. It sounds different and goes very slowly. At higher speeds, way high, it runs fine. Speed censor says one thing, but tread moving very slowly.
Treadmills are usually made up of various components. The rolling surface (tread) is usually placed on a set of rollers when the unit starts due to the low friction between both the surface (tread) and the rollers the surface (tread) starts slowly while the rollers move regularly and the sensor is placed on the movement of the rollers.
What you need to do is get the unit serviced usually there is a way the tread it tightened to have better grip on the rollers. This method differs from one make to the other so get an expert who knows about proform rollers. Once the system is tightened the problem will be solved.
Hope this solution has been helpful?
Jan 05, 2011 | Proform 595LE Treadmill Walking Belt
Tread is sliding and rubbing agianst right side of track.
Make sure treadmill is running when you adjust belt. The treadmill belt tracks as the belt goes around. I usually put machine on 2-2.5 if belt is not rubbing instantly. If belt is already against plastic, turn adj. counterclockwise on the opposite side about one full turn. You can usually move belt with your foot to see if it aligns any with turning on the treadmill. Once belt is not rubbing, turn treadmill on and continue alighing the belt.
Jul 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Your Problem: jazfit-750 Treadmill motor will not turn on
DEAR
AT FIRST YOUR MOTOR CONTROL BOARD IS DAMAGE
I can turn it by hand it turns smoothly and the tread moves fine and the belt from the motor to the tread is good
Mar 18, 2017 | Exercise & Fitness
Nordic Track NordicTrack COMMERCIAL 1750 Treadmill Logo
26 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
