Question about Wamsutta Cool & Fresh King Down Alternative Comforter
How to WASH this comforter ??
It stinks - can it go in a washing machine??
The tumbler of my wash AEG machine stinks
There are washer cleaners you get them in the stores. You should clean the machine ones a month
Jun 16, 2014 | AEG Washing Machines
Wash down
Since down comforters are very light in weight, they confuse energy efficient front loader washing machines in how much water to add. Therefore, very little water is used, which results in a semi-damp comforter at the end of a wash. Pre-soaking the comforter beforehand would help, however, now the comforter weighs a ton, and the machine will vibrate like crazy during a spin cycle. It may be better to have the comforter dry cleaned.
Apr 28, 2014 | LG WM1812C Front Load Washer
How to wash down
Hello.. I do not recommend trying to wash a down comforter in this washer. It will not wash correctly and more than likely will not spin out. Your best bet is to take the item to a local laundromat and use a large 50lb washer if available.
Apr 28, 2014 | LG 3.7 cu. ft. Front-Load Washer - WM2240C
Machine clogged and rust and stink
to help clean the unit, do a large load of whites, extra bleach, extra-super-heavy-duty wash, hot wash and hot rinse. many small loads sometimes cause the unit to "smell up"
Sep 04, 2009 | LG WM2077CW XL Front Load Stackable Washer...
Our Maytag Washing Machine Model number MFW9700SQ1 stinks!
This is a common problem, you can run a few cups of vinager or bleach in a empty load set to hot wash and this will help. To keep it from coming back when your done doing wash wipe the door gasket down with a rag dampened with bleach and never shut the door all the way. Good Luck
Jul 16, 2009 | Maytag EPIC MFW9700S Front Load Washer
Washing a down comforter.
yes but use a gentle cycle also ck for open seams or tears in comforter first if torn may cause stuffing to come out and plug pump
May 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Wamsutta Cool & Fresh King Down Alternative Comforter Logo
54 people viewed this question
Top Wamsutta Home Experts
Donni Steen
Tom Chichester
Are you a Wamsutta Home Expert? Answer questions, earn points and help others
