Question about Health & Beauty
Sec 769 scale gives error message E 10.16, what does this mean? How do I fix it?
3 Suggested Answers
SOURCE: error message
Try this, I have the same problem and I just got off the phone with Taylor, this is what they told me to do and my scale is now working again.
1. take the battery out.
2. put the scale on a flat, hard surface
3. stand on the scale for 10 seconds
4. put the battery back in, be careful not to touch any buttons or turn the scale on
5. put the scale back on the flat, hard surface
6. put one foot on the scale and apply pressure until the display comes on
7. take your foot off of the scale
8. wait for the the display to go blank
9. now stand on the scale to weigh yourself.
This worked for me. Hope that it works for all of you.
Posted on Feb 17, 2009
christyrse
  • 45 Answers
SOURCE: the Taylor bathroom scale is
If the scale is moved or bumped, or the battery is replaced, the scale needs to be initialized before use.
To initialize, just press on the platform with your foot. The display will turn on and off. The scale is ready for use once again.
Posted on Sep 26, 2010
What does Err3 mean on taylor body fat scale?
Remove your shoes and socks and wet your feet slightly with a damp cloth if you receive the "ERR3" error. ERR3 is a contact error and your feet should ideally be bare and wet to achieve an accurate body-fat reading.
  • Step off the scale and wait for it reset. Remove your shoes and socks and wet your feet slightly if you receive either the "ERR4" or "ERR5" errors, which means your body-fat or body measurements are out of range.
  • Reset the scale if it doesn't work or you continue to receive error messages. Remove the battery and set the scale on a flat surface. Stand still on the scale for five seconds and step off. Re-install the battery and place the scale back on the flat surface. Place one foot on the scale until it displays zeros or dashes. Remove your foot and wait for the scale to turn off. Step back on the scale to weigh yourself
  • Sep 28, 2016 | Taylor Health & Beauty
    Sw13 scale reads HHH
    Most likely HHH represents an error message telling you the weight of them item is higher than the scale can handle. For example if you had a very sensitive scale that weighed up to 50 carats and you put a 250 carats ring on the scale, it would give you an over load error message.
    May 17, 2014 | NATASHA COLLIS Gold nugget ring with mixed...
    Seca 769 error code e.10.11
    showing error code " Seca 769 error code e.10.11" how can i solve this problem.pls help me.
    Oct 07, 2013 | Seca 769 Digital Scale 400 Lb with Bmi and...
    The Taylor bathroom scale is giving an error message. How can I fix this?
    Sep 26, 2010 | Taylor 5593 Body Fat/Body Water Scale
    Seca 769 error code e.10.16
    What does this code mean? How do I fix it?
    Thank
    Jun 03, 2010 | Seca 769 Digital Scale 400 Lb with Bmi and...
    Display gives Error message
    On my scales you have to have bare feet for it to measure body fat index, if you still get err, moisten ythe soles of your feet with a cloth to get a better contact.
    Jan 28, 2010 | Tanita Digital Body Fat Scale with 2...
    Taylor 7532S, battery replaced, error message 0-Ld
    Try to reset the unit. Use the following steps
    - Open the battery compartment on the bottom of the scale. Push the tab on the door and lift the cover.
    - Remove the battery from the compartment. Close the battery compartment door.
    - Sit the scale right side up on a hard surface floor.
    - Step on the scale and stand still on it for five to ten seconds. Step off the scale.
    - Turn the scale over and open the battery compartment. Re-insert the battery. Close the battery compartment cover.
    - Place the scale right side up on the hard surface floor.
    - Press one foot on the scale until the display shows zeroes or dashes. Remove your foot.
    - Wait for the scale to shut off by itself. When you step back onto the scale, it will be reset.
    Hope this solution has been helpful?
    Jan 26, 2010 | Taylor 7532 Ultra Thin Glass Digital Scale
    I have a Taylor body fat analyzer and scale model #5563 that keeps showing Err 2. It won't read any weight whatsoever... it just goes stratight to the Error message. Do you know what that means and how I...
    From the Taylor Site http://www.taylorusa.com/faq-scales
    Here are the basic ERR messages and their meanings:
    • Error 0: Initialization
    • Error 1: Instability (scale is on an uneven surface ex: carpet)
    • Error 2: Unit may have been jarred or unit was overloaded (customer went over the maximum weight capacity)
    • Error 3: Contact error (Feet were not wet for Body fat reading, feet aren’t big enough to reach sensors)
    • Error 4: Body fat is out of range
    • Error 5: Water is out of range
    I got an ERR2 message and now the scale doesn’t work. What should I do? The following reset procedure is used when the scale shows an err2, err, 0.0, inaccurate weight, or some other unusual error.
    1. Remove the battery from the scale.
    2. Sit the scale on a hard surface floor.
    3. Step up onto the scale, stand still for about 5 seconds and step off the scale.
    4. Re-install your battery.
    5. Place the scale back on a hard surface floor.
    6. With one foot only, place just enough weight on the scale for the display shows zero’s or dashes. Once you see zeros or dashes remove your foot.
    7. Wait for the scale to turn off again.
    8. Step up onto the scale for a weight.
    If the reset is successful, you should receive a weight right away. If you continue to receive one of the error messages above please call our Customer Service department or contact us via email. You can also try the reset procedure a 2nd time. Sometimes the reset procedure will work the second time.
    Jan 15, 2010 | Health & Beauty
    E000 error message on canon imagerunner 2000 copier
    Hello.
    E000 means :
    "The main thermistor reading does not reach 40oC 14 sec after the fixing heater goes ON (fixing low temperature error)"
    Jan 19, 2009 | Canon ImageRunner 1600 Copier
    Health & Beauty Logo
    53 people viewed this question
    Top Health & Beauty Experts
    Robin Hill
    Robin Hill
    wcdoc1953
    wcdoc1953
    Are you a Health and Beauty Expert? Answer questions, earn points and help others
