Question about Shark SV1100 Navigator Freestyle Cordless Vacuum
Start button Why does the start button gets stuck
I have a SV1106-FS. Today the vac stuck and would not shut off. The on/off button was stuck. We had to disconnect battery to stop. Is the button broke or can I take it somewhere to get repairs.
If you are capable of repairing yourself, it is cheaper that way.
Replace the switch. Get it from the manufactured with a schematic on how to do the setup.
Jan 04, 2015 | Shark Vacuum. Navigator FreeStyle Premium...
How do I empty the canister? The red release button seems to be stuck.
Hi Julie, it's Jack at Dyson.
I'm glad to hear you've been able to resolve the issue and empty your DC44's clear bin. For reference, the correct way to empty the machine after use is shown in our official Getting started video guide.
If you'd like advice from our experts at any point, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 14, 2014 | Dyson DC44 Animal Cordless Vacuum
Kenmore Canister Vacuum Bagless is not working when I push the on button
There are many different things that could cause this. It could be the cord, the switch, a fuse, the motor, the pcb, a loose wire. If it is under warranty I recommend you take it to a Kenmore warranty center.
Mar 04, 2014 | Kenmore Vacuums
Why does the motor start, then shut off?
Check for a stuck or binding float switch
Jan 31, 2013 | Porter Cable 7812 Wet/Dry Vacuum
I transported my newly given to me by my dad tristar from Fl to LA and I can't get the reset button to start the power. The vacuum comes on, but the rug attachment is not spinning I can't get
If the rug attachment is not spinning, it is likely the drive belt has come off. Also, the entire intake area probably needs to be cleaned.
If the vacuum cleaner starts, the reset button has nothing to do with why the attachment doesn't spin.
Sep 12, 2012 | Tristar Vacuums
With microwave door shut oven continues to run
The door switch when closed seems to give a feedback to the processor which is triggering continuosly the circuit.
Please check on the board for insect secretion or dirt that seems to RUN the board when the door is shut.
Wash the board and replace, check the connectors to be tight and test.
if not there are errors in the board/ control panel which could be stuck with the start button in ON state. remove panel to confirm.
Aug 08, 2011 | Vacuums
Kirby won't start. cord got stuck and it stopped, but after I wiggled it, it worked again. Then the next time I couldn't get it to start. took cover off of cord, it looks fine, no fraying. Its an older...
The problem is most likely a bad cord. Take off the cord cover on the side of the motor unit, and pull the cord straight out to remove it. The cord can then be tested with a voltage meter, and replaced if necessary.
Jan 24, 2011 | Vacuums
The head on my guardian suddenly quit working while I was using it. The reset button seems stuck up. Are their any more reset buttons
No, that's the only one. Make sure there is nothing wrapped around the roller brush. If so, clear it. Try pressing the reset button, then start machine. If nothing, there's good possibility the switch is broken or worn out. I recommend taking to the nearest Aerus Electrolux store to allow the service tech to check it, and repair if necessary.
If you don't know where the nearest store is, follow instructions on following site.
You can also call and ask for someone to pick up the machine and take in. Just be sure to let them know you are absolutely NOT going to buy a new machine. Yours should have lots of years left in it, especially with some periodic cleaning and maintenance.
http://www.aerushome.com/storelocator/
Nov 04, 2010 | Electrolux Guardian Bagged Canister Vacuum
There is suction to the vacuum, however the brush will not turn. Any suggestions?
there is also a small reset button on the outside of the head next to the brush that you can push to get it to start spinning again. dont know officially why its happens, but i would think its there as a safety switch in case something gets stuck
Sep 25, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Pull Cord
CHORD STUCK , NOW FIXXED BUT METAL SPRING CAME OUT, WHEN WOUND BACK, HOOW DOES IT ATTATCH TO PLATIC COWL AGAIN?
May 15, 2008 | Euro-Pro PT205 Leaf Blower Powerful 12 AMP...
Shark SV1100 Navigator Freestyle Cordless Vacuum Logo
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
