Question about Home Security
My Sentry A3821 safe will not close
I have my password and opened the safe and now it will not close. I changed the batteries and still nothing.
SOURCE: sentry safe msw3517
I have a Sentry Safe MSW3517 and forgot my code.
Posted on Nov 19, 2008
SOURCE: Changing the code on my Sentry Safe S3877
how to change the on sentry safe s3877
Posted on Jan 20, 2009
SOURCE: know combination, but cannot open sentry safe 1250
If you know the combination:
1) Turn the dial to the left a few complete rounds, then stop on 1st number.
2) Turning the dial to the right, pass up the 2nd number once, then stop on it on the next round.
3) Turn the dial to the left directly to the 3rd number then stop.
The handle should open now.
Posted on Mar 18, 2009
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
SOURCE: I forgot my sentry safe password awhile how can I reprogram it.
How do you change password or code for model #AU958609?
Posted on Aug 05, 2010
White powder is leaking out of the door of my Sentry A3821 safe. What is the composition of this powder? Is it asbestos?
Sentry uses a proprietary compound concrete/water and some other "secret ingredients".
Sentry claims there is no harmful or toxic products used it's line of safes.
Seal the crack/hole..with silicone or gorilla glue etc..
Best of luck
Apr 05, 2011 | Sentry Fireproof Safe
I need to find out what the factory code is to my sentry safe model a3821 they said you had my solution and i paid but have not seen a solution yet@@@?????
Here's the link to the Owner's Manual for the safe. See the bottom right of page 3 for installation of new batteries. This model has the batteries outside of the safe so there is no reason to look into for the batteries. Once you follow these steps, you will have your resolution. http://www.sentrysafe.com/pdfs/OwnersMan uals/501664.pdf Reference: http://www.sentrysafe.com/pdfs/OwnersMan uals/501664.pdf
Jan 17, 2011 | Home Security
I have a sentry safe model A3821 need factory code to reset my code does anyone know the code?
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 16, 2011 | Sentry Safe Fire-Safe Home/Office Safe
Dead battery and safe wont open
battery cover can be removed from outside. replace batteries and try again but if you remove batteries more than 1 or 2 times in a row, safe will revert back to a factory setting. That number should have been on your instruction sheet when bought. Good luck though, I bought a Sentry A3821 and it's only 5 years old and won't open.. After help from sentry I was told solenoid is bad and no longer made. So I now have a piece of junk bolted to my floor
Oct 27, 2010 | Sentry Fireproof Safe
I LOST COMBINATION TO A SENTRY FIRE SAFE A3821
You and dozens of others tonight.
No easy fix. You need to send request to Sentry...or buy a power tool. ;o)
http://www.sentrysafe.com/customercare/Contact_SentrySafe.aspx
Jun 25, 2010 | Sentry Fireproof Safe
LOST COMBO FOR SAFE (A3821) HAVE KETS BUT NO WAY TO OPEN
I hope you registered you safe after you bought it. If not you still have a chance. Contact their support here.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
Apr 20, 2010 | Sentry Fireproof Safe
Somehow can open my sentry s3877 with the keypad.
A Safe and Vault Tech Will confirm that once you change the batteries the user code will erase and you will now have to enter the factory default that is in the owners manual and then use the programing instructions to program a new user code.
Jan 07, 2010 | Sentry Fireproof Safe
Sentry 1610 safe - battery is dying?
I have 2 Sentry 1610 Safes. A fresh alkaline battery MAY open the safe once (maybe twice), and then the same problem. I have a variable DC power supply that I hook up to the battery terminals, set to 9 volts and increase the current until the keypad responds & the deadbolt releases. Sentry has no solution for this problem, as this model is too old & they have no parts or troubleshooting. If you know someone with a small DC Power Supply, you can get your safe open / closed.
Mar 29, 2009 | Sentry Fireproof Safe
How to cahnge the battery on a sentry safe
There is a small opening on the front number panel of safe. Use a small hex screwdriver or pin to insert into opening. It will open up the front panel (slide panel to right to take off) showing you 4 AA batteries. Just replace and close panel. Very simple to do. I wish the manual show me how. Instead of trying to figure it out for hours.
Dec 25, 2007 | Optics
Home Security Logo
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
