W1613 washer fault f63 - Washing Machines
2 Suggested Answers
SOURCE: miele w3033 tech fault f63. what to do?
i have washing machine miele gala grande w 3000.and i have a tech fa ult f63.what is this?
Posted on Jul 03, 2010
F15 and F63 errors? What does it means?
I am assuming its a bosch, F63 indicates a failure with the main control board can try to reset the machine but if it does not work you will need to replace the board. Try this:
Turn the knob to off and now shut the door. Turn the knob to the 6 o'clock position and wait for two seconds. Start/pause should flash. Now press and hold the spin button and turn the knob to 7 o'clock position. Release the button and turn the unit off. Did the fault erase? Try unit again.
If did not help you need to replace the main control board.
Again I don't know machine model but error 15 Fault: No pump out detected. Check pump outlet hose and sump/filter for blockages
Apr 06, 2016 | Washing Machines
Fault F63
Roger
Depending on the model number - (guessing its a W48XX series) F63 is a water path fault - This is the control unit that directs the water flow to the proper path (pre-wash, detergent, fabric softener ect..... ) Sometimes and audible clicking can be heard when this unit fails as it trying to switch to the proper path as per the program being ran.
Dec 08, 2013 | Miele Washing Machines
F 16 AND F 63
F16 occurs when you try to start machine with door open or faulty door lock, F63 is a fault with control module
Mar 22, 2013 | Siemens WM14S794GB Front Load Washer
Miele fault F63
F63 on certain washers is an indication of too much soap is being used. If you live in an area where the water is hard and your not using too much soap you have a clog in one of the hoses used for air. Try to do a hot cycle with white vinegar. On other models the F63 is indicating that the water intake valve didn't find it's position. If this is the case just run an additional cycle.
Jan 21, 2012 | Miele Washing Machines
My Miele 1374 washing machine just had a fehler f63 error. What does this mean and is it fixable?
heres your problem..
3.33 Fault code F63, water path control unit In normal operation mode the display shows Technical fault. The Check inlet LED flashes rapidly. The programme is interrupted. The drain pump is activated for 120 s. Cause Water path control system faulty. The power-programme module (ELP) cannot register a valid position of the water path control unit within approx. 80 s of it being switched on.
Note: Water intake monitoring is not active if a valid position of the water path control unit cannot be registered.
Remedy Check the water path control system. tool1.gif?leaf=true Check the water path control system circuit for an open or short circuit, and correct insulation.
Jun 05, 2011 | Miele W 4800 Front Load Washer
Miele w3033 tech fault f63. what to do?
Jul 04, 2009 | Washing Machines
Washing Machines Logo
10 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
