Question about Riccar Vacuums
Coin in motor riccar vacuum - Riccar Vacuums
  • Riccar Master
  • 1,317 Answers
It's impossible to get a coin the motor of most Riccar models. Take it to your dealer to see if it's possible with your model.
Posted on Aug 11, 2014
Why does the belt on a riccar vacuum keeps coming off?
The cause could be different depending on which model you have. Some models have stretch belts which should be replaced at least once per year because they lose elasticity. The most common problem I've found with Riccar vacuums is the belt coming off when a new belt is installed on an older model. Riccar vacuums are very well built and many owners use their vacuum for many years without having it serviced. I recently had a 17 year old Riccar Vibrance model brought in for service because the belt crumbled to pieces. The vacuum had the original belt and filters. Putting a tight new belt on the vacuum pulls on the motor because it must be stretched so much. After many hours and years of use screws may need tightened up and motor mounts and pivot points can become worn.
If your model is a few years old or is used heavily I suggest having it inspected by a qualified Riccar service center. A properly maintained Riccar vacuum can last 10 or even 20 years. A few dollars spent on maintaining it can add years to the usable life.
Feb 04, 2017 | Riccar Vacuums
How do i replace the fan on a riccar rsl3 vacuum cleaner?
RICCAR SIMPLICITY SUPRALITE RSL MOTOR and FAN
Its looks the same as a Kirby its done with a nut on the axle on the armature of the motor.
Feb 20, 2016 | Riccar Vacuums
How to replace motor on 8925 riccar vac?
There is not a motor bushing on a Riccar 8925, it has sealed bearings. There is nothing that needs to be timed or adjusted in the motor.
Jul 17, 2014 | Riccar 8925
Belt continually slips off Riccar upright vacuum
Your 8850 is an old vacuum. If a new belt does not solve the problem it may need a new rubber motor mount or metal pivot. Both parts are inexpensive and available from your Riccar dealer. If it's been a while since it's been serviced it would be wise to have it serviced by your dealer. A Riccar vacuum will last for many years but should be serviced once a year like all vacuums.
Apr 07, 2014 | Riccar 8850 Vacuum
Parts schematic for riccar 8920 vacuum
I am looking for a new motor for my 8920 Ricaar Vacuum. All else works fine.
Jul 13, 2012 | Riccar Vacuums
Riccar model 8625 need compatible repalcement motor for original Ametek # 117405-00 12 amp no longer available ?
You can likely get any 8000 series motor to fit but there are different motors and you really need to talk to a qualified trained Riccar repair technician to determine the proper motor for your model. Your model is almost 30 years old and a newer motor would be difficult for the average homeowner to safely install. You were given good advice because they told you to discuss it with a qualified retailer for the proper way to safely get your vacuum running again. If done properly there could be many more years of usable service left I your old vacuum. If done wrong it could cause damage to the motor or other parts of the vacuum or even cause a fire, death or injury.
Jan 21, 2012 | Riccar Vacuums
My Riccar 8850 stopped running. Changed the bag and cleared all hoses. Light comes on but the motor doesn't operate. I can turn the brush freely by hand.
Greetings from GoVacuum,
If the light on your Riccar 8850 is coming on, but the motor is not coming on, this indicates that your motor has gone bad. There is a reset switch on the back of the vacuum cleaner that sometimes trips if the bag is too full, or the filters are not maintained, but when this happens nothing on the vacuum comes on including the headlight. If the headlight is coming on, this indicates that electricity is making it down to the headlight, and the current is going through, but just not activating the motor. This is a tell tale sign of your motor being bad, and needing replacement. You can purchase the motor for the Riccar 8850 (12 AMP, 2 stage motor, Riccar part D113-1700 $122.44) from GoVacuum by giving us a call, as we don't yet have this part on our website.
I hope this helped you. We have been fixing Riccar's for over 30 years, and they are great vacuum cleaners, and the age of the model 8850 is probably the life expectancy of this vacuum cleaner.
Chris Jones
GoVacuum.com
Mar 18, 2010 | Riccar 8850 Vacuum
Riccar 8955 sweeper won't run...where is thermal protection switc
thermal reset is located on the back of the machine at the bottom
Nov 24, 2008 | Riccar 8955 Upright Vacuum
Vacuums Logo
24 people viewed this question
Top Riccar Vacuums Experts
ray gallant
Thatvacguy.com
Are you a Riccar Vacuum Expert? Answer questions, earn points and help others
