Question about Dometic Refrigerators
Could a shortage of voltage cause an electric heating element to go bad?
We have a fridge that went out and we found that the extension cord we were plugged into was not connected all the way, we found this because we were not getting 120 volts out of the outlet. Once we fixed the plug we were getting the right voltage but the electric side of the fridge will still not work.
    Top Expert:
  • Dometic Master
  • 5,061 Answers
If works on LP might have ruined heater element if not on LP or ac bad control board
Posted on May 27, 2016
  • 6 Answers
SOURCE: Frigidaire side-by-side refrigerator keeps tripping GFI outlet.
We had same problem with different fridge. Is the fridge cooling things? When ours did that we needed to replace the relay overload start capacitor it's called a three in one. It acts like a giant battery to give your compressor a n extra boost to get started runs about 25 bucks relatively easy fix only has three wires to connect
Posted on Jan 24, 2009
  • 68 Answers
SOURCE: Norcold Fridge will not work on LP gas while traveling.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free.
Regards
Posted on Mar 24, 2009
jumptrout51
  • 3361 Answers
SOURCE: Everytime I plug in the power cord, it trips the breaker.
Refrigerators are not designed to run on a GFCI. Try a heavy duty extension cord to the fridge from a outlet that is not GFCI protected. If it still trips you probably have a short circuit in the compressor.
Posted on May 13, 2009
  • 103 Answers
SOURCE: GFI outlet is tripping because of refrigerator in the garage.
Hi: Yes, replace the GFI outlet. A refrigerator should not be plugged into one for what you are experiencing and food loss. This was an easy answer for me, but unfortunately not for you The owners manual covers this, but us men don't read them (Well I had to as I worked with them for 30 years). Good luck, Jeff
Posted on Jun 01, 2009
localwonder
  • 6784 Answers
SOURCE: KENMORE SIDE BY SIDE COMPRESSOR KICKS OFF
HI. i would recommend to check the relay first, then the compressor last to confirm total failure. If both devices test out ok, this will lead to a failed main power control board.
THE RELAY
The compressor relay starts the compressor. A fault relay can result in the compressor failing to cycle on. The relay is accessed from the lower rear of the refrigerator. The compressor relay can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. On some units. the relay may not be covered at all.(each model may vary). Beneath the terminal cover(if equipped), you will find the compressor relay, and the overload protector as well. The electrical terminals of the compressor motor are located here also. Remove the compressor relay by pulling it straight off from the compressor, gently. Pull the wire off of the side terminal of the relay. It is connected with a slip on connector. Firmly pull the connector, do not pull on the wire. You may need to use a pair of needle-nose pliers. Inspect the connector and terminal for corrosion. If either is corroded they should be cleaned or replaced. There are two types of relays you may encounter, wire coil and solid state. If the relay has an exposed wound wire coil it can be tested for continuity. Otherwise, the relay is of solid state design and requires specialized equipment for testing. Test the relay with a ohm(multimeter), for continuity. Set the meter to the ohms setting X1. With the relay upside down, place the probes into the terminals labeled "S" and "M"(the labeling may vary on each modle). The meter should display a reading of zero ohms, indicating continuity (or if using a continuity tester, it should light up). With the probes still in place, turn the relay over. You should hear the click of the magnetic switch engaging. The meter should now display an ohm reading of infinity (or the tester should not light up). Turn the relay upside down again, place the probe on the "S" terminal and place it on the side terminal labeled "L". The meter should now display a reading of zero ohms (continuity). Turn the relay over and the reading should change to infinity. With the relay upside down place one probe on the "L" terminal and the other probe on terminal labeled "M". The meter should display a reading of zero ohms. Turn the relay over and the reading will stay the same, zero ohms. Now, if the relay fails these described tests, it should be replaced asap.
COMPRESSOR TEST PROCEDURE
The compressor is accessed from the lower rear of the refrigerator. Generally the same proximity of the relay. The compressor motor can be accessed by removing the terminal cover box. The cover is held on by tension or with a retaining clip. The main testing points will be the actual terminal post that hold the relay, gently pull the relay of the terminal box on the side of the compressor, and use the relay holding probes for testing. Once the relay is removed, Place one probe on any terminal and then touch the other probe to each of the other two terminals. The multimeter should display a reading of zero ohms. Be sure to set your meter to 1X before beginning. Now move the first probe to a different terminal and test the other two terminals with the other probe. Finally, move the first probe to the last terminal and test each of the other terminals with the other probe. Every test should have continuity with the multimeter displaying zero ohms. If the compressor motor does not pass all of these tests, the compressor will require professional service. Now test the compressor for ground. With the multimeter still set to X1, touch one probe to bare metal on the compressor housing (it may be necessary to scratch away a little paint to expose the metal). Touch the other probe to each of the three terminals in turn. None of the terminals should have continuity; the multimeter should display a reading of infinity. If any of the grounding tests show continuity, the compressor will require professional service.
NOTE_ If both components test out ok, the culprit will be a faulty main control board.
Posted on Dec 03, 2009
Testimonial: "good advise. exactly what i asked for. thanks"
Oven doesn't heat up all the way on our Jenn-Air duel-fuel range
all repairs should be performed by an authorized service person. if your breakers were tripped there is a high voltage short or weak home breakers. when resetting the breakers make sure the dual breaker switches are in the on position. if the is ok check for the proper voltage is at the power outlet is correct.if it is ok unplug the range. be sure not to break the gas line. remove the rear panel check to see if the power cord power cord is secured to the power cord terminal.if the terminal is damaged do to the shortage at the terminal replace the terminal and power cord. when replacing the power cord and install the power cord restrain that usually comes with the.power cord.
Jun 02, 2017 | Jenn-Air JDS9860AAS Dual Fuel (Electric...
EARLY 1990 model (RM2652). Camper in storage for
Hello!
Your fridge might be suffering from a bubble, but is unlikely. I am more suspicious that insects (dirt daubers) have built nests on the cooling fins (at the upper rear) and air flow through the fins is being blocked.
Try switching your fridge to LP mode for a day, and see if your cooling performance increases. If so, take a look at the heater, try checking its resistance. Resistance should measure 44 ohms, +/- 10%. While you are checking for insects, also take a look around the burner area of the fridge. You are looking for a white or yellow residue. This would be evidence of a coolant leak, and the cooling unit would need to be replaced.
Given the time of year, air conditioners are being used heavily, including those in trailers. If you are using your air conditioner, and trying to use the fridge as well, make sure that your electrical cord is large enough. You want to use as short of an extension cord as possible, with as heavy gauge as possible (10ga minimum). If you are using an extension cord, or are plugged into an outlet that can't meet the current demands, that will cause voltage to drop. As voltage drops, heater (in the fridge) drops with it. If the output drops too low, there will not be enough heat from the heater to power the absorption cycle for the fridge.
Jul 13, 2010 | Dometic RM2652 Refrigerator
Fridge works pn propane but fuse blose on electric.What do i look for? please advise
I had same problem with my camper. RV repair place told me the 110velement was likely blown and shorting out. I ordered a replacement and removed my old one. When I went to the parts place , the one they handed me had different wires on it than the one I had in my hand. We checked everything out and found that the 12v element was pluged into the 110v terminals , and the 110v element was pluged into the 12 v terminals. It almost looked like it had been that way right out of the factory. Anyways , everything works great after switching the wires. If you remove your elements , and have a magnifying glass , or really good eyes , the voltage is stamped on the base of the element. While they are out , you can just hook the 110v element up to an extension chord. If it heats up it is good , If it sparks and blows a breaker , it is toast and shorting out.
May 23, 2010 | Thetford Norcold RV Cooler/Freezer
Element not heating
If the model number is correct, your heating circuits are comprised of the following components:
1. Heating Element
2. Thermal Cut-Out
3. Hi-Limit Thermostat
4. Internal Bias Thermostat
5. Thermal Fuse
You can access your heating circuits by UNPLUGGING the dryer and removing the rear panel.
As viewed from the rear of the dryer, your Heating Element will be located on the RIGHT hand side inside a heater box. The Thermal Cut-Out will be located on the outside of the heater box at the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
The Internal Bias Thermostat and Thermal Fuse are two small components mounted on the Blower Fan housing on the lower LEFT hand side.
You can refer to the following parts illustration for assistance: http://pcappliancerepair.com/model-display.php
The components are listed as follows:
Heating Element (Item 17)
Thermal Cut-Out (Item 6)
Hi-Limit Thermostat (Item 15)
Internal-Bias Thermostat (Item 20)
Thermal Fuse (Item 19)
If the dryer is running, but not heating, this is not always an indication of a blown heating element. If you need assistance on how to troubleshoot a dryer, you can refer to this link:
http://www.fixya.com/support/r3574266-thorough_dryer_advice
The MOST common causes of a dryer that will not heat are:
1. Blown Thermal Cut-Out (replace the Hi-Limit Thermostat along with the TCO if found to be bad). 2. Bad Heating Element.
3. Missing all , or part, of your input voltage at the wall receptacle - double check your source voltage at the receptacle and/or your circuit breakers.
4. Bad power cord. Check the terminal block on the back of the dryer with the cord plugged in. If the voltage is good at the receptacle, but missing a the terminal block, you may have a bad power cord.
Read through all the information provided and let me know if you have any questions, or need further assistance. I hope you find this information helpful.
NOTE: Take all resistance readings with the dryer UNPLUGGED and the component under test isolated (meaning disconnect any wire leads to ensure the accuracy of your readings).
Apr 19, 2010 | Whirlpool LER4634J Electric Dryer
DRYER WIILL NOT HEAT
If this is an ELECTRIC dryer, If your dryer runs, but does NOT heat, any one of the following could be causing your problem:
1. Heating Element
2. Thermal Cut-Out (TCO)
4. Improper input line voltage
5. Defective power cord. The following link explains how to troubleshoot and diagnose a no heat problem on an electric dryer:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
First, begin by unplugging the dryer and verifying the voltage at the wall receptacle. You should read 220-240VAC across the two Hot terminals (left and right slots). If the voltage is incorrect, check to make sure you don't have a breaker tripped. Some homes use 2 separate 120VAC breakers to provide power to the receptacle vice using one 240VAC breaker.
If the voltage IS correct, leave the dryer unplugged and remove the cover plate on the terminal block in the back of the dryer (this is where the power cord is installed). Plug the dryer back in and take a voltage reading across the two hot (RED and BLACK) wires at the terminal block. You should read 220-240VAC. If the voltage is good, you have an internal heating problem. If the voltage is bad at the terminal block, but good at the receptacle, you have a bad power cord.
NOTE: If the wires at the terminal block are not color coded, the outer two wires (left and right) are the hot leads. The center conductor is neutral or ground.
The reason a dryer will still run if the input voltage is incorrect, is because the drive motor only uses a portion of the 220 service. The motor runs off 110-120VAC, while the heating circuits require 220-240VAC. So, if you are missing 1/2 your input voltage due to a tripped breaker or bad power cord, your dryer may exhibit these symptoms.
If you determine the problem to be internal, the heating circuits are located in the rear of the dryer on the right hand. Just remove the back panel of the dryer for access.
The Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
If either the TCO or Hi-Limit Thermostat are determined to be bad, replace BOTH components at the same time. That is why these components are commonly sold as a set. Failure to do so may result in premature failure of any parts you replace.
Replacement parts (if required) can be found at the following websites:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
The average cost of these components varies, so shop and compare. The first three websites I listed also have helpful exploded view parts diagrams that can help you locate and properly identify the parts you need.
NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a new heating element that may or may not be the problem.
Read through the information I provided and, if you have any questions, please post back and let me know. I hope you find this information is helpful.
Mar 27, 2010 | Whirlpool LER4634J Electric Dryer
Kenmore Elite HE3 Electric Dryer tumbles but doesn't heat?
If this is an ELECTRIC dryer, it does not have a spark igniter. Only gas dryers use igniters.
If your dryer runs, but does NOT heat, you have a problem in the heating circuits. Any one of the following could be causing your problem:
1. Heating Element
The following link gives some advice on how to troubleshoot an ELECTRIC dryer with a no heat problem:
repairclinic.com
Read through the information I provided and, if you have any questions, please post back with your MODEL NUMBER and let me know. I hope you find this information is helpful.
Mar 11, 2010 | Dryers
Kenmore 110 electric dryer is running but no heat.......besides heating element what other causes?
If your dryer runs, but does not heat, the following link explains how to troubleshoot an ELECTRIC dryer with a no heat problem:
If you determine the problem to be internal, the heating circuits will either be located in the rear of the dryer on the right hand, or under the dryer drum on the right hand side. Usually, an easy way to determine is by the location of the lint screen filter. If the filter is on top of the dryer, the heating circuits are in the back of the dryer. If the lint screen is in the door, the heating circuits are located under the dryer drum.
repairclinic.com
If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Comments: NOTE: In many cases the problem is NOT the heating element. The heating element has protection devices that are designed to regulate the heat temperatures. If the dryer overheats the Thermal Cut-Out (TCO) typically will blow BEFORE the heating element. The replacement kit is much cheaper than purchasing a heating element that may or may not be the problem. Read through the information I provided and take resistance checks to be sure.
Jan 27, 2010 | Dryers
Tumbles but does not heat - instructions to R and R heating element
Have you confirmed the heating element is bad, or are you assuming? There's more to the dryer heating circuits that can cause a no heat problem besides the heating element.
repairclinic.com
Now...if you have determined the heating element is defintely bad, and this is a Kenmore Elite as the one you posted this question under, the following link explains how to access the heating element and replace it: http://www.fixya.com/support/r3677025-elite_duet_dryer_heating_element If you need further assistance, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope you find this information helpful.
Jan 06, 2010 | Kenmore 84832 Electric Dryer
Whirlpool LER4634J - The dryer doesn't heat. Is the heating element shot or is there a thermal fuse, etc. that could be causing the problem?
The problem could attributed to either component. But, there are several factors that can cause a dryer not to heat. If the dryer runs, but does not heat, the following link explains how to troubleshoot an electric dryer with a no heat problem:
http://www.fixya.com/support/r630242-dryer_runs_but_not_heat
All dryers are not constructed the same. However, the Heating Element is located inside a heater box. The Thermal Cut-Out (TCO) will be located on the outside of the heater box on the end opposite the heating element terminals. The Hi-Limit Thermostat will be located adjacent to the heating element terminals.
Replacement parts can be found at appliancepartspros.com, searspartsdirect.com, pcappliancerepair.com, or repairclinic.com. The average cost of these components varies, so shop and compare.
If the model number you listed this question under is correct, the part numbers you may need are as follows:
Heating Element - 279838
Thermal Cut-Out/Thermostat Kit - 279816
NOTE: If a replacement power cord is required, you can purchase them at any hardware store.
If you have any questions, or require additional assistance, please let me know. I hope you find this helpful.
Nov 26, 2009 | Whirlpool LER4634J Electric Dryer
No power to fridge. power to house ok, circuit breaker to fridge not tripped. what to do?
plug something else into outlet and see if it works your outlet/ wiring maybe bad if it works your power cord for fridge maybe bad have a short in it if outlet or cord is bad call eletrictian
Jul 07, 2009 | Sub-Zero Refrigerators
Refrigerators Logo
16 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
4stevetaylor
Level 1 Expert
RV REFER LLC
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
