Question about Ovens
Hygena app2170 extractor tripping MCB problem
No power to oven (MCB tripped but has now been reset on) but temperature light to small oven glowing faintly. If any control is turned on then this glowing light goes out. Any Ideas?
Check the bulbs in main oven. Bulb blows and takes out circuit board. A new circuit board will set you back £250 to £300. It can possibly be repaired if you can solder. need to take out the board behind the clock and find the blown track. if you can solder a jumper across it you can get it working again and it will cost you nothing. I had to do this to mine and it has been working for last 3 years.
Jan 14, 2016 | Neff U1421 Double circotherm Electric Oven
Stanley cooker trips when heating comes on. Clock not working
heater has the highst possiblity that causing the tripping of unit .check also before calling ur tech maybe ur MCB tipping due to evrload of
Feb 22, 2015 | Ovens
Hygena APP2420 Extractor fan
If this is a hood vent turn off the power to it from the fuse panel and open the panel and remove and replace the wire connectors one at a time looking for a wire that was not quite on right
Oct 16, 2013 | Ovens
Hygena ahy3120 manual
i need a manual for deluxe hygena oven cooker
Feb 20, 2013 | Ovens
Hob is tripping fuse box
If the hob is tripping the RCB or MCB on the consumer unit, there is a fault, usually in the elements or halogon heaters, you will need a multimeter to define but please ISOLATE FROM MAINS POWER BEFORE OPENING ANY PANEL
Some electrical knowledge would be helpful, check each element seperatly, you may have to carefuly disconect each heater on the hob, unless you know which blows the mcb, check all connectings to see thay are secure, work round the hab reostates, make sure there is no shorts to ground from elements, with temp control down at zero. Check wiring into mains as a loose connection will cause heat and mcb to trip.
If it is wired into the same outlet as an oven disconnect oven in case the other appliance is causing the problem. it is realy a question of eliminating causes one at a time, working round the affending appliance to define what is the cause.
Hope this is helpful
John
Jun 06, 2011 | Ovens
Door hinge on hygena single electric oven broken
You neede to replace both door hinges.
To get more detailed instructions on how to do this, go to the following site.
WWW.YOUTUBE.CO.UK
In the search box enter FITTING OVEN DOOR HINGES.
You should then click on the appropiate link, and follow the instructions.
Please rate my solution.
Thankyou.
Feb 03, 2010 | Ovens
Replacement knob for Hygena Turbo electric oven
You should be able to get a replacement fairly readily, try www.appliance-parts.co.uk or www.cooker-parts.co.uk.
Jan 04, 2010 | Ovens
Belling oven xou592 bottom fan oven not heating up fully. Fan works and orange thermostat light on but does not heat up. Before this happened it tripped mcb in consumer unit.
You need to fit a new oven element.
This is located at the rear of the oven behind a removeable cover, where the fan is
It is a fairly straightforward job to replace.
Hope trhis helps with your problem.
Dec 15, 2009 | Belling XOU592 / XOU593 Electric Double...
Timer clock is not illuminated and oven will not work
This does have an internal fuse and there are probably 2 or 3 of them. They should be located right behind the timer or thermostat.
Feb 03, 2009 | Blodgett Ovens
Faulty electric oven (Ignis AKL828/AV)
I think you will find that it is the oven element that has shorted, causing the trip to go. The fan will still work, but with no heat.
Remove inner rear panel of oven, there you will see the element.
Remove and replace.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Ovens
Ovens Logo
20 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
