Question about Garden
Types of bridge - Garden
Does an ONT Support Routing?
Query the ONT nameplate to determine whether an ONT supports routing. If "gateway HGU" is marked on an ONT nameplate, the ONT is of the gateway type and supports routing. If "bridging SFU" is marked on an ONT nameplate, the ONT is of the bridging type and does not support routing.
Apr 19, 2016 | Cell Phones
How do I find out what the ip address of the bridge so that i can access the setup page?
wire the bridge into the ethernet port on your router. access the setup page of your router and check the DHCP client table. you should see the name of the bridge there with the corresponding MAC address. Just type the ip of the bridge into the address bar of your internet browser, you should be able to access the setup page of the bridge by then.
Sep 17, 2010 | Linksys WET610N WirelessN Bridge...
How do I access the setup page of this bridge?
wire the bridge into the #1, 2, 3 or 4 port of your router. access the setup page of your router and go to the DHCP client table. Take note of the ip of the bridge.
type the ip address of the bridge in the address bar of your internet browser. then you'll be asked for a username & password for your bridge. ( default UN: & PW: admin ).
hope this helps.
Trying to run the setup cd for the wet610N on a WGR614v7 router and getting error 107 after it tries to find the device.
setting this up would be easy if you do it manualy. Just wire the bridge into your router, access the setup page of your router, go to the DHCP client table and take note of the ip address of the bridge.
Open you internet browser then type the ip address of the bridge into your address bar.
You'll be asked for a UN
Sep 15, 2010 | Cisco Linksys WET610N WirelessN Bridge...
How do you change from nat type 3 to nat type 2 on this router
To reduce the NAT
1 ) Disable the firewall in the router
2) Enable the Playstation in the DMZ
3) Make sure UPnP is Enabled
Jun 22, 2010 | Siemens SpeedStream 4200 (13A4200001)...
Bought a Belkin router model # f5d8326 4 v2 was told this worked for cable modems not working yet
Make sure the modem is configured properly so it would detect the router. Most of the time, modems now has DCHP capability, meaning it has the ability to hold the username and password you ISP has provided you. The most effective way of making modems work with routers is to bridge the modem first before connecting the router.
Bridging the modem is done by opening the interface of the modem. To pull up the interface of the modem, type the default gateway of the modem in the address bar of your browser(intenet explorer)
Look for the "connection configuration" button and choose "bridge ethernet" as the connection type.
Once the modem is bridged, connect the router to the modem, then configure the router to set the connection type to pppoe. Once done, type your username and pw your ISP have provided the save the settings. This should cpnnect you online..
May 12, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
Bridging 2 different types of router
Yes, you can bridge two different brands of routers. It is not the router but the protocol that the router uses that makes it incompatible. But because of the way you are set up you will not have any problems with different brands. Both will use DHCP to get your IP address..
Dec 26, 2008 | Computers & Internet
Modem settings for Siemens SL2_141
First of all check whether dsl yellow light is on or not.
if it is not on then contact bsnl local branch.
otherwise
remove dsl line from modem.
Then
open internet explorer
type http://192.168.1.1
username= admin
password= admin
click WAN
edit pppoe 0_35_1
connection type=bridging
encapusulating =LLC/Snap-bridge
next
again next
save
save/reboot
close IExplorer
connect DSL line.
if its work plz reply me
findme_rohit@yahoo.co.in
Sep 14, 2008 | Computers & Internet
Speedstream 4200
I keep get a NAT type 3 on my ps3. I've been told when plugging the modem straight into the ps3 it should be type 2. After looking on the net it seems that there is some type of problem because of the Speedstream 4200 Modem. Is there some type of setting I could change on this modem to make it better?
Sep 04, 2008 | Siemens SpeedStream 4200 (13A4200001)...
Wiring my subs to my alpine mrv-1000
did you read your instruction manual. does it says "it could be bridged to other amp"?. you can't make a bridge to amplifier that is not bridgeable. bridging an amp is a way which it is made through transistor type ampilfier by bridging more transistor inside and more voltage is required for bridging.
I don't know if we could do to an IC type amplifier. ask an experts about bridging IC types how to bridge maybe they know how.
and if you had an successful bridging, you may have a problem through your speakers, they may hit hard but you will experience some errors through your speakers and easy to worn.
Jan 22, 2008 | Pioneer GM-X962 Car Audio Amplifier
Garden Logo
507 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
