Question about As Seen On TV Tobi Steamer The Original Clothes Steamer
Tobi steamer parts
I need to buy a hose and steamer attachment for my tobi clothes steamer
Where can I buy tobi steamer parts
Have you tried Tobi? The manufacturers usually can supply parts.
Sep 03, 2014 | Cars & Trucks
My Tobi Steamer will not power on?
Check the fuse in the mains plug and replace it with a like value one. If this doesn't work your iron is at fault.
Jan 08, 2014 | Irons
I need a replacement hose for my tobi steamer
Can't you cut the hose so it is even across, and level? Reaffix the hose to the steamer portion. Just remove the old attached hose from the end of the handle, clean it and reaffix the freshly cut end into the handle once again.
Dec 21, 2013 | As Seen On TV Tobi Steamer The Original...
I left the stemmer on and all the water was gone and the light went out...it wont turn on now. is it finished?
Possibility is that the coil burned up or a thermal fuse opened. If it was a thermostat, it would have reset. Replace it.
Aug 10, 2012 | As Seen On TV Tobi Steamer The Original...
Maxi cosi tobi strap has jammed
It's not possible to loosen the belts of your Tobi?In this case you may need a repair of the quick-adjuster (the part where the buckle is attached to) or it may be appropriate to exchange the quick-adjuster.
Because this part is directly affecting the safety of the seat I would advise you not to try to repair it yourself; please visit a Maxi Cosi dealer to have it serviced.
I hope this helps.
Erwin de Raadwww.babycare.nl
Sep 20, 2011 | Maxi-Cosi Maxi Cosi Tobi MAGIC ROSE 2008...
My Tobi Platinum clothes steamer gets hot at the handle making it too hot to hold and steam with??
We had the same problem but discovered it was because the steam hose had come adrift from it's fitting inside the handle. Dismantling the handle, re-attach the hose, re-assemble the handle and use some tie grips to hold the very poor design together and the problem was solved.
Apr 02, 2011 | Vacuums
I need replacement parts for my Scunci SS-1000 Steamer
hi i need this part for my scunci steamer model ss-1000 this is internal parts inf to dannacielcr@hotmail.com thanks
Jun 04, 2010 | Scunci SS1000 Handheld Steam Cleaner
Conair steamer leaks water and wets my clothes.
When I use mine I hang the hand held part from my closet door, while I am waiting for it to heat up. When the hose gets too much condensation, from the steam, it leaks out... This will also happen if you try to use in the motion of an iron. The hand held part needs to be at a vertical position at all time to prevent leaking.
Jan 24, 2009 | Conair Compact Garment Steamer Iron
Re Conair garment steamer ctx12c
I bought this model from Costco and followed the instructions and tried using the picture on the box. You may have trouble, or at least be confused, if you try to attach like the picture on the package because the hose in the box is not exactly as pictured.  The hose you get does not have that extra ribbed part around the end that attaches to the console.  Therefore try the other end and you should be able to attach.  Once you figure that out make sure you "lock" the hose into place.  If not steam will escape from the loose installation and may scald you if you reach down.
Oct 06, 2008 | Conair Compact Garment Steamer Iron
As Seen On TV Tobi Steamer The Original Clothes Steamer Logo
27 people viewed this question
Top As Seen On TV Televison & Video Experts
Andrew Taylor
Andrew Taylor
Are you an As Seen On TV Televison and Video Expert? Answer questions, earn points and help others
