5108t delonghi oil heater
Red knob for ?
2 Suggested Answers
SOURCE: set time on delonghi oil filled portable heaters and set start and finish times
It was very tough to find the actual manual online for your modle in English. However, you can call Delonghi customer support:
DeLonghi Customer Support: (800) 322-3848
Delonghi does have manuals for some models on their site. Take a look at this link, the model might be similar enough to yours to be able to get the information you need.
http://www.delonghiusa.com/search_results.cfm?sp_q=oil+filled+heater&sp_p=all&sp_f=ISO-8859-1&sp_w_control=1&sp_w=alike&sp_a=sp1003e79d&sp_c=5
Hope this was helpful.
have a great day!
Posted on Oct 29, 2008
THE KNOB THAT SETS LOW MED HI AND OFF
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Feb 13, 2011 | Lakewood Oil-Filled Electric Radiator...
Wires have come off inside creda 9 fin oil heater
I have one and can tell you what the colorsare and how they are connected e-mail me at b123153h@yahoo.com so I can send you a picture later today or tonight so you can see how they are hooked up.
Jul 27, 2009 | DeLonghi 9707 Oil Filled Radiator Heater
Set time on delonghi oil filled portable heaters and set start and finish times
have a great day!
Oct 29, 2008 | DeLonghi 6707E Oil Filled Radiator Heater
Delonghi TRD0715T heater
turn timer knob clockwise till arrow points to correct time (your time), there are plastic protrusions "ticks"around the knob, they move in and out, move them in for on, and out for off
select time sectors that you wish hearted to heat, each tick is 15 minutes, experiement and become profecient
Oct 27, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Delonghi MG15T Magnum Oil-Filled Radiator timer -timer keeps running?
I found the manual at this website:
http://safemanuals.com/user-guide-instructions-owner-manual/DELONGHI/MG15T-_M
I hope this helps.
Oct 13, 2008 | DeLonghi MG15T SafeHeat Oil Filled...
Vulcan oil heater
1. Check electricity is on.
2. Check oil is in the tank and valve turned on.
3. Switch the fan off at the bottom left hand corner.
4. Switch oil knob to No.1.
5. Set Air knob to No.3.
6. Operate re set button (right hand corner of heater under settings dial). Either press in until it clicks or if the pull out version pull out until it clicks.
Wait - ignition should take place in a few minutes and flames will appear on the left of the burner under the radiants.
You should get occasional yellow crests above the pure blue flame just visible below the top row of burner holes under the radiants.
After the red warning light goes out you can adjust to higher settings.
The radiants do not glow on low setting.
You can adjust the heater on to higher settings but this should be done gradually - no more than 2 settings at a time.
Some warnings:
* The unit must be correctly earthed.
* Do not use anything except heater oil.
* Never attempt to re-light the heater when it is hot.
* If the red light does not appear when the oil knob is switched on, immediately turn the oil knob off. Reasons include: Heater is too hot; Electric plug turned off; failure of ignition system.
Good luck - no responsibility taken for the advice (but it is largely copied from my Vulcan heaters instruction manual which I still have (installed in 1967).
Mar 26, 2008 | Heating & Cooling
DeLonghi oil filled heater typ.061563
Hello I have a Delonghi KR031225 found that after turning it on and it heated up it began leaking on the bottom corner on the same panel that holds the controls? What could be wrong? Is it beyond repair?
Thanks
Mel
Jan 29, 2008 | DeLonghi TRD0715T Oil Filled Radiator...
Heating & Cooling Logo
12 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
