Question about Vizio Gallevia GV42LF 42 in. LCD Television
TV will not turn on 26vizio tv no light or power to set
No power on or off t 26 vizio tv
  • 191 Answers
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Posted on Nov 10, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
My vizio tv just has the vizio light on when i plug it in it wont turn on
Sounds like a problem in the power supply. Possible bad capacitors if you can have it checked out.
Apr 22, 2013 | Vizio VA26LHDTV10T 26" 720p LCD HDTV
No power on vizio E371VL
Vizio TV model E371VL turned on ok and had tv show on ch.4.
Turned on the DVD player and put movie dvd in and closed tray.
We have done thhis numerous of times and never had a problem.
This time " HDMI " was showing on top right of black screen,
then " No Signal " came up on screen, then went completely black screen. Called Vizio, they had me power off and unplug set.
Push and Hold power button on TV for 30 sec. to reset.
Replug set and Vizio (lighted) on lower front of set lighted normally dull orange. Pushed power button on remote and when set did not come on, then push main power button on side of TV. Nothing, no White " Vizio " from orange light. Is this a power supply (0500-0412-1020) problem ? Thanks, Sidney (sidneysites@yahoo.com)
Feb 17, 2013 | Vizio E371vl 37 Inch Class Lcd Hdtv
When i turn on the tv the orange light comes on but no tv
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Vizio VW26L 26 in. LCD TV
Vizio m260va no power flashing power light
This is an error code indicating failure of some board and might need attention by a qualified service technician.
Jul 30, 2012 | Vizio M260VA 26 in. HD-Ready LCD TV
Vizio vw26l
replacing the power supply board should solve the issue you can get the replacement power supply board from www.tvrepairworld.com
Jun 01, 2012 | Vizio VW26L 26 in. LCD TV
Vizio vw26l after about 20 minutes the picture flickers then blinks out, then back on
most common problems are in power supply or main board, a 26 inch set from a cost point of view just may not be worth fixing............?
Vizio M261VP 26'' LCD TV no picture, logo does not light up
If the Vizio logo(power indicator) isn't coming on when the set is plugged in, most likely you have a issue with the power supply. Your standby power supply isn't working, and without it, you will have a dead set.
May 12, 2012 | Vizio M261VP 26" LCD TV
Need code for my vizio tv i bought a ihip remote control for my tv
The instructions on letting the Hipi remote to seach for the code that came with my remote are not correct. I used the instructions from HOWTO.COM and printed below. There are two changes from the printed instructions. The first is to push the <TV> button after the <Code Search> button. The second is that the <Enter> button saved the code not the <MUTE> button.
Instructions
Turn on the Vizio TV.
Aim the Jumbo Universal Remote at the Vizio TV and hold down the "Code Search" button on the remove for roughly 3 to 5 seconds. The LED lights on the Jumbo Universal Remote will come on.
Press the "TV" button at the top of the Jumbo Universal Remote.
Start pressing the "ON/OFF" button repeatedly until the Vizio TV turns off. (This took only a few tries for my Vizio TV)
5
Press "Enter" on the remote immediately after the Vizio TV turns off to save the code.
6
Test the Jumbo Universal Remote by trying to control the Vizio TV with the remote. If the control doesn't work with the remote, repeat the entire process.
Nov 15, 2011 | Vizio VA26L 26 in. LCD HDTV
I cant find the code to program my wide open west remote control to turn my Vizio TV on and off
SEARCHING FOR YOUR CODE
1. Turn on your TV.
2. On the remote control, press TV once; it will
blink once.Then press and hold SETUP until
the TV key blinks twice, then release SETUP.
3. Enter 9 - 9 - 1.The TV key will blink twice.
4. Aim the remote control at the TV and slowly
alternate between pressing PWR and TV.
Stop when the TV turns off.
5. Press SETUP once to lock in the code.The TV
6. To search for the codes of your other devices,
repeat steps 1 through 5, but substitute the
appropriate key (e.g., AUX, DVD, AUD, or CBL)
for the device you are searching for.
http://www1.wowway.com/remotecontrol/
Good luck, pls rate it :)
Dec 16, 2009 | Vizio VA26L 26 in. LCD HDTV
No Audio in my Vizio HD TV
I solved the problem by going into settings. Then audio. I had one of the audio settings turned off
Oct 05, 2009 | Vizio VA26L 26 in. LCD HDTV
Vizio Gallevia GV42LF 42 in. LCD Television Logo
22 people viewed this question
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
