Question about Exercise & Fitness
Cover stuck fast
Polar Edge cannot turn to remove from strap
2 Suggested Answers
escapement
  • 2334 Answers
SOURCE: can not change battery on Polar chest strap
Yes, there are a few.
1) As you may noticed, coin and even screwdriver blades are never sharp, but mostly blunt. So, sharpen the edge of the coin on a piece of sandpaper. Get hardened steel screwdriver or very sharp, pointed end file and scrape that indention (groove) to make sure the channel have straight sides, forming I_I shaped groove, but not V shaped groove. When done, insert the sharpened coin and unscrew the battery cover using some pressure as well.
2) In case if the groove is stripped completely, you will have to drill two small holes into the battery cover. Drill them 1mm from the battery cover's edge on opposite sides. Depth of holes should be 0.5 mm. Do not drill through completely. For drilling use 0.3-0.5 mm diameter drill bit.
When finished with both holes, take hardened tweezers, insert each arm into separate hole and unscrew the battery cover.
Do not forget to rate, please.
Posted on Jan 25, 2009
My polar heart rate monitor counts the heart beets for quite a while before it gives me the heart rate as a number it may be up to one hour before it gives me a mumber.
I would go to Polar for a definitive answer but your monitor may not be making a good contact with your body. Therefore the reception of your heart beat is constantly starting over and can't give a reading fast enough. Try adjusting how you wear the monitor and see if it makes a difference. There is a battery in the chest strap also. The new ones have to go to Polar to get replaced unfortunately. That is another possibility.
Nov 02, 2011 | Polar T31 Transmitter and Belt Set
Where can i get a replacement watch strap for my polar s410?
Contact a Polar Authorized Service Center, they keep replacement parts in stock. Any S-series strap will work, some are different colors but they are all the same for replacement purposes.
Mar 19, 2011 | Polar S410 Heart Rate Monitor
Can you change the battery in the chest strap for polar f6
There are two types of straps for Polar:
1) hard rubber/ solid - These can not have the battery changed.
2) soft strap with connector in middle - these you can change the battery.
If you have the soft strap, it will have a small hard around 3 inch long block that "snaps" onto the strap to connect it. These have a battery compartment. Turn it around and you will see the outline for the battery compartment. These are not always easy to open, and the batteries are a little harder to find. Take it into any watch repair and they should be able to pop a new battery in for you pretty easy.
There is a link on my tips and tricks page to get manuals for Polar products, the T-31 wearlink is the product we are talking about, it has the how to change the battery and battery type.
Jan 12, 2011 | Polar F6 Wrist Watch
I have no speed or trip distance showing, cadence is normally ok. also my watch strap has broken and because it is glued on i cant get it fixed!
Since your Cadence is working then there is a problem with the actual speed/ distance sensor. First make sure that in your settings you have speed turned on. If so then...
1) Your battery may be dead = Replace CS sensor
2) The distance of the sensor and magnet is not set correctly = make sure magnet on spokes and sensor are within 1-2mm of each other.
Polar can fix the strap, you need to send into an authorized service center. They replace the entire strap unit. If you send into Polar to get the strap fixed, then you can send in the sensor unit as well for diagnosis if you want. But if #2 doesn't fix, then it's #1 and they will just tell you to buy a new one anyway.
Nov 29, 2010 | Polar CS300 Cycling Computer and Heart...
Is it worth trying to replace battery of my heart rate monitor
You certainly have had good service out of the battery. It is best left to a watch repairer to replace the battery.
Feb 10, 2010 | Polar F4 Heart Rate Monitor Watch
Reebok fusion rower rev 11401 - how do i get it to see my polar heart rate monitor watch
I had cause to strip the covers off my rower now i find the strap does not recoil as supposed what have i done wrong with the reassembly...please...thx.its a reebok edge/fusion.
Sep 23, 2009 | Reebok Exercise & Fitness
Polar CE0537
you need CR2032 lithium batteries. They can be found on amazon (pretty cheap). here Finally charging for our multi device world
click on the link and chose some (by price or vendor...) I hope this was helpful. cheers
Aug 20, 2009 | Polar A5 Wrist Watch
Can not change battery on Polar chest strap
Jan 25, 2009 | Polar F11 Heart Rate Monitor
Polar F11 not responding
I' advise to start with battery check. If the battery is ok, then you will need a professional to find the cause of malfunction.
Dec 19, 2008 | Polar F11 Heart Rate Monitor
Polar CS 200 chest strap appears to be sending signal to the HRM sporadically, and therefore heart rate displays zero. I changed the battery, but this did not help.
Just read that you need to wash the belt in a washing machine and/or check the snaps for corrosion. My 200sd is doing the same thing so will try this when I get home tonight.
Dec 07, 2008 | Polar CS200 Cycle Computer/Heart Rate...
Exercise & Fitness Logo
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
