Vidal aaniz jrl
Can not login
How to disassemble Vidal Sassoon 1875 W (Blue) hair dryer?
hi
If the model is like this one you can use a paintbrush and with the hairdryer unplugged you can wipe the net full of dust. Then blow with air compressor if very dirty.
Plug it and enjoy
Feb 19, 2015 | Helen Of Troy VS783N3 - Vidal Sassoon...
Vidal sassoon vs505 disassemble
There is one Philips head screw near the top of the handle and there are four more behind the rubber on the handle grip. The rubber on the handle grip is attached to a curved plastic plate that has four clips that hold it to the handle, you have to pop the plate with the handgrip rubber off the handle to access the four screws.
Mar 23, 2014 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
Is it universal volt
It is not listed as such. You should not plug a 120VAC unit into 240VAC.
Nov 22, 2013 | Vidal Sassoon Sassoon Vidal 1875 Watt Hair...
How to dissassemble Vidal sassoon VSCL816. (e.g. scissors area). two phillips scresw unscrewed, but two shells of housing cannot be separated completely. Hint needed for taking away scissors. Scissors got...
I have a Vidal Sassoon Max hair clipper, and I suspect the construction of it is similar to yours. To take the two halves of the body shell apart you need to remove the blade assembly. Try this:
After removing the two visible screws, place your thumbs at each end of the cutting blades and push upwards.
The blade assembly should unclip, revealing two more screws underneath. Remove these, and the two halves of the body shell should come apart.
Graham
Apr 10, 2011 | Vidal Sassoon VSCL816 Beard Trimmer
Replacement blade
GO ON LINE YOU SHOULD BE ABLE TO ORDER THEM FROM VIDAL SASSOON.
Mar 15, 2009 | Vidal Sassoon VSCL900T2 Hair Trimmer
Computers & Internet Logo
15 people viewed this question
David Payne
David Payne
