Question about True GDM-45 Refrigerator
Where do I find the ballast in a True GDM-45 cooler?
SOURCE: True Refrigeration GDM-26 Compressor problem?
More than likely you need a new compressor. It sounds like it's trying to start and then trips on it's overload or capacitor may be out.
Posted on Sep 13, 2008
  • 400 Answers
SOURCE: I have a true GDM-12FC floral cooler that the
You have not said if the cooler is cooling to the correct temperature or achieving the setpoint. Make sure that the correct thermostat has been supplied. Also that the sensor has been installed in the correct location. If all of the above is correct, then I would have the refrigerant level checked.
Posted on Mar 09, 2009
rockitman187
  • 2559 Answers
SOURCE: TRUE COOLER COMPRESSOR CYCLES ON 45 SECONDS AND OFF FOR 2 MIN.
The unit has a temperature swing adjustment screw located behind the thermostat plate.If you remove the knob and the face plate you will see it,It can be adjusted there.It may also be the thermostat bulb is going bad or touching something and giving a false signal to the compressor.
Posted on May 03, 2009
  • 906 Answers
SOURCE: GDM-41 Refrigerator: True GDM-41 Refrigerator getting too cold...
good day,
hope this link below will solve your problem.
ref
Posted on Aug 03, 2010
  • 266 Answers
SOURCE: i have a true brand
Either the compressor is going bad or the start relay on the compressor is going bad. The relay is under the plastic cap on the compressor it will be a nickle size round disc with one wire hooked to one of the 3 prongs coming out of the compressor. This is what you hear click. But to be honest normally this points to a bad compressor and then its time for a new fridge. Hate to give bad news good luck
Posted on Aug 15, 2010
How do i chage the temperature on a true cooler gdm 49 florial cooler
True GDM-12 Refrigerator... Repair Questions - Fixya
www.fixya.com/support/p22955-true_gdm_12_refrigerator_commercial
Recent True GDM-12 Refrigerator Commercial questions, problems & answers. ...Where is the temp control on the older (14 yrs or so) on GMD-12? True ..
Aug 16, 2014 | True GDM-12 Refrigerator Commercial
Gdm 45 with new thermostat goes down to 28 degrees and compresor does not shut down
If the new thermostat sensor is secure and where it belongs, it has the wrong charge in the system. That cooler takes a critical charge. The factory charge is in ounces if refrigerant. The system needs to be evacuated completely with a vacuum pump and recharged with an accurate scale that weighs in ounces. That will solve your problem. A refrigeration tech carries the necessary tools that an hvac tech doesn't. Hope this helps and good luck.
Apr 13, 2014 | True GDM-45 Refrigerator
I need to replace the ballast on my GDM 12 freezer and I need to know where the balast is located
The ballast is located on the bottom inside wall where the compressor is located. Its usaually mounted, and can be easily removed and replaced. The ballast is rectangular in shape and has a few wires protruding from each end. To replace simply dismount the bad ballast and clip the wires. Match the ballast to a new one, reattach the wires using wire nuts, and remount ballast.
Jul 24, 2009 | True GDM-12 Refrigerator Commercial
Interior Lighting on True Refrigerator Unit
A starter may be located in the top area inside the cooler. Not all true coolers have starters. Check the connections where the light pins slide into. Also may need new ballast.
Jul 24, 2008 | True GDM-9 Beverage Cooler
True GDM-45 Refrigerator Logo
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
christian nielsen
Are you a True Refrigerator Expert? Answer questions, earn points and help others
