Question about Cameras
Lens error fujifilm finepix s2980 - Cameras
zohail
  • 1223 Answers
SOURCE: My FINEPIX s1000fd fujifilm camera
pls update firmware issue will be resolved most likely and pls rate me fixya for help
http://www.fujifilm.com/products/digital/download/s1000fd/fupd.html
Posted on Apr 13, 2009
  • 11967 Answers
SOURCE: Fujifilm Finepix S1500. CARD ERROR
You may need to format the card in the camera. This will completely erase it so download the pictures first. Use a card reader if necessary.
Posted on Sep 28, 2009
richard191
  • 691 Answers
SOURCE: Lens control error
Hello
Thank you for using FixYa for your problem
Sorry but the Zoom Lens has had a knock, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Posted on Dec 22, 2009
  • 1040 Answers
SOURCE: I keep getting a lens control error on my FujiFilm
Sorry Friend, it is a mechanical problem so get it serviced.......
Posted on May 08, 2010
  • 11967 Answers
SOURCE: Fujifilm finepix J37 zoom error
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jul 17, 2010
Turn off camera and turn back on will not go away
I guess your camera has the message turn off the camera and turn on again.
This message will occur when the camera has any malfunction. Could be caused because you obstructed the lens while focusing or zooming. Could be lots of other things.
If the switching is not enough and you observed the lens is retracting complete when switching off. Please remove the battery for a little while. Perhaps you could use the time to recharge the battery. Then when you replace the battery and the camera still gives this error, there is only one thing you can do: Please contact a FujiFilm dealer.
Nov 19, 2013 | Fujifilm Finepix S2980
Tells me to turn off and back on
Fujifilm finepix s2980 says turn camera off and turn it back on. Sounds silly but someone on here said drop camera from about 2to 3 foot on to carpeted ground, and mine started working again. something to do with lens gears not engaging. and the impact was enough to ironically make it re-engage. Thanks just saved £55 cost of camera and proberly more if I was to sent it for repair.
Nov 06, 2013 | Fuji FinePix S2980 Digital Camera
Re Fuji finepix, keep getting message turn off camera, turn on again as lens won't extend, so camera not useable, batteries fresh. any ideas? thanks, robin
Remove and reinsert the batteries or disconnect and reconnect the AC power adapter/DC coupler. If the problem persists, contact your FUJIFILM dealer.
Before that:
Carefully check if and eventualy where the lens is blocked. Don't touch the front lens. Feeling for any movement on the edge not on the glass. If there is not any obstruction, then perhaps the motor that should move the lens is defect. If you can find anything that blocks the lens, ask a technician if he / she can remove is. Or else I'm affraid you have to visit your FUJIFILM dealer.
Oct 31, 2013 | Fujifilm Finepix S2980
Is compatible with SDXC & support 64GB?
No. The S2980 works with SD cards (up to 2GB) and SDHC cards (up to 32GB). It does not work with SDXC cards.
May 16, 2013 | Fujifilm Finepix S2980
Setting aperture for fujifilm s2980 camera
Rotate the mode dial to A. Press and hold the exposure compensation button and press up or down on the selector to change the aperture. For full details see page 28 of this manual.
Jan 27, 2013 | Fujifilm Finepix S2980
Me sale un mensaje que dice que apaga y encienda nuevamente
go to the repair shop from fujifilm , see if your manual say something in your troubleshooting section.
God bless you
Oct 03, 2012 | Fujifilm Finepix S2980
Lens locking on s2980
Try blowing ******* the lens. If it doesn't work, hold your camera with the lens facing the ground and tap your camera repeatedly so any dirt inside the lens mechanism will fall out.
Aug 13, 2012 | Fujifilm Finepix S2980
When I turn on my s2980 the lens does not extend.
robmcd27, I did what you said with the SD-card, but it still doesn't work... help me? :(
Jun 27, 2012 | Fujifilm Finepix S2980
Protected memory card on S2980
SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
May 20, 2012 | FUJIFILM Cameras
Cameras Logo
16 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
