Question about Shark SV1100 Navigator Freestyle Cordless Vacuum
Start button Why does the start button gets stuck
I have a SV1106-FS. Today the vac stuck and would not shut off. The on/off button was stuck. We had to disconnect battery to stop. Is the button broke or can I take it somewhere to get repairs.
If you are capable of repairing yourself, it is cheaper that way.
Replace the switch. Get it from the manufactured with a schematic on how to do the setup.
Jan 04, 2015 | Shark Vacuum. Navigator FreeStyle Premium...
How do I empty the canister? The red release button seems to be stuck.
Hi Julie, it's Jack at Dyson.
I'm glad to hear you've been able to resolve the issue and empty your DC44's clear bin. For reference, the correct way to empty the machine after use is shown in our official Getting started video guide.
If you'd like advice from our experts at any point, you can reach us by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
May 14, 2014 | Dyson DC44 Animal Cordless Vacuum
Kenmore Canister Vacuum Bagless is not working when I push the on button
There are many different things that could cause this. It could be the cord, the switch, a fuse, the motor, the pcb, a loose wire. If it is under warranty I recommend you take it to a Kenmore warranty center.
Mar 04, 2014 | Kenmore Vacuums
Why does the motor start, then shut off?
Check for a stuck or binding float switch
Jan 31, 2013 | Porter Cable 7812 Wet/Dry Vacuum
Dyson brush wont turn
Hi There is a reset switch on your Dyson that needs to be pressed when something gets stuck in the brushes. The reset switch helps protect the motor that spins the brush from damaging if something gets stuck inside the brushes. There is a little red pole that sits up behind the brushes on the vacuum head, I believe it's on the left side of the floor head as if you were behind the machine vacuuming. Try pushing this reset switch first.
Oct 08, 2012 | Dyson DC25 All Floors Bagless Upright...
I transported my newly given to me by my dad tristar from Fl to LA and I can't get the reset button to start the power. The vacuum comes on, but the rug attachment is not spinning I can't get
If the rug attachment is not spinning, it is likely the drive belt has come off. Also, the entire intake area probably needs to be cleaned.
If the vacuum cleaner starts, the reset button has nothing to do with why the attachment doesn't spin.
Sep 12, 2012 | Tristar Vacuums
With microwave door shut oven continues to run
The door switch when closed seems to give a feedback to the processor which is triggering continuosly the circuit.
Please check on the board for insect secretion or dirt that seems to RUN the board when the door is shut.
Wash the board and replace, check the connectors to be tight and test.
if not there are errors in the board/ control panel which could be stuck with the start button in ON state. remove panel to confirm.
Aug 08, 2011 | Vacuums
Kirby won't start. cord got stuck and it stopped, but after I wiggled it, it worked again. Then the next time I couldn't get it to start. took cover off of cord, it looks fine, no fraying. Its an older...
The problem is most likely a bad cord. Take off the cord cover on the side of the motor unit, and pull the cord straight out to remove it. The cord can then be tested with a voltage meter, and replaced if necessary.
Jan 24, 2011 | Vacuums
There is suction to the vacuum, however the brush will not turn. Any suggestions?
there is also a small reset button on the outside of the head next to the brush that you can push to get it to start spinning again. dont know officially why its happens, but i would think its there as a safety switch in case something gets stuck
Sep 25, 2009 | Dyson Ball DC24 Bagless Upright Vacuum
Pull Cord
CHORD STUCK , NOW FIXXED BUT METAL SPRING CAME OUT, WHEN WOUND BACK, HOOW DOES IT ATTATCH TO PLATIC COWL AGAIN?
May 15, 2008 | Euro-Pro PT205 Leaf Blower Powerful 12 AMP...
Shark SV1100 Navigator Freestyle Cordless Vacuum Logo
20 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
