Question about Caterpillar Heavy Equipement Manual Dozer
T30D Clucth Paks
The forward Gear Does Not Move
I put my foot on the clucth peddle of my subaru impreza and put it in gear and nothing has anyone got any suggestion s
if car is in gear and does not move you either have a driveshaft joint damaged or the clutch disc worn out ,,, hard driving ie spinning wheels high revving inlow gears can cause this ,,,, sorry but it looks expensive either way ,,,,,
Feb 11, 2012 | Cars & Trucks
My 1997 volkswagen wont run in any gear position.the only way i can make it go is by rev up the rpms, then it will go slow. now it wont move at all.
is it a automatic or a manual car.if maual ur clucth is burned if automatic its the oil level in box to low or torque converter in box is broken.
May 21, 2011 | 1997 Volkswagen Jetta
Vw sharan I changed clucth and flywheel but some times clucth padel stays down and first gear hard to change.
sounds like the pivot for the clutch release arm has broken or the the release arm has come off the pivot.
Jan 11, 2011 | Volkswagen Tiguan Cars & Trucks
I brought a 99 gsxr about 2 weeks ago. For the past two weeks it was ridin fine every once in a while it will take a hard push to get it in 1st gear but nothing too serious. But after the rain storm i took...
I dont have your bike but have had this problem on a few bikes, for me it was the reservoir or master cylinder. pump your clutch for about 30 seconds before you shift into first if that works rebuild your reservoir failing that replace your master cylinder. I would wait for someone more knowledgeable to answer before you replace your master cylinder though.
Jun 08, 2010 | 1999 Suzuki GSX-R 600
With engin running and in gear i let the clucth out and the bike wont move could the clucth boss cause this as other clucth components are new
The clutch is still disengaged. Adjust it starting at the lever, and work your way down till you find it.
Sep 27, 2009 | 2003 Yamaha YZ 250
Clucth not disengauging....
try this.you have 2 shifter cables.one is select cable the other is shift cable.first put the transmission selector lever in neutral.then move transmission shift lever to 4th gear.depress clutch to if necessary to shift.move the shift lever to the 4th gear position until contacts stop.then you turn the adjuster turn buckle so the shift cable eye aligns with the eye in the gear shift lever.when installing the cable eye. make sure the flange side of plastic bushing at the shift cable end is on the cotter pin side.the cables should be adjusted so the clearance between the shift lever and both stoppers are equal when the shift lever is moved to 3rd and 4th gear. move the shift lever to each position and check that the shifting is smooth.
Jul 12, 2009 | 1996 Mitsubishi Galant
Stuck clutch
The clutch has rusted to the flywheel drive the truck down the road you will have to start it in gear (1st) while driving push the clucth pedal to the floor and keep pushing up and down on the gas pedal to get the truck to rock forwards and backward the clutch should brake loose.
May 29, 2009 | 1991 Toyota 4Runner
My pto wont go in gear; 8n tracter.
Try it while just coming to a stop.or just starting to move forward.
Depress the clutch and push it back towards engagement position....because it's tied to wheel speed the moving parts might allow it to drop in.
Apr 15, 2009 | Ford 8N Tractor
Hi ive got a 1991 mr2 turbo it seems i cant select my gears properly if i do get a gear it creeps forward with the engine off i get the gears ok and the clucth feels very soft any ideas please
You need a slave cylinder and possibly a clutch kit.
Contact www.twosrus.com for parts. If this car has over 80K I would replace both and get the flywheel resurfaced and save the headaches that can creep up later on.
Feb 17, 2009 | 1993 Toyota MR2
Caterpillar Heavy Equipement Manual Dozer Logo
27 people viewed this question
Top Caterpillar Toys Experts
fordexpert
DROPNDEAL
DROPNDEAL
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
