Question about ADVANTAGE Power Advantage Electronic Bathroom Scale
Won't turn on
I have tried changing the battery a number of times to no luck, I turned it off then on still nothing I turned it to kg and to Ibs still nothing so what's wrong with this scale?
Weight 48.2kg what does that mean stones lbs ounces
Hi 48.2 kg = 7.590201 stone.....Ibs. = 106.2628. Ounces = 1700.205. Cheers
Apr 11, 2017 | Health & Beauty
The electric cord was eaten by the mouse and got shortcircuited eventually. we had the cord connected again with electrical tape but when we plugged the machine back, it won t turn on. what could ha
Did you check to see if there is a fuse blown on the machine ? Also you can go to utube and see if anyone has posted your model and where the problem maybe ? I also know that for the DYI person ;
"Time Life Books " has a series out on appliance repair , so call your local library to see if they have the book ? Hope this helps , Good Luck !!!!!!!!!!!! Grant
Aug 11, 2014 | LG Washing Machines
2005 trailblazer ignition key will not turn
If you had a dead battery, its likely the code in the radio part of the key no longer is synchronised with the car. Only a dealer can fix that I'm afraid, unless there is a guidance (check, changing the keyfob battery for example) in the car's handbook. Good luck.
Note that when it sometimes (very occasionally) doesn't work its usually due to some kind of radio interfererence just at that moment nearby. There are cases reported here in UK where several neighbours at the same time can't use their car because of some localised radio interference problems.
Dec 17, 2013 | Cars & Trucks
Samsung N145 Plus battery charge failure
If the laptop battery is more than 3 - 4 years old then the battery could be worn out. Rechargeable batteries have a finite number of charge and discharge cycles and will lose their charge capacity over time, i.e. won't charge to 100% and gradually the charge reduces until the battery won't charge up at all. OR The battery shows a 100% charge but when the adapter is disconnected the battery drops off to zero capacity in a very short time. If the battery drops to an unacceptable charge level then the battery needs to be replaced.
Sep 03, 2012 | Samsung Computers & Internet
Turned off car now it won't start I changed battery and still nothing
is it turning over at all ?? or just not firing ,if not turning over it could be immobilisor so try spare key first
Jun 15, 2012 | 1997 Toyota Camry
2009 HHR won't start. Battery is good.
Is the security light on or blinking?If not then do you have power to the starter.You can check this with a test light.You should have power when you turn the key to start.The test light should light up.Should be the small wire.I believe it is purple in color.If the security light is on then you will have to get the codes to see what is causing the no start.Hope this helps.Good luck.
Dec 07, 2011 | 2009 Chevrolet HHR
ADVANTAGE Power Advantage Electronic Bathroom Scale Logo
22 people viewed this question
Top ADVANTAGE Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you an ADVANTAGE Health and Beauty Expert? Answer questions, earn points and help others
