Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Terminal is receiving error no modem connection
MF Digital Scribe 9000 with Picojet disc printer. Hello, could anyone please help with the pin configuration connections of the 9 pin seriel cable to mini din control cable connection from the duplicator...
Have you tried emailing tech support?
http://www.mfdigital.com/techsupport.html
Failing that, and lack of pinout, serial communications can be done with only 4 connections, Transmit and Receive (TX, RX) ground (GND) if you do it with no handshaking. You'll need Data Terminal Ready (DTR) and Data Set Ready (DSR) and or CTS/RTS (Clear/Ready to end). You may have to trial and error it.
Pin 1 - Carrier Detect (CD) - only needed for a modem
Pin 2 - Receive Data (RX) - Cross over with TX
Pin 3 - Transmit Data (TX) - Cross over with RX
Pin 4 - Data Terminal Ready - Cross over with DSR
Pin 5 - Signal Ground (GND) - Goes to other side ground.
Pin 6 - Data Set Ready (DSR) - Cross over with DTR
Pin 7 - Request To Send (RTS) - Cross over with CTS
Pin 8 - Clear To Send (CTS) - Cross over with RTS
Pin 9 - Ring Indicator - Only needed for modem
May 20, 2014 | Computers & Internet
ZTE MF190 Dialing problem
I have a unlocked ZTE Mf190 USB-Modem. When I put the SIM card in it and connect it to the computer, I am able to connect to 3G Internet via beetel connection manager. Is it also possible to send and receive SMS. But when I try to make a voice call on beetel voice call panel, I receive this error message "Dialing failed! Please try again!" . And also when I use another phone to call the SIM card line number that I put in the USB-Modem, I receive busy tone
Mar 31, 2013 | ZTE Mf190 Unlocked 3g Gsm 7.2 Mbps...
Verifone Vx570 given an error Modem Profile Not Set?
error modem profile not set appears when your Verifone VX 570 modem profile is not properly loaded or has been errased due to Tamper error or Bad RTC. Reloading back the modem profile will sometimes fix the error, but there is also a chance that your I/O module (form where you connect the power and telephone wire) is also bad, thats needs to be repaired or replaced. Call (775)358-2922 ask for Randy. Thanks.
Backside of the I/O module of VX 570
Jan 18, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
MY SAMSUNG GT-S5350(METRO 3G) WITH BSNL 3G ON CONNECTING WITH PC GIVES OS ERROR MESSAGE THE CONNECTION WAS TERMINATED BY THE REMOTE COMPUTER BEFORE IT COULD BE COMPLETED.
Feb 15, 2011 | Samsung Modem Configuration Software...
Error 734: PPP Link control protocol was terminated
hi dear, if you are facing the error 734 with n82 using nokia pc suite then i think the solution is delete the extra string in phone and modem option which is in control pannel. the path is control pannel>> phone and modem option>> modem>> select N82 USB modem then click on properties>> advanced tab>> Delete the commend. After that delete the modem settings in handset then connect. it works. just try this . . . . .
Nov 27, 2008 | Microsoft Windows Vista Home Premium with...
Dialup 56k modem not responding.help says harware failure
whts the name of the modem and the light status and , whts the error message u get when u try to connect to the internet
Nov 15, 2008 | Compaq 56K Modem
I have a problem while connecting my phone as modem to use internet ?
Please Suggest me how to find modem for this type of laptop computer ( Fujitsu FMV5MTBL3)
Oct 15, 2008 | Computers & Internet
My windows vista will not send or receive emails. When sending I receive Error 0X800CCC0F Wher nreciving I recive Error 797, Modem not found.
If you don't have a modem on your machine, you must have another way to connect to the Internet, an ethernet card, or a wireless card.
If you are connected to the Internet this way, you should change the configuration on your email account to use the connection, instead of dialing via a telephone line.
If you're uncertain what to do next, tell me the email program you are using (Windows Mail, Outlook, Thunderbird...), and how you connect to the internet, and I'll try to give you additional details.
Hope that helps!
Jul 21, 2008 | Computers & Internet
Dynamode Internal Fax Modem 56K
i had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
Jun 27, 2008 | Computers & Internet
Solve GSM CMS Errors......
I'm using also smslib and nokia 6020 phone for sending and receiving SMS, but i've some trouble with reading messages, would you please tell me the configuration for the modem, i used this one :
ModemGateway gateway = new ModemGateway("modem.com4", "COM4", 4800, "Nokia", "Nokia 6020", srv.getLogger());
Oct 01, 2007 | Microsoft Office Outlook 2003 for PC
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
54 people viewed this question
Top VeriFone Computers & Internet Experts
lolthepcman
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
