Question about Radio Communications
Instructions for recharging RadioShack 1250mAh Slim-Style Portable Power Bank
I'm lost I have a superex slim power bank 2600xmAH I try charging and the percentage of power remaining goes down, I'm not doing it right. There is in & out at one end for connections, what!!!
in is for recharging the power bank and please note that it takes time to charge. and out is for your charging your devices when the bank is charged. yes you can use the same cable for both by inverting. and do not loop i.e connect the in to out whatever you do
Feb 17, 2016 | Computers & Internet
User guide for Craig portable power bank model # cma3121a
Craig Electronics Inc
Portable Power Bank with Dual USB Charging Port (3400mAh) CMA3121a Features & Specs Best Replica Watches
  • Quickly Recharge any USB Powered Device such as Tablet, Smartphone and iPad
  • Stylish blue LED power indicator
  • LED light indicates Battery level
  • Built-in TWO Full size USB ports for any device charging via USB port simultaneously
  • Charges Two mobile devices at the same time
  • Scratch resistant UV coating
  • 3400mAh, One Max. 2.1A Output, One 1A Output
  • Available in Colors
ASME B16.5 Accessories Included •Micro USB to Full Size USB Cable
•Mini USB to Full Size USB Cable
Jun 23, 2015 | Craig Televison & Video
How to charge htc phones?
if you are outside and can't help yourself to charger your HTC phone, i recommend you can choose a rechargeable portable mobile power bank device
May 24, 2012 | HTC EVO 4G Smartphone
I have a Century Jumper 1000 with no user manual. How do I recharge it?
Portable Power Source Owners Manual Units Manufactured Pre 03/99 Price $8.00
Portable Power Source User's Manual. This Operators manual provides specific information for your model. This manual contains information such as the Important Safety Instructions, Usage and Maintenance of your Booster Pac. This document is provided as a download PDF format. We suggest you save it to your computer for future reference.
Model Coverage: ES2500, ES5000, J1000, JUMPER 1000, J850, JUMPER850, For Models with Old Style Manual Charging Board "Cigarette Lighter Style Charging Jack" (pre 03/99)
Oct 13, 2010 | Vacuums
The PSP won't recharge
Hello :
First you need to check the charger . If charger is working fine , then check the power cord . If the power cord is working fine , then the problem is that the battery is dead [ can't be recharged anymore ] . You need to replace the battery in a such situation .
If it's none of that , then I recommend you to replace it , if you still have the guarantee . Or just take it to the service .
good luck .
please rate !
Mar 30, 2010 | Sony PlayStation Portable (PSP) Slim...
Psp will not come on and it has a new battery in
well it sounds to me like you need a pandora battery because your psp lost alot of memory. you can find one in a gamestop or walmart or radioshack. and taget too. and when u get, turn the psp on and let the psp load up it memory.
Sep 22, 2009 | Sony PlayStation Portable (PSP) Slim...
I need a AC Adapter and power pack for a durabrand dur-10 dvd player.
radioshack has multiversion powersupply. if not contact durabrand for replacement
Jul 07, 2009 | Durabrand PDV-705 Portable DVD Player
Psp screen wont turn on
you need to recharge your unit for some more time, it means that the battery is fully drained
Jan 09, 2009 | Sony PlayStation Portable (PSP) Slim...
Need battery charger
You can buy it to any electronic or computer shop nera you like Bestbuy , Radioshack or any other store just give them model of your device and they will be able to provide you that....
Nov 12, 2008 | kawasaki PVS1080
Power Supply How To
Because inverters operate from a DC (Direct Current) power source, usually a battery bank (one or more batteries), the battery source will have to be recharged at some point. (Remember that a battery discharged more than 50% is probably close to being dead.) Most cars and trucks recharge their batteries from an onboard alternator. Depending on the inverter load and runtime required, most power use applications will be covered by the charged battery, augmented by the operating alternator supplying a continuous charge to the battery. If the load is large (air conditioner, large draw power tools, large microwave, food freezer, ice cream machine, etc.), the user should verify that the installed vehicle alternator is of large enough capacity to operate the vehicle's power requirement as well as to fulfill the capacity of the inverter load. If it’s not, a motor throttle installation may be required to carry a small load, a larger alternator may be required, or a larger alternator, battery isolator and additional onboard battery bank may be required in order to meet the power requirement of the large load. Remember: it takes 12 DC Amps (at 12 VDC) to run 1 AC Amp (at 120 VAC single-phase) of power because there are voltage and efficiency factors to take into consideration.
Aug 27, 2008 | Xantrex Technology Xantrex Freedom Xmic...
Radio Communications Logo
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
